Author Topic: .  (Read 13590 times)
Offline esoomenona
  • Gnillort?
« on: Tue, 12 March 2013, 23:23:41 »
« Last Edit: Wed, 15 October 2014, 19:26:36 by esoomenona »
Offline esoomenona
  • Gnillort?
« Reply #1 on: Tue, 12 March 2013, 23:23:57 »
« Last Edit: Wed, 15 October 2014, 19:26:43 by esoomenona »
Offline esoomenona
  • Gnillort?
« Reply #2 on: Tue, 12 March 2013, 23:24:12 »
« Last Edit: Wed, 15 October 2014, 19:26:52 by esoomenona »
Offline The_Beast
  • I like wood ಠ_๏
Re: Moose's Mods
« Reply #3 on: Tue, 12 March 2013, 23:46:21 »
When I had hellocodes poker, I tried lubed clears. I didn't like it nearly as much as ergo clears. However I also tried ApocalypseMaow lubed browns, I think I might light browns again
Offline Michael
  • Formerly Bro Caps
Re: Moose's Mods
« Reply #4 on: Tue, 12 March 2013, 23:49:30 »
lubed browns are goodness. people shouldn't hate.
Re: Moose's Mods
« Reply #5 on: Tue, 12 March 2013, 23:49:54 »
Those colors on that black...
Offline esoomenona
  • Gnillort?
« Reply #6 on: Wed, 13 March 2013, 00:15:02 »
« Last Edit: Wed, 15 October 2014, 19:27:02 by esoomenona »
Offline esoomenona
  • Gnillort?
« Reply #7 on: Wed, 13 March 2013, 00:15:19 »
« Last Edit: Wed, 15 October 2014, 19:27:11 by esoomenona »
Offline The_Beast
  • I like wood ಠ_๏
Re: Moose's Mods
« Reply #8 on: Wed, 13 March 2013, 00:16:54 »
Hmm... Is it hard to clean off lube if you don't like it?
Well, I mess up one of my poker plates so I use it to test switches. One switch this lube, the other that lube..... and then see which one I like the most. Then I ran with it.
Offline zoolzoo
Re: Moose's Mods
« Reply #9 on: Wed, 13 March 2013, 05:28:13 »
So, here we have it. My first actual mod of sorts. I recently purchased some Clears, and once I received them today, decided to drop them in my Poker with Blues. I chose to go with Clears first, to see how I like them. Then, I will try different variations of Ergo Clears with different springs. After I make my decision on which I like best, I will sticker and lube. But on to the pictures!
Looks really clean but colorful, awesome.
Leopold FC660C, Topre 45g | CM QFR, MX Blue | Rosewill RK-9000v2, MX Red | Cherry Slimline G84-4100, ML | Ducky One2 Mini RGB, MX Red
Re: Moose's Mods
« Reply #10 on: Wed, 13 March 2013, 06:05:57 »
Looks awesome moose. Let us know how you like the clears
Offline esoomenona
  • Gnillort?
« Reply #11 on: Wed, 13 March 2013, 08:40:46 »
« Last Edit: Wed, 15 October 2014, 19:27:38 by esoomenona »
Offline Jmneuv
Re: Moose's Mods
« Reply #12 on: Wed, 13 March 2013, 09:35:50 »
Try Panda Clears (with black springs) - those feel great, like stiffer browns.
Regular Clears just make me bounce off the keyboard, can't take those seriously.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
Re: Moose's Mods
« Reply #13 on: Wed, 13 March 2013, 09:43:14 »
Green with envy over your key cap puller. Very nice!
Offline esoomenona
  • Gnillort?
« Reply #14 on: Wed, 13 March 2013, 09:50:00 »
« Last Edit: Wed, 15 October 2014, 19:27:50 by esoomenona »
Offline SmallFry
Re: Re: Moose's Mods
« Reply #15 on: Wed, 13 March 2013, 10:16:09 »
The switch removal tools?
You lucky poo poo... :P
Offline esoomenona
  • Gnillort?
« Reply #16 on: Wed, 13 March 2013, 10:22:38 »
« Last Edit: Wed, 15 October 2014, 19:28:01 by esoomenona »
Offline Sai
Re: Moose's Mods
« Reply #17 on: Wed, 13 March 2013, 10:25:08 »
Thanks, everyone. So far, I like the Clears, but I can see what people say when they say that they almost feel linear, like the bump is hardly there, even though it's bigger then Browns. I will swap them out tonight and put the Blue springs back in.
The only thing that worries me is how tight these caps are on the stems. Last night, I put one on wrong, and had to pull it off. When doing so, the whole switch top came off! Lucky that the stem didn't break off. I managed to get the stem and housing out, but I'm worried that might happen to more, or worse.
yep. happened to me when i was using clear stems and decided not to use them again. its just scary for me. =.=
Offline Jocelyn
  • 조셀린
« Reply #18 on: Wed, 13 March 2013, 10:26:44 »
^They are awesome. I can only imagine how much it must suck to pop them out with screwdrivers or something. Just slide 'em in, squeeze, and remove.
This^ Switch removal tools plus WFD's dremel mod to my switch tops w/ LED means I can change my board to any switch/spring easily and quickly.
PS - esoomenona, I have some black springs in case you'd like to try panda-clears.
^Dremel mod? Also, PM incoming.
Link - http://geekhack.org/index.php?topic=40126.msg794392#msg794392
Video
« Last Edit: Wed, 13 March 2013, 10:38:34 by Jocelyn »
Offline esoomenona
  • Gnillort?
« Reply #19 on: Wed, 13 March 2013, 10:31:18 »
« Last Edit: Wed, 15 October 2014, 19:28:22 by esoomenona »
Offline esoomenona
  • Gnillort?
« Reply #20 on: Wed, 13 March 2013, 10:53:32 »
« Last Edit: Wed, 15 October 2014, 19:28:29 by esoomenona »
Offline Jocelyn
  • 조셀린
Re: Moose's Mods
« Reply #21 on: Wed, 13 March 2013, 11:44:01 »
Yep, need to buy a Dremel. That'll be the next thing on my list.
Haha yes, you will definitely need one of those :)
(Courtesy WFD)
Offline fruktstund
Re: Moose's Mods
« Reply #22 on: Wed, 13 March 2013, 11:51:59 »
I did the same thing with a regular wire cutter thing (don't really know what they're called, but some kind of smaller wire cutter), and it works great, so I wouldn't buy a dremel only for this. (Dremels are rather useful for other stuff though, so might be worth a buy anyways.)
Since I don't have any of those fancy switch openers I have to bend the LED forward a bit before opening the switch, but that works just as fine. :>
Offline esoomenona
  • Gnillort?
« Reply #23 on: Wed, 13 March 2013, 11:59:29 »
« Last Edit: Wed, 15 October 2014, 19:28:41 by esoomenona »
Offline esoomenona
  • Gnillort?
« Reply #24 on: Wed, 13 March 2013, 19:50:02 »
« Last Edit: Wed, 15 October 2014, 19:28:50 by esoomenona »
Offline Jocelyn
  • 조셀린
Re: Moose's Mods
« Reply #25 on: Wed, 13 March 2013, 19:54:51 »
New update, post 2.
Nice springs and caps!! Are they 62g like mine? :)
Edit - Which set of RGB are those red and blue caps from? Sherryton?
« Last Edit: Wed, 13 March 2013, 19:56:42 by Jocelyn »
Offline esoomenona
  • Gnillort?
« Reply #26 on: Wed, 13 March 2013, 20:03:59 »
« Last Edit: Wed, 15 October 2014, 19:29:03 by esoomenona »
Offline Jocelyn
  • 조셀린
« Reply #27 on: Wed, 13 March 2013, 20:19:33 »
The springs are from stock Blue switches. I will try 62g and 65g next. And yes, the caps and RGB are from Sherryton.
Whaaaaaaaat? Stock Blue switches have gold springs?
Offline esoomenona
  • Gnillort?
« Reply #28 on: Wed, 13 March 2013, 20:25:30 »
« Last Edit: Wed, 15 October 2014, 19:29:11 by esoomenona »
Offline Jocelyn
  • 조셀린
Re: Moose's Mods
« Reply #29 on: Wed, 13 March 2013, 20:30:24 »
They're not gold. They're more silvery brassyish.
Thanks, I see that now and blame my SGNote2's over saturated screen when I looked before.
« Last Edit: Wed, 13 March 2013, 20:32:43 by Jocelyn »
Offline tjcaustin
  • King Klaxon
    • Buy stuff
Re: Moose's Mods
« Reply #30 on: Wed, 13 March 2013, 20:40:10 »
I wish I had custom caps to make my poker with new case look good.  I just have these boring stock ABS things.
Nevermind that I'm waiting on four separate GB sets, at least two of which will be here before summer, if not all four.
Offline esoomenona
  • Gnillort?
« Reply #31 on: Wed, 13 March 2013, 20:44:32 »
« Last Edit: Wed, 15 October 2014, 19:29:23 by esoomenona »
Offline tjcaustin
  • King Klaxon
    • Buy stuff
Re: Moose's Mods
« Reply #32 on: Wed, 13 March 2013, 20:46:19 »
I'm waiting on two GB sets right now. One of which has shipped, the other I was would ship already.
I got a poker simply for Retro (I'm assuming that's what you want to ship already).  Hell, I got this case because retro + poker + silver case looked fantastic.
It's just in the meantime that's the problem, heh.  I mean, I guess I could unicorn it up a bit...
More randomness.  I went to make my own "here be my keyboards" thread, then realized I don't have a camera that takes good enough pictures to do something like this.  Soon though.
« Last Edit: Wed, 13 March 2013, 21:16:21 by tjcaustin »
Offline esoomenona
  • Gnillort?
« Reply #33 on: Wed, 10 April 2013, 12:40:30 »
« Last Edit: Wed, 15 October 2014, 19:29:53 by esoomenona »
Offline rurushu
Re: Moose's Mods
« Reply #34 on: Wed, 10 April 2013, 14:33:00 »
Alright. So I haven't touched my Poker since I borked the  spacebar switch. Just really haven't had the time. BUT...
I did finally receive the Ragnorock 10 key set that I've been searching for. And now that I have my Phantom up and running, it's time to carefully consider where to go from here. This is a picture of what I've been considering doing. The Insert key won't be Insert, but rather Delete. I think it's a good position for it. I'd like the Num Lock key to switch between Arrow mode and Numpad mode. Also, of course I won't be able to fit that big + there, so I'll probably use the red Cherry key under it for +.
nice caps esoomenona!
so you going to change the layout of your phantom?
Offline esoomenona
  • Gnillort?
« Reply #35 on: Wed, 10 April 2013, 14:40:41 »
« Last Edit: Wed, 15 October 2014, 19:30:01 by esoomenona »
Moose's Mods
« Reply #36 on: Wed, 10 April 2013, 14:47:31 »
Glad to see the moose avatar back!
Offline inlikeflynn
  • file not found
Re: Moose's Mods
« Reply #37 on: Wed, 10 April 2013, 14:54:06 »
I fear the moose is near plotting to steal my 1800's
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Moose's Mods
« Reply #38 on: Wed, 10 April 2013, 15:09:06 »
Be afraid!
Offline esoomenona
  • Gnillort?
« Reply #39 on: Wed, 10 April 2013, 15:37:20 »
« Last Edit: Wed, 15 October 2014, 19:30:13 by esoomenona »
Re: Moose's Mods
« Reply #40 on: Tue, 07 May 2013, 09:46:28 »
Moose thanks for the awesomeness of this thread....I will study it more later but wanted to give you props!
Offline esoomenona
  • Gnillort?
« Reply #41 on: Tue, 07 May 2013, 09:50:22 »
« Last Edit: Wed, 15 October 2014, 19:30:23 by esoomenona »
Re: Moose's Mods
« Reply #42 on: Tue, 07 May 2013, 15:59:52 »
moose's collection is just too damn cool.
Offline TheQsanity
  • SmallFry Lovin'
Re: Moose's Mods
« Reply #43 on: Tue, 07 May 2013, 16:30:53 »
Blue brown springs are slightly stiffer than reds.
I have red springed ergoclears.
I hav tried ghetto reds and they feel slightly stiffer than reds.
We need more removal toooollllllsssss!!!!!! ASDF
SmallFry! <3
Offline Jocelyn
  • 조셀린
« Reply #44 on: Tue, 07 May 2013, 16:34:06 »
Ehhhhhh? I thought black and red stems were identical >.>
Offline esoomenona
  • Gnillort?
« Reply #45 on: Tue, 07 May 2013, 16:45:48 »
« Last Edit: Wed, 15 October 2014, 19:30:34 by esoomenona »
Offline TheQsanity
  • SmallFry Lovin'
Re: Moose's Mods
« Reply #46 on: Tue, 07 May 2013, 17:07:14 »
The most noticeable thing would be the sound it makes. It is ever so slightly different. Most people wouldnt notice.
SmallFry! <3
Offline TheQsanity
  • SmallFry Lovin'
Re: Moose's Mods
« Reply #47 on: Tue, 07 May 2013, 17:07:28 »
SmallFry! <3
Offline VesperSAINT
  • vpsert
  • #CustomKorean
Re: Moose's Mods
« Reply #48 on: Tue, 07 May 2013, 18:24:52 »
This thread is pretty awesome. I'm also very close to doing my own mod and this thread definitely has me pumped! I really would love to be able to buy those switch removal tools too!
Offline davkol
  •  Post Editing Timeout
Re: Moose's Mods
« Reply #49 on: Wed, 08 May 2013, 06:21:14 »
I'd rather believe that different batches of springs are different.
