Have you read the geekhack TOS lately?
It says login failed.
I just checked, and I'm getting the same error. Can't log in either :/. This is really stupid, requiring a log in to use it. Sherry needs to bring this up to them to remove the log in crap.
Already thought of that. C:\KMAC. What does the checkbox say? It doesn't seem to make a difference but I'd like to know.
If you press the key on your kmac the diagram of the keyboard in the kmac hex file making program will light up red the key you are pressing.
Yes, that's the one from post 2.
Is that the "unknown device"? If yes, I cannot do the next step. Any different way to update?Thanks
I get stuck in this step, cannot find "ATMEGA device"7. (only the first time) Go to device manager and find ATMEGA device with no driverShow ImageIs that the "unknown device"? If yes, I cannot do the next step. Any different way to update?Thanks
So... umm, I just installed windows 8. I also realized that Flip does not have a USB driver or windows 8. Anyone know a way around this?Thanks,-Tad
I'm here.
Can anyone tell how to create a macro. or tell me the lines to set M1 as alt+f4.and is it possible to create a numpad that works like the realforce 87?thanks
