Author Topic: Post your GH60!  (Read 120666 times)
Post your GH60!
« on: Mon, 28 January 2013, 12:40:56 »
Finished my prototype build today. Ordered a 1.5-mod stainless steel plate from The_Beast, sanded it, and painted it satin black. Installed it with Cherry plate mount stabs and PCB mount browns in a jdcarpurple treble318 alu case. Added Cherry black on beige keycaps. Here is the end result.
Offline alaricljs
  • I be WOT'ing all day...
Re: Post your GH60!
« Reply #1 on: Mon, 28 January 2013, 12:45:43 »
Show off :P
Nice tho.
Filco w/ Imsto thick PBT
Offline DanGWanG
  • Higher Standards
    • DanGWanG's Keyboard Blog
Re: Post your GH60!
« Reply #2 on: Mon, 28 January 2013, 12:46:20 »
Love that purple color
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
Re: Post your GH60!
« Reply #3 on: Mon, 28 January 2013, 12:54:43 »
Nice keyboard!!!! I WANT ONE TOO :(
-Enzo Ferrari
Offline SmallFry
Re: Post your GH60!
« Reply #4 on: Mon, 28 January 2013, 13:23:08 »
I like... I like. Looks nice JDCarpe. Is your favorite color purple?
Offline The_Beast
  • I like wood ಠ_๏
Re: Post your GH60!
« Reply #5 on: Mon, 28 January 2013, 13:27:52 »
The hates
I haz them
Offline Acetrak
  • ssk.ℜ
  • gnawm_
Re: Post your GH60!
« Reply #6 on: Mon, 28 January 2013, 13:30:54 »
Pretty rad! Nice work jdcarpe :)
Surprised you didn't go for the short right shift you've mentioned a couple times, I'm assuming this is because no plates with that layout are available yet?
Offline Rinsaku
  • lorem ipsum
Post your GH60!
« Reply #7 on: Mon, 28 January 2013, 13:34:02 »
Awesome job! I really like that purple case! With this case and the toxic set it would be unstoppable. Good work!
Current Boards : Apple m0116 (Salmon Alps), B.Face (Mx Clears), Filco Tkl (Mx Blues), HHKB Pro JP (Topre), Jd45 (78g Zealios), KBParadise v60 (Gateron Yellows), KBParadise v60 (Matias Quiet Click), Kbt Pure (Kailh Bronze), Leopold FC660M (Mx Browns), Minidox (Mod-H), Pok3r (62g Zealios)
Re: Post your GH60!
« Reply #8 on: Mon, 28 January 2013, 14:00:20 »
Once the production boards are made, I'll be using the HHKB layout, most likely. I just wanted to get a quick and dirty plate on this, so I didn't have to deal with PCB flex anymore. The plate design is not perfect for this prototype board, but it works well enough for its intended purpose. There are 11 switches in this layout that are rotated 90 degrees. The switches fit into the holes in the plate, and mount to the PCB just fine, but the holes for the switch housing pins which allow you to open the switch without desoldering it are on the wrong sides of the switch. I don't often need to open my switches to swap springs/stems, so it's not a big deal to me for this prototype board.
Bottom line: it looks good, and the PCB flex is eliminated.
Offline Viz
Re: Post your GH60!
« Reply #9 on: Mon, 28 January 2013, 14:56:11 »
Damn JD, that looks sweet as hell.
Great to see what komar and the rest of the crew has accomplished!
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
Re: Post your GH60!
« Reply #10 on: Mon, 28 January 2013, 16:19:00 »
Want this soooooo bad.
Re: Post your GH60!
« Reply #11 on: Mon, 28 January 2013, 16:20:07 »
Agreed. I'm thinking more and more that this will be my first 60% board and my first foray DIY boards.
Offline The_Beast
  • I like wood ಠ_๏
Re: Post your GH60!
« Reply #12 on: Mon, 28 January 2013, 16:20:46 »
You'll love both bro
Re: Post your GH60!
« Reply #13 on: Mon, 28 January 2013, 16:27:32 »
It's the beginning of the end isn't it? First the GH60, then I'm elbow deep in a KMAC, then I become Profosist-esque. Just a beast at soldering and assembling boards.  :p
Offline The_Beast
  • I like wood ಠ_๏
Re: Post your GH60!
« Reply #14 on: Mon, 28 January 2013, 16:28:26 »
Depends, you may like the GH60 so much, you may stop looking for boards all together
or run out of money
Offline Jupiter
Re: Post your GH60!
« Reply #15 on: Mon, 28 January 2013, 17:30:07 »
Does anyone know if a price has been mentioned for the GH60? I'm eagerly awaiting the Phantom round 2 and this is looking might fine and extremely tempting :P
(Going to be) building Phantom - Red MDPC / White Heatshrink Pexon Cable - WoR/RoW Klaxon - Shiny Titanium Spacebar - Titanium Zerg key
Post your GH60!
« Reply #16 on: Mon, 28 January 2013, 17:35:00 »
The GB will probably begin in a few weeks. Price should be comparable to Phantom.
Offline Jupiter
Re: Post your GH60!
« Reply #17 on: Mon, 28 January 2013, 19:36:06 »
Ahhh cool. Might just grab the PCB and controller when I can and try to save my wallet for now by gettin the rest later.
Re: Post your GH60!
« Reply #18 on: Mon, 28 January 2013, 19:38:21 »
Yeah, understandable. FWIW, the controller and SMD diodes/components will be pre-soldered to the board at the fab, so no need to worry on that front. Just need some PCB mount switches and someone's spare stock Poker case, and you're GTG.
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
Re: Post your GH60!
« Reply #19 on: Mon, 28 January 2013, 20:34:10 »
GH60 with plate and case? so jealous of that.
though i may end up loving the ergodox more, my poker is my favorite keyboard now, even more than the HHKB, i don't use anything else. I just wish i had a plate and case; might as well wait til GH60.
i want to make a MX-HHKB, maybe even we can get a HHKB plate made :D perfect travel board for my extended trips.
Post your GH60!
« Reply #20 on: Mon, 28 January 2013, 20:36:35 »
Have you seen WFD's alu case and integrated plate? HHKB layout will be an option with that case.
Offline Jupiter
Re: Post your GH60!
« Reply #21 on: Mon, 28 January 2013, 20:48:15 »
Oh even better! I really need to read through more of the GH60 threads hahaha
Offline Glod
    • YouTube Channel
Re: Post your GH60!
« Reply #22 on: Mon, 28 January 2013, 20:57:50 »
i saw, my wallet is ready :)
Offline daerid
    • Rossipedia
Re: Post your GH60!
« Reply #23 on: Tue, 29 January 2013, 02:02:14 »
I love how nobody else has posted their GH60's
Offline tipo33
  • "Ski"
Re: Post your GH60!
« Reply #24 on: Tue, 29 January 2013, 03:21:38 »
I still neet to assemble mine...
KM4COL    R.I.P.  SmallFry
Offline phetto
  • HHKB JP
Re: Post your GH60!
« Reply #25 on: Tue, 29 January 2013, 11:47:08 »
dirge should post his!
Re: Post your GH60!
« Reply #26 on: Tue, 29 January 2013, 11:51:03 »
^ Agree. dirge built a GH60 with ISO layout that looks really nice. He used some handmade blocks to cover the winkey positions, which to me is a cool idea.
Offline WhiteFireDragon
    • youtube
Re: Post your GH60!
« Reply #27 on: Tue, 29 January 2013, 12:09:21 »
This thread will just be a discussion thread for a while. Very few have a GH60 prototype right now. Only a handful of people  ^-^
« Last Edit: Tue, 29 January 2013, 12:12:44 by WhiteFireDragon »
Offline dirge
Re: Post your GH60!
« Reply #28 on: Tue, 29 January 2013, 13:14:10 »
Just seen this thread, love the gh60, MASSIVE thanks to komar.  Mate you're a ****ing legend.  Owe you a drink!
Used http://www.ebay.co.uk/itm/180724932018 leather spray to colour the case.  Dries in 15mins, I'm quite happy with the stuff.  Can't say how durable etc but its made for spraying on leather shoes to change their colour, so must be a little durable.
The windows keys were made by taking two pcb mount switches and removing the tops, the gold contacts and using some flush cutters to remove the plastic from around the top.  Then some squares of acrylic also sprayed.
Cherry sticker to finish off and it doesn't look too bad.  It's got blue switches with o-rings and switch stickers.
Also thanks to mm87 for the new case, I'll be using it when the groupbuy board drops in :) also the The_Beast who's been real helpful!
jdcarpe, very nice! no unicorn vomit! classy :) (we need to get you a shift mind bud)
Thinking about things isn't the same as doing things. Otherwise everybody would be in jail.
Offline The_Beast
  • I like wood ಠ_๏
Re: Post your GH60!
« Reply #29 on: Tue, 29 January 2013, 13:16:34 »
What did I do again? lol
    • youtube
Re: Post your GH60!
« Reply #30 on: Tue, 29 January 2013, 13:43:35 »
Great mod dirge! 1.5x Winkeyless ISO is very unique.
Offline alaricljs
Re: Post your GH60!
« Reply #31 on: Tue, 29 January 2013, 13:47:16 »
You did the dishes... er, plates!
Offline jeroplane
Re: Post your GH60!
« Reply #32 on: Tue, 29 January 2013, 18:29:56 »
Oh wow, amazing mod dirge. That has to be the first 60% ISO board, let alone Winkeyless! Classy as hell.
My signature hasn't changed since 2012. I should really update it.
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Post your GH60!
« Reply #33 on: Tue, 29 January 2013, 19:29:40 »
Apple beat dirge by almost 30 years lol as there are some versions of the Mac 128k keyboard in ISO. Definitely a nice build though dirge, top notch.
Though I am not sure if that was the first either, but certainly much before.
I can't wait to get my GH60 finished, as soon as WFD finishes up all those pesky diodes for me.
Offline jeroplane
Re: Post your GH60!
« Reply #34 on: Tue, 29 January 2013, 19:33:59 »
That's a cute little keyboard. Well dirge's can be the first modern 60% ISO WKL board :)
Offline dirge
Re: Post your GH60!
« Reply #35 on: Wed, 30 January 2013, 05:28:41 »
Thanks very much guys :)
I've had an eBay watch on those apple boards for ages now. They don't come up often and are expensive...
Offline akuJIWA
  • Lock 'N Load!
Re: Post your GH60!
« Reply #36 on: Wed, 30 January 2013, 05:33:30 »
Looks great! :)
The Cheat - B/R/B ; Clear switch with 62g springs
quit
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
Re: Post your GH60!
« Reply #37 on: Wed, 30 January 2013, 20:55:44 »
Teaser!
It took me 5 days, two donor boards, and three soldering irons. But all this mess, was for something!!!
Re: Post your GH60!
« Reply #38 on: Wed, 30 January 2013, 20:58:11 »
Dirge...I think that's the first ISO layout board I've really like. That's real sharp. Is that a WYSE keycap set?
Offline The_Beast
  • I like wood ಠ_๏
Re: Post your GH60!
« Reply #39 on: Wed, 30 January 2013, 21:23:02 »
I've always thought ISO looked dumb, but damn that one looks great. Would there be a way to have ISO but a longer left shift like a ANSI board?
Offline kmiller8
Re: Post your GH60!
« Reply #40 on: Wed, 30 January 2013, 21:34:09 »
K done with pics, I shall call it.... The Das60
Yes the GH60 is sitting ontop of my Das in the first pic :))
also, DEM GHETTO KEYS. Someone used plate mount switches without a plate :x
Offline alaricljs
Re: Post your GH60!
« Reply #41 on: Wed, 30 January 2013, 21:34:40 »
for those that have no windows key ... how do you navigate to the 2nd layer?  How is your 2nd layer set up?
CapsLock key!!
Re: Post your GH60!
« Reply #42 on: Wed, 30 January 2013, 21:49:05 »
You mean like Cherry POS boards?
I don't see why not, the pcb mount options are possible.
Offline TheQsanity
  • SmallFry Lovin'
Re: Post your GH60!
« Reply #43 on: Wed, 30 January 2013, 22:23:51 »
Cant be that bad, can it?
Nice Das btw.
SmallFry! <3
Offline The_Beast
  • I like wood ಠ_๏
Re: Post your GH60!
« Reply #44 on: Wed, 30 January 2013, 22:25:34 »
That would be perfect. I almost never use the \| key
Offline dirge
Re: Post your GH60!
« Reply #45 on: Thu, 31 January 2013, 03:24:53 »
Authentic Cherry set mate.  Doubleshot, didn't break the dyesubs out yet  :cool:
Offline komar007
    • komar's blog
Re: Post your GH60!
« Reply #46 on: Thu, 31 January 2013, 05:42:35 »
No fancy stuff here (except for imsto's thick PBTs, of course). I can't prove its not a poker. You have to believe it's GH60 next to a prototype of the upcoming GHPad;)
12702-0
« Last Edit: Thu, 31 January 2013, 05:50:06 by komar007 »
Offline ishumprod
Re: Post your GH60!
« Reply #47 on: Thu, 31 January 2013, 05:52:10 »
wow. i love the color scheme and the layout.. i mean it :)
where did you get that set ?
( btw nice board )
home-made TKL rubber dome keyboard !
Offline akuJIWA
  • Lock 'N Load!
Re: Post your GH60!
« Reply #48 on: Thu, 31 January 2013, 06:01:16 »
( btw nice board )
Looks like imsto. :p
quit
Offline komar007
    • komar's blog
Re: Post your GH60!
« Reply #49 on: Thu, 31 January 2013, 06:02:03 »
Thanks, I bought it from imsto.
EDIT: too late.
