Author Topic: IBM Model M with Lenovo t530 and Windows 8  (Read 373 times)
Offline charrington
« on: Tue, 16 April 2013, 01:28:03 »
First, I've been away from this site for too long. Is good to be back!
I got a new PC - Lenovo t530 and Windows 8. Just getting setup.  I've got one of my Model M keyboards plugged into a USB port using a Ziotek adapter (several years old - not sure if they've changed).  When I boot Windows, the keyboard flashes (sometimes NumLock stays on) but the keyboard won't respond unless I unplug it and then plug it back in. The particular Model M I tried was made March 1990.
Offline E TwentyNine
    • Some of My Keyboards
Re: IBM Model M with Lenovo t530 and Windows 8
« Reply #1 on: Tue, 16 April 2013, 09:08:15 »
Do you have it plugged into a USB-3 port?  Try a USB-2 port instead.
Current daily driver: AT Model F modded to tenkeyless layout
Others: December 1984 Model M Industrial Prototype ⌨ 1992 Black Oval Industrial M SSK ⌨ 1982 5251 Beamspring ⌨ 89 Key "SSK" ⌨ Multiple M13's and older M's
Offline Rule16
  • R.I.P. SmallFry
« Reply #2 on: Tue, 16 April 2013, 12:30:22 »
This should not be a problem the USB-3 port would downgrade it to a USB-2 port.
| Das Keyboard Silent | Black Widow Ultimate | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F
Did someone say [Thunderfury, Blessed Blade of the Windseeker]?
« Reply #3 on: Tue, 16 April 2013, 12:46:54 »
It "should not" be a problem.  However, I have a Thinkpad W520 and it acts the exact same way when the keyboard is plugged into the USB-3 .  USB-2 - no problem.
Offline Rule16
  • R.I.P. SmallFry
« Reply #4 on: Tue, 16 April 2013, 13:01:53 »
That's odd... does it work with other USB-2 devices?
« Reply #5 on: Tue, 16 April 2013, 13:07:40 »
From what I recall, other stuff with that port (mouse, printers, external drives) all worked fine.  Just the keyboard with the bluecube acted funky.  Thinking back, I think on a cold boot it worked fine.  On a resume from hibernation it always happened.
Switched ports, hasn't been a problem since.   Haven't investigated it any further than that.
Offline SmallFry
« Reply #6 on: Tue, 16 April 2013, 13:33:52 »
I occasionally have problems with USB 3.0 ports acting funky also. I can get things to wrok in USB 2 ports, but not USB 3.0
Offline Rule16
  • R.I.P. SmallFry
« Reply #7 on: Tue, 16 April 2013, 14:08:12 »
Hmmm... have you tried turning it off and on again?
Offline longface
« Reply #8 on: Wed, 17 April 2013, 11:05:50 »
My Model M has trouble waking up from hibernation from the powered USB 2.0 port (Windows 7).  But after I moved it to a normal USB 2.0 port, it works perfectly.
So I guess the good old USB 2.0 is the best friend of old keyboards?
ThinkPads, tennis racquets and now, keyboards
