Author Topic: Halverson's Poker Lego Case!  (Read 20345 times)
« on: Wed, 13 February 2013, 19:46:54 »
Hey everyone! So it was awhile ago I posted a picture of a poker in a Lego case. Well, more of a tray, like a normal poker case. So here is the thread finally, to explain some details about it, and hopefully answer any questions!
So it all began with some talk with a friend, and I decided to take some measurements. For some reason I threw all this out, but it's not too important at this point. Looking online I found measurements of the thin 1x4 Lego blocks, and just did some calculations to see how many I would need.
I never took a step-by-step picture guide, but it's pretty simple.
First, I'll start with the order list.
The main components are the thin 1x4 plates.
The other main component were 6 6x12 plates.
To make sure everything fit without any odd ends, added some 1x2 plates as well, and 1x1 was used near the opening for the USB.
The plate tiles, which are flat on top, were just to make the top of the case smooth.
The normal 1x4 bricks were used inside for support under the PCB.
The corners were made with the 1x1 circle plates.
I had a plan with the technic bricks and connector pegs to have the pcb connected to the case, but didn't feel like glueing lego to my pcb.
My list does have extras, but it never hurts to have too much versus too little. This is what you need for a case:
240 1x4 plates
25 1x4 flat tiles
20 1x1 plates(20 more if you want to use these in the corners instead of round plates)
20 1x1 flat tiles
6 6x12 plates
20-40 1x1 round plates(optional, can use 1x1 plates instead)
10 1x4 bricks(if you would rather the case on an angle instead of the pcb, double the order of these)
And it doesn't hurt to get at least 10 of some 1x2 bricks and 2x2 bricks.
My list in the picture has more items due to me getting random things, and instead of a solid colour, I did the red/blue theme.
Now onto some horrible photos!
Version 1!
Rectangle case, random pieces of normal lego height for support. Case was ever so slightly too small from from to back, but two folded pieces of paper held it in place perfect.
As you can see in the last one, I added the extra two rows on the back to angle the case, more could be used to tilt it more.
USB hole, not centred, but works fine.
Support bricks. Spaced in a way to avoid hitting the DIP switch or anything inside. Used the random bricks I had because I had no more 1x4, which I would recommend getting more.
Speaking of dip switch, didn't bother making a hole in the bottom for it, since you can just pop the pcb out to change it.
Just showing what I used in the corners, little pillars!
Bottom of the case. I made a layer on the bottom of the case to strengthen the connections of the above plates, and overall sturdiness. Also, the big plates need one ring of 1x4 plates on the outside for the correct poker size. So I connected them together underneath to keep the top flat.
And on Version 2 I had spare 1x4 plates, so I added more on the green parts of the bottom.
Version 2!
I didn't get many pictures of this one, but I think I prefer it much more, makes the front end much lower.
First, I changed the pcb support to 3 rows of lowering heights.
Had to change the USB hole to one plate higher.
I tapered the sides into 3 layers to make it more even with the pcb.
And for fun, I used two 1x2 flat keyboard tiles. Keyboard on a keyboard.
I guess last but not least, a quick note on the build method.
1-Line up the 6 big plates
2-Connect them underneath with either 1x2 or 1x4 plates
3-Make a ring around the plates with one row of 1x4 plates
4-Connect those to the big plates on the bottom
5-Add 1x4 plates and 1x2 plates around the perimeter in your desired fashion!
6-Don't forget to leave a hole for the USB plug at the back!
Depending on how you want to alternate the blocks, you can do almost anything. If you really wanted, you can just get even longer plates to save the hassle of having lots of little ones.
The actual measurement in lego bumps or 1x pieces for the entire case. 14 wide by 38 wide!
Hope this is somewhat useful for anyone wanting to build their own case! Would be nice to see what other people could design, heck a TKL would be pretty sweet! Even one with a top to sandwich the pcb into place.
Any comments or questions, post away! If need be, I can take more photos, hopefully better ones!
Cheers,
Halverson!
PS-Taking apart 1x4 plates from each other is all sorts of frustrating!
Oh, and if anyone wants to know...that is original dolch with a moogle kit, and the switches are dirty blacks, black springs with brown switches....kind of comparable to browns vs reds, in that they feel almost the same, but that little bump in there.
« Last Edit: Wed, 13 February 2013, 21:44:00 by Halverson »
Re: Halverson's Poker Lego Case!
« Reply #1 on: Wed, 13 February 2013, 19:47:17 »
Ugh, those are brutal photos. I'll get some better ones I promise!
« Reply #2 on: Wed, 13 February 2013, 19:49:29 »
Is it wrong to say I think I love you Halverson? This case looks amazing and I'm happy you documented the process. Next you need to spell "Halvy" in the side with bricks
And I'm loving the keyboard-ception. Keyboard on keyboard on lego :P
« Reply #3 on: Wed, 13 February 2013, 19:52:03 »
:D
Oh and I prefer Version 2 if anyone is wondering! If feels more sturdy, doesn't want to budge at all.
I think if I had a plate on this poker, would make it even better!
Offline YoungMichael88
  • HHKB Wannabe
« Reply #4 on: Wed, 13 February 2013, 19:59:13 »
It looks great! Version two is definitely an improvement. I'm thinking about trying to adopt this technique for a Phantom case in the future.
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #5 on: Wed, 13 February 2013, 20:08:22 »
What an awesome idea!
Offline bavman
« Reply #6 on: Wed, 13 February 2013, 21:40:59 »
How did you get all those legos for free?
It can get a little pricey when ordering a lot of them
« Reply #7 on: Wed, 13 February 2013, 21:42:36 »
Hah, was not free! That was just the order list, there was another page I must have tossed out with the cost. I think I paid between $50 and $60 shipped. Definitely not cheap, but meh, neither are keyboards!
Offline bavman
« Reply #8 on: Wed, 13 February 2013, 21:49:09 »
Haha makes sense.
I guess thats too terrible then. I just remembered looking there a long time ago and pieces were like .2-.5 each, and I saw you had 180 of one of the pieces.
Offline phetto
  • HHKB JP
« Reply #9 on: Wed, 13 February 2013, 21:50:45 »
holy **** this is nice.. Less dolch more pride colored keycaps! :D
Offline TheQsanity
  • SmallFry Lovin'
« Reply #10 on: Thu, 14 February 2013, 00:53:48 »
OMFG! This is too much to ****ing take in!!!
I think it is time to steal back my donated Legos...
SmallFry! <3
Offline simkev
« Reply #11 on: Thu, 14 February 2013, 16:40:26 »
Nice case but whats up with your spacebar?
JAG ÄR LIVRÄDD FÖR ATT LEVA & JAG ÄR DÖDSRÄDD FÖR ATT DÖ
| Poker X - Ergo Clears & Red Alert 2.0 | Majestouch 2 TKL - Browns & Blue Cream Cheese |
Offline Jocelyn
  • 조셀린
Re: Re: Halverson's Poker Lego Case!
« Reply #12 on: Thu, 14 February 2013, 16:45:19 »
lol, pretty sure it's just flipped :)
Offline Jupiter
« Reply #13 on: Thu, 14 February 2013, 17:17:19 »
Looks amazing! If I had any sort of spare cash I would definitely try this out, but the Phantom and Klaxon took care of that :P
(Going to be) building Phantom - Red MDPC / White Heatshrink Pexon Cable - WoR/RoW Klaxon - Shiny Titanium Spacebar - Titanium Zerg key
« Reply #14 on: Thu, 14 February 2013, 17:49:39 »
Oh I love da flipped! I be all upside down! :D
  • HHKB Wannabe
« Reply #15 on: Sat, 16 February 2013, 10:42:21 »
Boooo to flipped spacebars!!!
Offline precarious
  • LOOK MOM, I'M A DRAGONZORD! DOOOO DODOODODODOODOO
« Reply #16 on: Sat, 16 February 2013, 11:24:54 »
that is amazing, nice job!
Offline gnubag
« Reply #17 on: Sat, 16 February 2013, 13:19:14 »
Do you have the measurements of the poker pcb?
I am thinking of a super lowbudget case. :)
Offline inteli722
« Reply #18 on: Sat, 16 February 2013, 13:20:55 »
Whats wrong with flipped spacebars?
Waiting for: Phantom Plate
  • HHKB Wannabe
« Reply #19 on: Sat, 16 February 2013, 14:28:36 »
Nothing, I just bug Halverson about it for laughs. They're fine.
« Reply #20 on: Sat, 16 February 2013, 15:42:19 »
I only ever took case measurements. If you'd like I can take some pcb measurements later.
Offline remedyhalopc
« Reply #21 on: Mon, 18 February 2013, 12:09:03 »
How much did this cost? Can you use a plate with it?
« Reply #22 on: Mon, 18 February 2013, 12:42:52 »
About $50-$60 shipped. And if your poker had a plate, I see no reason why it wouldn't work. I could only imagine it would make it more sturdy overall.
Offline fydo
  • Meow!
« Reply #23 on: Tue, 19 February 2013, 18:57:22 »
Awesome idea! I did some messing around in LEGO Digital Designer and somewhat recreated your case in a 2-tone grey theme. I was able to do this because of your excellent instructions. Some of the positions of the supports were hard to tell in your photos, but those are easy to adjust.
I was aiming for a shorter assemble time so I used larger pieces rather than lots and lots of 1x4 pieces. I don't know if any of the piece sizes and colors I chose are rare/expensive, so that may be an issue. :)
Here's the bottom:
If anyone wants to play around with it, here's a link to the file: http://fydo.net/misc/PokerCase-v3.lxf
Bonus points if you can make decent looking access to the dipswitches! :D
2018 Edit: Fixed broken links!
« Last Edit: Thu, 28 June 2018, 14:34:42 by fydo »
CoolerMaster Quickfire Rapid | Ducky Shine II (White LED)
Offline domoaligato
« Reply #24 on: Mon, 01 April 2013, 23:01:48 »
I just used this lego designer plan and exported the list of bricks.
After a few minutes on pick a brick the total is about $33.90 USD(before shipping+tax) for a lego poker case.
thanks for your lego designer file!
I will post pics when I receive the lego bricks in about 15 days.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #25 on: Tue, 02 April 2013, 16:45:16 »
I can't wait to see the results!
« Reply #26 on: Tue, 02 April 2013, 16:45:57 »
Completely forgot about this thread! Glad to see people are advancing it! Can't wait to see how others build theirs :D
Offline osxoep
« Reply #27 on: Tue, 02 April 2013, 16:48:48 »
This is so cool. I'm going to try this out for my GH60.
To LDD!
HHKB Pro JP with hasu's controller (waiting for MX sliders)
Offline domoaligato
« Reply #28 on: Tue, 02 April 2013, 17:04:24 »
I replaced the larger black plates that go inside the bottom with some green ones.
the green ones were .70 usd each
the black ones were 3.00 usd each
I also picked all black pieces instead of the two toned look in the lego designer file.
when I get the parts I will post the list.
I would have done it last night but once you add the parts to the shopping cart the list is gone.
Offline fydo
  • Meow!
« Reply #29 on: Tue, 02 April 2013, 19:37:27 »
Awesome! Great to hear that you guys are making use of that LDD file. Please post any corrections. :)
I don't actually have my Poker PCB yet, so I built it all based on Halverson's excellent build tutorial.
I'm pretty excited to see the case built in "real life"! :D
« Reply #30 on: Wed, 12 June 2013, 13:57:06 »
How am I just now knowing this existed!  :o
Offline domoaligato
« Reply #31 on: Wed, 12 June 2013, 14:17:08 »
I already got all my legos and assembled it. I do not have a poker atm and I am waiting on my gh60's to use the case.
I wanted to make sure that everything it fitting perfectly before I posted pictures.
would you like to see a few pic's before I receive a pcb to mount it in the case?
« Reply #32 on: Wed, 12 June 2013, 14:21:39 »
YES!
and a parts list if you have it available!!
Offline domoaligato
« Reply #33 on: Wed, 12 June 2013, 14:47:51 »
I get off work in a few hours and I will try to track down that parts list I received and take a few pics.
keep in mind I have to get a pcb to determine where to put the standoff's to mount the pcb in the case.
Offline linziyi
  • The one with many questions
« Reply #34 on: Wed, 12 June 2013, 14:53:12 »
 :confused: The lego keyboards are in ISO though!
Ducky DK9008G2 Pro
"Much to learn you still have" --Yoda
Offline domoaligato
« Reply #35 on: Wed, 12 June 2013, 17:01:28 »
what do you mean?
this is a tray style case made from legos.
do you have a link to a iso keyboard made with legos?
Offline linziyi
« Reply #36 on: Wed, 12 June 2013, 17:09:37 »
what do you mean?
http://i.imgur.com/RHY5IGL.jpg <--- iso layout  :blank:
Ducky DK9008G2 Pro
Offline domoaligato
« Reply #37 on: Wed, 12 June 2013, 17:36:01 »
oh lol. he has iso lego bricks in the front but a ansi keyboard in the case. :)
mine will be case only until I receive my gh60.
« Reply #38 on: Wed, 12 June 2013, 18:34:45 »
Hehe, well the case is compatible with both. I just wanted to go crazy and against the grain :p
Offline germy
« Reply #39 on: Wed, 12 June 2013, 19:05:13 »
Ooh going to go out and buy some lego bricks to try building my own.
Offline domoaligato
« Reply #40 on: Wed, 12 June 2013, 20:12:18 »
please ignore my unicorn throwup qfr in the background  :p
« Reply #41 on: Wed, 12 June 2013, 20:42:56 »
That is awesome!
Offline domoaligato
« Reply #42 on: Wed, 12 June 2013, 21:23:34 »
I can not find the parts list and my lego.com order history only shows the total amount of the order and not the actual parts list.
I have emailed lego and when they reply I will post the parts list here.
Offline fydo
  • Meow!
« Reply #43 on: Wed, 12 June 2013, 21:42:12 »
Wow! That looks awesome! Thanks for sharing, domo!
Offline domoaligato
« Reply #44 on: Wed, 12 June 2013, 22:47:20 »
no problem! I can't wait until I can get a keyboard in it!
my alps 60% board fits in it but until I can get the firmware finished I am not really going to play with it much.
Offline domoaligato
« Reply #45 on: Thu, 13 June 2013, 16:51:39 »
ok here is the list of parts I had ordered.
Pick a brick did not have some of the 1x12 bricks that were in the lego designer file so I had used 2 1x6 plates to = 1x12 plate.
download the lego designer file that fydo created (I have attached it to this post in case he removes it from his dropbox.)
* fydo-PokerCase-v1.lxf
When you open the file in the lego designer choose the build instructions open and it will show you how to assemble it.
   Qty  Item No.     Element ID
3  FLAT TILE 1X4    243126
7  BRICK 1X16       246526
7  BRICK 1X6        300926
4  PLATE 1X2        302326
2  PLATE 1X8        346026
2  PLATE 1X4        371026
2  PLATE 2X10       383226
5  PLATE 4X4        4243819
2  PLATE 1X10       447726
1  BRICK 1X12       611226
3  FLAT TILE 1X6    663626
4  PLATE 2X12       244526
1  BRICK 1X2        300426
3  BRICK 1X4        301026
2  PLATE 2X8        303426
16  PLATE 1X6        366626
2  PLATE 2X6        379526
8  FLAT TILE 1X8    416226
6  PLATE 6X12       4256149
2  ROOF TILE 1X4X1  4515362
« Reply #46 on: Thu, 13 June 2013, 16:57:57 »
So, I'm thinking I may have to kick it up a notch and try to design one for my phantom. Whenever I get it and build it that is! But would be quite the feat I think. Not a tray, but a case that accommodates the plate and sandwiches it in place.
« Reply #47 on: Thu, 13 June 2013, 16:59:38 »
7  BRICK 1X16       246526
7  BRICK 1X6        300926
4  PLATE 1X2        302326
2  PLATE 1X8        346026
2  PLATE 1X4        371026
2  PLATE 2X10       383226
5  PLATE 4X4        4243819
2  PLATE 1X10       447726
1  BRICK 1X12       611226
4  PLATE 2X12       244526
1  BRICK 1X2        300426
3  BRICK 1X4        301026
2  PLATE 2X8        303426
16  PLATE 1X6        366626
2  PLATE 2X6        379526
Very awesome! Thanks!!
Offline domoaligato
« Reply #48 on: Thu, 13 June 2013, 17:25:02 »
Lego plates are 3.2mm tall, how thick are the phantom plates? Aren't they 1.5mm thick?
If the phantom plate is to thin you could attach weather striping or something to the outer edge of the phantom plate to make sure that it does not bounce within the extra 1.7mm of extra space.
« Last Edit: Thu, 13 June 2013, 17:27:11 by domoaligato »
Offline Grim Fandango
« Reply #49 on: Thu, 13 June 2013, 17:27:11 »
This is pretty funny. Nice man, looks great actually.
