Author Topic: [IC] Phantom PCB  (Read 46027 times)
Offline bavman
[IC] Phantom PCB
« on: Fri, 14 December 2012, 11:39:40 »
We've gotten a go-ahead to use the Phantom PCB designs to run a GB.
We'll only be running just the PCBs, no controllers/switches/plates/diodes.
Switches and diodes are fairly common to find/source, and teensy controllers can be bought from  PJRC electronics: http://www.pjrc.com/teensy/index.html
Pricing is yet to be announced until I hear back from pcbwing, until then, the original GB ended up being $35.
Here are reference threads to info about the plate:
http://geekhack.org/index.php?topic=26742.0
http://geekhack.org/index.php?topic=23572.0
Phantom PCB board borrowed form Litster:
« Last Edit: Fri, 14 December 2012, 12:10:52 by bavman »
Re: [IC] Phantom PCB
« Reply #1 on: Fri, 14 December 2012, 11:47:47 »
« Last Edit: Fri, 14 December 2012, 11:49:29 by metalliqaz »
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
« Reply #2 on: Fri, 14 December 2012, 11:48:40 »
YIIIIIIIIIIIIIIISSSSSSSSSSSSSSSSSSSSSSSSSS
Offline korne
    • comscan
« Reply #3 on: Fri, 14 December 2012, 11:49:30 »
I'm interested for sure
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #4 on: Fri, 14 December 2012, 11:54:47 »
If I could find a good case, this would quell my urge to get a tkl korean board, I think.
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #5 on: Fri, 14 December 2012, 11:58:09 »
That urge doesn't die after it starts ;)
Question, are these PCB's going to be exactly the same as the ones from the original Phantom GB?
Any potential add on to this GB for cases?
Offline bavman
« Reply #6 on: Fri, 14 December 2012, 11:58:41 »
nvm
« Last Edit: Fri, 14 December 2012, 12:11:00 by bavman »
Offline Shadovved
  • King of Stickers (and GBs)
« Reply #7 on: Fri, 14 December 2012, 11:59:12 »
Just get the korean tkl and laugh at the world  :p :p :p
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #8 on: Fri, 14 December 2012, 12:04:14 »
But this is equally exclusive.  And I can read the instructions and I don't have to know a korean to get one ordered or get stupid lucky like I did with my mxmini and 356mini...
Just need a good case for these.  Wonder if treble would do it once he's running at capacity again.
Offline Shadovved
« Reply #9 on: Fri, 14 December 2012, 12:05:17 »
Imma gonna run a custom case for myself whoopie! :p
Offline Dgsbllx
« Reply #10 on: Fri, 14 December 2012, 12:06:57 »
Offline WhiteFireDragon
    • youtube
« Reply #11 on: Fri, 14 December 2012, 12:08:49 »
I have one, but interested in another PCB. Can it be slightly modified to accept SMD diodes and controller? Without a daughterboard controller, it's easier to design future cases to fit.
And also, this PCB fits all layouts listed in the google doc so why do we need to choose which layout option?
Offline bavman
« Reply #12 on: Fri, 14 December 2012, 12:10:19 »
Mainly because I didnt know ;)
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #13 on: Fri, 14 December 2012, 12:12:35 »
« Reply #14 on: Fri, 14 December 2012, 12:13:34 »
In for 2 (or 3).
I bet The_Beast will run a plate GB if people need plates. ;D
Offline duq
  • Connoisseur
[IC] Phantom PCB
« Reply #15 on: Fri, 14 December 2012, 12:14:27 »
Interested.
« Reply #16 on: Fri, 14 December 2012, 12:15:21 »
Did this get cross-posted to DT? If not, it should...
Offline Sai
« Reply #17 on: Fri, 14 December 2012, 12:16:41 »
again. i am interested but wallet not allows.  :'(
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #18 on: Fri, 14 December 2012, 12:16:58 »
In for 2-3...
Just turn this into the GB :)
Will need to check with Dan to grab another plate :)
-Enzo Ferrari
« Reply #19 on: Fri, 14 December 2012, 12:22:54 »
Yes, exactly the same.
It could, yes, and I've talked with bpiphany about just those options (plus holes for PCB mounted switches and stabilizers). He is (inactively) working on a 2.0 revision, but we have nothing but the original at the moment.
Offline phetto
  • HHKB JP
[IC] Phantom PCB
« Reply #20 on: Fri, 14 December 2012, 12:23:32 »
I'm in for 5
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #21 on: Fri, 14 December 2012, 12:25:07 »
It may not be the worst thing in the world to coordinate with beast or someone to smoosh plates into this GB as well.  Also, I think oneproduct is working on an aluminum/acrylic case that would work as well.
Offline mistakemistake
  • Global Loveinator
« Reply #22 on: Fri, 14 December 2012, 12:39:09 »
I'm in.
« Reply #23 on: Fri, 14 December 2012, 12:41:06 »
I'm in.
Yay! Does that mean you're in for making some kind of little detachable cable stubs for these? ;)
Offline Piehunter
« Reply #24 on: Fri, 14 December 2012, 12:43:02 »
Hey, would anyone be kind enough to tell me how much the whole endeavor would cost? (or in what balllpark it runs in) before i put my finger in the gear :S
from what i understand
pcb 35
plate 15-35 (based off GB from boostbeast and whitefire
Case =??? (i saw some made in aluminum that were like 300+ but thats a bit out of my budget range)
keys = 40-50? @ around .4 per key or something like that
and then you would need keycaps ofc...am i missing anything else?
edit: sorry for name mistake :S
« Last Edit: Fri, 14 December 2012, 13:03:40 by Piehunter »
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #25 on: Fri, 14 December 2012, 12:45:37 »
pcb 35
plate 15-35 (based off GB from boost and whitefire
I didn't do a plate GB sir. l
You also need to ad $16 for the teensy 2.0. You'll need a filco case. not sure if the PLU cases will work
-Enzo Ferrari
Offline alaricljs
  • I be WOT'ing all day...
« Reply #26 on: Fri, 14 December 2012, 12:47:00 »
boost != the_beast
Filco w/ Imsto thick PBT
  • Global Loveinator
« Reply #27 on: Fri, 14 December 2012, 12:47:45 »
I'm in.
Haha.. sure :) I'll post up a DIY on how to do an inline female mini-b connector, so you can use any usb cable. I'll keep you all posted when time gets closer.
Offline Sai
« Reply #28 on: Fri, 14 December 2012, 12:47:59 »
pcb 35
yes. thats what i want to know as well.
The total cost for building a phantom :D
Offline TheProfosist
  • Custom Layouts Only!
Re: Re: [IC] Phantom PCB
« Reply #29 on: Fri, 14 December 2012, 12:48:20 »
boost != the_beast
lol yea i messed that one up the other day my self but even worse had MMB mixed in as well.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #30 on: Fri, 14 December 2012, 12:50:02 »
pcb 35
 1 PCB (includes 2 white LEDs and2 resistors) - $35
 1 Plate - $25
 1 Teensy (includes 1 40-pin pin header) - $16
 100 switches - $65ish (I think that's what I paid to get them from 7bit)
 100 diodes - $4
 4 2x stabilizers for ANSI or 3 2x stabilizers for ISO or 0 for PH7BIT - (??)
 1 7x or 1 6.25x stabilizer set for spacebar or 0 for PH7BIT - (??)
 1 case - Depends on what you go with or can find.  There are acrylic cases that would work starting at $40ish, or you could try and find another filco case.
I would think, all said and done to plan for $300 before caps.
« Reply #31 on: Fri, 14 December 2012, 12:51:06 »
pcb 35
plu cases work like a boss contact qtan about a plu-87 nothing else
Offline nebo
« Reply #32 on: Fri, 14 December 2012, 12:58:10 »
I'd be in for this. I remember watching the KMAC and phantom DIY videos on putting it all together but if someone offered a service to have everything go to them and be assembled I wouldn't say no.
  • Global Loveinator
« Reply #33 on: Fri, 14 December 2012, 13:02:42 »
can we get a matte royal purple pcb color? :D
Offline Shadovved
« Reply #34 on: Fri, 14 December 2012, 13:03:23 »
Baby/hot pink please!  :p :p
« Reply #35 on: Fri, 14 December 2012, 13:03:39 »
lol been working on that and already have received some pms from people on this topic
Offline nebo
« Reply #36 on: Fri, 14 December 2012, 13:10:03 »
You are a gentleman and a scholar. I think this might be my best chance to get a winkeyless board w/ergo clears.
« Reply #37 on: Fri, 14 December 2012, 13:18:56 »
yea could definitly do that send me a pm when you get a chance.
« Reply #38 on: Fri, 14 December 2012, 13:19:39 »
Also i think this GB should have different color PCBs personally to set it a bit apart from the first.
Offline nebo
« Reply #39 on: Fri, 14 December 2012, 13:24:57 »
White PCB is where it's at, so underdone.
[IC] Phantom PCB
« Reply #40 on: Fri, 14 December 2012, 13:28:25 »
Definitely interested in one of these!
« Reply #41 on: Fri, 14 December 2012, 13:28:33 »
white would be cool the reverse phantom
Offline kmiller8
« Reply #42 on: Fri, 14 December 2012, 13:30:53 »
Offline MMB
« Reply #43 on: Fri, 14 December 2012, 13:31:02 »
I dont think an IC is even needed. I am pretty sure you won't have an issue getting orders.
In.
Offline aggiejy
« Reply #44 on: Fri, 14 December 2012, 13:32:55 »
I'm in for one too!
Offline Sai
« Reply #45 on: Fri, 14 December 2012, 13:33:50 »
umm. i can't resist. i am in as well.
Offline esoomenona
  • Gnillort?
« Reply #46 on: Fri, 14 December 2012, 13:41:03 »
Yes, please.
« Reply #47 on: Fri, 14 December 2012, 13:43:54 »
if its a different color i want one to build into a black PLU case.
Offline SmallFry
« Reply #48 on: Fri, 14 December 2012, 13:59:13 »
I've gotten my Phantom for around $100, total. $300 is way overshooting, IMO.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #49 on: Fri, 14 December 2012, 14:03:05 »
Consider me interested.
