i'm looking for a keyboard for games and office every day typing. As i said i have the Isku from Roccat
and it feels a bit cheap when typing. Or is it just me not getting used to a gamer board with the noise that
it makes?
Tanks for response
jangodog
I don't think that's a mechanical keyboard, so I can't imagine it would sound too different from any normal keyboard.
Anyway, if you're going to spend a good sum of money on your keyboard, I'd recommend you lurk around the forum a bit, do some research, read some reviews, and make an informed decision. It seems to me that you know you want a better keyboard but you don't know enough about them to know what to get. That's not an insult, just an observation. I am by no means an expert myself; I do, however, believe in research before making a purchase.
Where are you located? If you have a gaming computer store near you (NCIX is awesome, I don't know any others) check if they have mechanical keyboards there, and actually try them out. There are a lot of options, and it is certainly hard to make a choice without trying them.
If you don't have a store near you with a range of keyboards to try, I would recommend this:
http://www.wasdkeyboards.com/index.php/wasd-sampler-kit.htmlIt contains 4 of the more popular types of switches, so you can actually see the difference in feel. The blue one is tactile and clicky, the brown is tactile with no click (you can feel a click but not hear it), the black and red are both linear (no click, smooth action to the bottom) but the black takes more force to press. Many say the red is like typing on a cloud. I like my blues personally.
So, it's a pretty subjective decision, and there's a lot of small things you can obsess over. I'd recommend you worry about the big things, mainly: switch type; extra keys. Decide if you like it clicky or smooth, and if you require any macros or programmable keys. That last choice will definitely shrink the number of keyboards you have to choose from. Many gamers demand it; I'm not a gamer so I have the very no-frills Filco Majestouch Ninja.
Ok, I'm rambling. Hopefully this came out helpful rather than unintelligible. Good luck, fine sir.
