Hello everybody,
Are you in need of a high quality custom cable? Then you came to the right place!
Not only do I use new high quality components, but you can also completely customize your cable!
You can count on it that I am only satisfied when the cable is perfectly put together by my own hands. It might take a little longer, but I do not want to sell flimsy and rushed products!
So, what can you use the cables for? Well here are some examples:
- Internal cables for your keyboards; Filco, Realforce, Dell, Noppoo and more..
- External USB cables for keyboards (HHKB, Phantom, Ducky, etc.), printers, DAC, hard disks, phones, etc.
- Detachable mini-usb cables for your keyboards
- Audio cables: RCA, 3,5mm, whatever you require.
- And pretty much everything else on custom demand as long as I can get my hands on it and if it's feasible. You want something unique? I'll make it!
Here are some options that I offer:
- Paracord or MDPC sleeving
- Silver or Gold connectors
- Several types of connectors: USB-A, USB-B, Male Mini-USB, Female Mini-USB, Micro-USB, PS/2, ..
- Different internal PCB connectors for a variety of keyboards
- Detachable cables
- Ferrite cores
- Cable holders (with pre-applied 3M tape)
- Heatshrink on request
Order FormsClosed indefinitely
All the information you need should be in the forms, but in case something is not clear or missing, send me a PM!
SleevesParacord: soft, sturdy and nice to touch
MDPC-X: premium durable netted plastic sleeving
http://de.mdpc-x.com/mdpc-sleeve/sleeve.htmUSB housing and cable holders For more examples of what I've done please take a look at the other pages
If you have any questions/comments, doesn't matter how small or big, just ask them. I'm happy to answer. You can always contact me via PM and I'll try to respond as fast as I can.
Please take into account that I have a fulltime job and I'm doing this as a hobby so sometimes life can get in the way and delays can occur.
Paranoid
