Have you read the geekhack TOS lately?
Aww yeah boy...84 key black LZ is mine!
Was I the only one that went 86 red D:
Quote from: KuhnTang on Fri, 25 January 2013, 12:28:53do you need special keys for the 86 or the 84?I think the only special caps in a sense are the modifiers. They aren't the typical 1.25 size. I think the 84 is 1.5x only with 7x spacebar and the 86 is 1.5x and 1x with 7x spacebar. A tsangan kit would fix you up for the right caps I believe.
This going to be 1:30 forum time, or what ever clock boost is looking at?
Quote from: AKIMbO on Fri, 25 January 2013, 12:30:34Aww yeah boy...84 key black LZ is mine!Same here!
Quote from: phetto on Fri, 25 January 2013, 12:31:30Quote from: AKIMbO on Fri, 25 January 2013, 12:30:34Aww yeah boy...84 key black LZ is mine!Same here! I was going to spring for that one but both of my Phantoms will be in black CM QFR cases so went for metal gun. Might try and source a new anodizing color down the road anyways with toxic in mind.I wonder if we'll see an order page. It also looked like people could order more than one?
I think I had a pretty good refresh on that one, hit it right as it went up.
boost: how many so far?
Actually boost can I change mine to a 84 black!
I just can't justify getting this and a Phantom
Quote from: iArson on Fri, 25 January 2013, 12:42:03Actually boost can I change mine to a 84 black! done!
Oh Good, That Means Being At An Airport On My Phone Didn't Cost Me A Keyboard. 84 Red RepresentThis Is Totally Getting Klaxon Caps
86 in black
Quote from: iArson on Fri, 25 January 2013, 12:39:2986 in black "brofist"
Quote from: Germiphene on Fri, 25 January 2013, 12:46:06Quote from: iArson on Fri, 25 January 2013, 12:39:2986 in black "brofist" I just changed it to 84. No backsies.
Order List:BoostverbhalreaperAcetrakekw808Patchworksturkishrambor3dxjdcarpeDanielucfphettoemptythecacheAtakpAKIMbOKabuksmegaforce93LeeweiGermipheneKuhnTangMetalliqaz WhiteFireDragonpasphjcrousehoggyBimGaoTheProfosistCaaaarrrtBatmanntjcaustinIArson DanGWanG
Quote from: tjcaustin on Fri, 25 January 2013, 12:44:40Oh Good, That Means Being At An Airport On My Phone Didn't Cost Me A Keyboard. 84 Red RepresentThis Is Totally Getting Klaxon CapsApparently it does cause you to Camel Case your sentences tho...
Quote from: iArson on Fri, 25 January 2013, 12:39:2986 in black "brofist" -edit- you changed, lol! I USE MY WINDOWS KEY!! does no one else?
What are the diodes for these like when it comes to soldering? Wires through the board or the difficult ones that nearly require a hot air gun?
