Author Topic: Ducky Shine 78 Review  (Read 14071 times)
Offline Tempest790
« on: Tue, 05 March 2013, 17:47:42 »
My Ducky Shine "78" arrived today, and for the first time, I got to try out some other switches besides buckling spring (my Dad's Unicomp) and my two Ducky Shine I's with Cherry MX Blue.
They keyboard is broken down it appears as follows:
Cherry MX Red - main alphanumeric layout backlit in purple
Cherry MX Black - auxiliary keys around the main keys like the Shift, Ctrl, Enter, Tab, and Spacebar backlit in red
Cherry MX Brown - arrow keys and Home, End, PgUp, PgDn, Ins, Del backlit in orange
Cherry MX Blue - number pad area backlit in blue
Cherry MX Dark Gray - F1 thru F4 backlit in yellow
Cherry MX Clear - F5 thru F8 and PrtSc, ScrLk, Pause backlit in white
Cherry MX Green - F9 thru F12 backlit in green
Cherry MX White - specialty keys in top right (Calc, My Computer, Email, and Internet Home) backlit in yellow
This is my first impression of the switches after using it for a few hours.
1.   Red
   a. Feel – light, smooth, and real joy to use
   b. Sound – quiet, almost no “spring noise”, and easy to bottom out with a nice medium plastic striking sound (sounds pretty good to me).
   c. Overall – This was a real surprise, but Red’s are an absolute joy to type on despite my looking for a stiffer switch.  Touch typing is fantastic, and with a little practice, I can very easily increase my speed with these switches.  Great for gaming.  Overall grade (A).
2.   Black
   a. Feel – medium-heavy switch, smooth, but not quite as top notch as the Red’s
   b. Sound – no click of course, but some keys exhibit a “spring noise” sound which doesn’t quite fit unlike buckling springs.  It’s very slightly annoying to me but this is because I’m specifically listening to it.
   c. Overall – Still a practical switch, I found myself liking the Red’s more.  Overall grade (B+)
3.   Brown
   a. Feel – light (on par with the Red’s) with a small tactile bump.
   b. Sound – the tactile bump seems to give the key a higher pitch than the Red’s.
   c. Overall – Not too impressed with these.  When pressed very fast, they don’t seem too bad, but I don’t really care for them when typing slowly. Overall grade (C)
4.   Blue
   a. Feel – light, medium tactile bump, and high-pitch clicky.  Slightly heavier feel than Brown’s or Red’s (but not much)
   b. Sound – Despite being noisy, I like the Blues.
   c. Overall – I’ve typed on them for over a year now, but now that I can actually compare switches, I don’t have any regrets getting the Blue’s.  Overall grade (B+)
5.   Dark Gray
   a. Feel – Very heavy, linear, they seem to really push back up against your finger.
   b. Sound – very dull, with almost no plastic striking sound.  Probably the quietest of all the switches.
   c. Overall – Umm.  WTH would you use these for?  Even the spacebar would probably be too much.  Great for anyone looking for a really heavy feel from the old typewriter days, but you better have some manly hands!  You won’t accidently press these keys.  Overall grade (D), unless this is what you were specifically looking for.
6.   Clear
   a. Feel – medium-heavy switch with a medium tactile bump.  Heavier spring than the Brown really masks the tactile bump though.
   b. Sound – “spring noise” is even louder than Blacks (which I don’t like).  It’s fairly quiet since it doesn’t bottom out as easy.
   c. Overall – I was really pursuing towards Clears, since I wanted something heavier than my Blues, but Clears really didn’t impress me the way I thought it would.  I do like the stiffness, but the tactile bump feels “wrong” to me for some reason.  Very glad I didn’t buy a keyboard with these.  That said, I could probably get used to them, but it wouldn’t be my first choice.   Overall grade (C+)
7.   Green
   a. Feel – heavier blues, with a nice medium tactile bump that seems more pronounced than the Clear’s.  Once past the tactile bump, seems lighter (which I like).
   b. Sound – Not as high pitched as the Blues (which I also like).  Heavier spring makes bottoming out a little less pronounced which gives this switch a very pleasant sound.
   c. Overall – Very much like these switches.  They have a crisp feel, not quite as high pitch as the Blues, and the tactile bump seems to be very pronounced at the beginning of the key press.  Definitely one of Cherry’s best switches.  Overall grade (A).
8.   White
   a. Feel – very similar to Green’s but the tactile bump is slightly lower in the stroke.  Tactile bump feels more pronounced than the Clear’s but not quite as much as the Green’s.  I think this is what I expected the Clears to be.
   b. Sound – Softer, lower pitch click than the Green’s.  Great compromise on someone who can’t have a clicky board, but would like to hear a very soft, slight click.  Click is lower pitch than either the Blue and the Green, and I think some people might appreciate that.
   c. Overall – Nice feel.  A close second place with the Green switch.  This would be great keyboard for work, since it won’t annoy co-workers as easily as Blues or Greens might.  Overall grade (A-).
Overall keyboard review:
Despite seeming impractical, this is a very good keyboard.  Ducky’s decision to keep most of the light, widely used keys for the keyboard for the main portion of the keyboard makes it very easy to use day by day.  I’ll probably keep this one hooked up to my computer for a while.  The backlighting makes it extremely to find your way around the keyboard in a dark room.  I don’t use the function keys very often, so their different feels really won’t affect my using this keyboard.  If anyone is nervous or on the fence about purchasing this keyboard, as long as you like lighter switches for the main part of your keyboard, I think you will be pleasantly surprised.  The heavier blacks for the spacebar, shift, crtl, etc don’t detract too much from my using the keyboard.  It’ll definitely be a conversation starter.
I really learned some stuff.  It’s amazing how my two favorite switches are linear Red and tactile, clicky Green even though they are about as opposite as you can get.  I was really leaning on getting a Clear board since Green’s are difficult to come by, but I’m glad I didn’t.  That said I would take White switches if I couldn’t get Green’s.
I’m looking to upgrade my Ducky Shine I keyboards, and my just go with Red’s since Green’s are difficult to come by.
Please let me know if you have any questions.  I’ll try and do a video review this weekend if I have the time.
Update:
After using the keyboard more and really getting a feel for the switches I definitely have my favorite switches.  Red and Green take it by far.  Red has such a nice light silky smooth feel to it.  The nice bottom out sound is very nice without being annoying or overly loud.  A true joy to type on.  The Green's are just like typing on an older typewriter which is fantastic.  Cherry really needs to push these switches, especially if someone wants a buckling spring or older stiffer type feel from the electric typewriter days.  The sound and feel go hand in hand to give it that feel.  The only way they could make it more so is to add a vibration feedback like the head striking the paper, but that's probably way overkill (if it ever did happen).  My Dad uses a Unicomp buckling spring board, and he absolutely loves it.  But, I'm pretty sure he would like typing on Cherry Green's as a close second.  I know I do.  I guess I'm going to have to track down keyboards with both switches and keep them for whenever I feel like typing on something different.
« Last Edit: Wed, 06 March 2013, 21:20:36 by Tempest790 »
Offline jabar
Re: Ducky Shine 78 Review
« Reply #1 on: Tue, 05 March 2013, 19:45:05 »
So, finally I can get a true feel for Green vs. White (typing on my 78 board right now). The best analogy:
Greens:Clears::Whites:Browns
Whites have a much duller, softer click than Greens and although they have the same actuation force rating, they feel a bit lighter to operate. I think Greens are much more satisfying just like Clears, but Greens wear my hands out when sustaining keys like during video gaming.
I too am impressed with the usefulness of the board. It's not entirely a gimmick; most activity will be performed on the Red/Black linear switches (Reds being my favorite), and occasionally on the Brown arrow clusters and the Blue numpad. Aesthetically (NB this is my first real backlit board), I do not like the keycaps at all. The smooth ABS feels too slippery and gives me the impression that the keys will wear out fast. The backlit is exceptional: no bleed like on other budget-oriented backlit boards. I am going to give some PBTs and my worn DS ABS keycaps a shot.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline DavinDidIt
« Reply #2 on: Tue, 05 March 2013, 20:03:23 »
I personally love my board.  It finally gave me the chance to try out every Cherry MX switch...and I have to say that this keyboard just oozes quality.  I was concerned with getting a board that had non clicking switches or a dead LED or something, but that didn't happen.
I agree with you Jabar on the ABS keycaps. I can't wait for them to come along with see-through PBT doubleshots... That would really make this board shine (no pun intended)
Even though I'm a total sucker for limited edition items, I'm very happy that I gave this board a shot!
« Last Edit: Tue, 05 March 2013, 20:06:18 by DavinDidIt »
KMAC 2, HHKB
Offline jabar
« Reply #3 on: Wed, 06 March 2013, 18:25:14 »
Davin, just wanted to update you: Ducky made 399 of these boards, up from the original 78. Still, they will be quite elusive once they sell out.
Phantom 7bit
Offline DavinDidIt
« Reply #4 on: Wed, 06 March 2013, 19:48:26 »
You're bringin me down, man!  Do you have a source for that 399 number?
Either way, that doesn't change the fact (too much :P) that I love this board.
KMAC 2, HHKB
Offline Tempest790
« Reply #5 on: Wed, 06 March 2013, 20:30:14 »
I didn't even think to look at the serial number on the bottom.  I have 169 of 399.  At least that makes that easy.
Offline DavinDidIt
« Reply #6 on: Wed, 06 March 2013, 20:53:00 »
Oh. Right.  Just have to turn it over, haha.  I'm #170//399
KMAC 2, HHKB
Offline aggiejy
« Reply #7 on: Wed, 06 March 2013, 21:29:50 »
Thanks for the review! Interesting.
Offline dante
« Reply #8 on: Wed, 06 March 2013, 21:36:23 »
Your review makes me feel like a damn fool for not picking up a Ducky w/ Greens when they were in stock.
Offline Tempest790
« Reply #9 on: Wed, 06 March 2013, 22:06:14 »
You're not alone!  I was broke at the time and lost out on that.  I truly, truly hope another batch gets made.  Ideally, I'd love a backlit one, but I'll even take a regular one.  If CM-Storm ever releases their XT with green switches, I'll probably scoop that up.
Offline DavinDidIt
« Reply #10 on: Wed, 06 March 2013, 23:25:45 »
You guys won't regret it- greens are far and away my favorite switch by Cherry.  Combined with the PBT caps by Ducky, it's phenomenal :)
KMAC 2, HHKB
Offline ShakeR
  • * Commercial Vendor
    • http://mechanicalkeyboards.com
« Reply #11 on: Tue, 12 March 2013, 14:02:36 »
Awesome reviews!
Tempest, Jabar: Would you be up for posting them on our reviews (review tab) here?
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=291
Should be able to copy / paste.  Also, we're still running our $2 for your 2 cents promo, so you'll get a couple dollars back as well ;)
I'm sure many would find them helpful!
Tempest,
Do you mind if I add an article to our site using your review with "Tempest790" as the author?
I agree with almost all of your assessments on the switches. :)
MechanicalKeyboards.com - What do you type on?
Offline Dubsgalore
« Reply #12 on: Tue, 12 March 2013, 15:22:10 »
1.   Red
2.   Black
3.   Brown
4.   Blue
5.   Dark Gray
6.   Clear
7.   Green
8.   White
Update:
are we going to get pics?
Offline Tempest790
« Reply #13 on: Tue, 12 March 2013, 16:29:09 »
Awesome reviews!
Tempest,
That's fine.  Thanks!
I submitted the review to the site too.
@Dubsgalore
I tried posting pics but it didn't come through.  I may not have enough posts or something.
Here's a link to a photo I took with the Ultimate Tester Tour Keyboard and the Ducky 78 next to each other.  I swapped out the Enter keys with the Ducky gray keycaps for now.
http://www.flickr.com/photos/93881582@N07/8539329875/
« Last Edit: Tue, 12 March 2013, 16:34:54 by Tempest790 »
Offline jabar
« Reply #14 on: Tue, 12 March 2013, 22:11:02 »
Swapped caps with new ones that arrived today. Great texture & overall feel of PBT. Can't wait til Ducky releases their thick PBT boards.
Phantom 7bit
Offline DavinDidIt
« Reply #15 on: Tue, 12 March 2013, 22:14:47 »
That looks phenomenal, Jabar
KMAC 2, HHKB
Offline Tempest790
« Reply #16 on: Tue, 12 March 2013, 22:30:00 »
I really like that!  Gives it kind of a surreal look.  Especially the blue led's in the shadow.
Offline ShakeR
« Reply #17 on: Fri, 15 March 2013, 11:11:04 »
Wow, that's awesome.
Offline deazncy
« Reply #18 on: Fri, 22 March 2013, 01:05:23 »
Now that's one handsome kb. The keyboard is too everywhere for me, though. Too many colors haha
“Do not pray for an easy life, pray for the strength to endure a difficult one” -Bruce Lee
Offline Neal
  • Skype: iNewbcake
« Reply #19 on: Sun, 31 March 2013, 15:03:10 »
Wow! Nice, I got one of these somewhere. Unopened in box still, after ordering it the idea of all the switches seemed silly. I should probably open it, haha.
Offline drdoooom
« Reply #20 on: Tue, 02 April 2013, 10:59:13 »
this is an awesome review, thanks for putting it up!
