Author Topic: Post your Ergodox!  (Read 169432 times)
Offline ekw808
  • Ekw
Post your Ergodox!
« on: Wed, 24 April 2013, 14:52:56 »
Let's see them.
« Last Edit: Wed, 24 April 2013, 14:56:53 by ekw808 »
[One Keyboard at a time]
Offline Michael
  • Formerly Bro Caps
Re: Post your Ergodox!
« Reply #1 on: Wed, 24 April 2013, 15:13:24 »
Where is yours? :P
Offline ekw808
  • Ekw
« Reply #2 on: Wed, 24 April 2013, 15:16:37 »
Being sanded
Offline SmallFry
« Reply #3 on: Wed, 24 April 2013, 15:19:38 »
Isn't there already an eDox thread? :confused:
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #4 on: Wed, 24 April 2013, 19:30:29 »
all my pics http://www.flickr.com/photos/panicfx/sets/72157633198800512/
making changes soon though and i still have the other one to build
:/ no love for Glod topics
http://geekhack.org/index.php?topic=42231.0
the ergodox makes me happy every day
« Last Edit: Wed, 24 April 2013, 19:36:16 by Glod »
Offline CommunistWitchDr
  • >implying keyboards
« Reply #5 on: Wed, 24 April 2013, 19:51:53 »
I noticed you have aluminum and acrylic. How does the acrylic plate compare to the metal one?
« Last Edit: Wed, 24 April 2013, 20:20:01 by CommunistWitchDr »
Offline Glod
    • YouTube Channel
« Reply #6 on: Wed, 24 April 2013, 20:18:54 »
i think you messed up quoting my post
yeah the aluminium case needs to be shaved (or the PCB) for the PCB to work with the case and the case is very rough to touch and kind of dirty so many have cleaned and sanded and buffed it.
i have yet to do anything to the aluminium case yet so right now except try out the top and bottom layers on the acrylic one so i don't have the second ergodox yet, not that i need it right now anyway.
the acrylic for the most part is cut correctly, i think i saw a burn mark but nothing noticeable.
problem with the acrylic, especially clear acrylic, its not very pretty, it makes something that looks geeky already look even more geeky and it gets dirty very easily.
and this is coming from me who owns a 30" tall danger den clear acrylic tower LOL
« Reply #7 on: Wed, 24 April 2013, 20:21:07 »
Oops, fixed it.
I was mostly wondering how it felt to type on, I'm getting a case custom cut in black and white (Black top/bottom, white middle) so the look shouldn't be so bad.
Offline Glod
    • YouTube Channel
« Reply #8 on: Wed, 24 April 2013, 20:24:15 »
the acrylic is very sturdy and thick so i think the typing is the same though i havent fully assembled my aluminum yet
if you have the full hand then of course the feeling would be different on the actual hands.
Offline WRXChris
« Reply #9 on: Wed, 24 April 2013, 20:28:27 »
I just finished mine yesterday, and I'm loving it!  The ergo clear switches are lubed with a mixture of GPL-103 & 205.  I used SMD diodes (my first attempt at SMD soldering and after getting over the jitters it was easy!)  One of my plates seems to be cut funky and wouldn't hold switches in certain locations (the other one was perfect, every switch snapped right into place), and it was a pain to hold the switch down while feeding the solder with the same hand on the opposite side of the pcb, iron in the other hand of course, but I made it through it!
Here is my layout so far: https://www.massdrop.com/ext/ergodox/?referer=HEXPCZ&hash=690ba45eae62982a0d5db34a3cc5a113
« Last Edit: Wed, 24 April 2013, 21:55:54 by WRXChris »
Offline Michael
  • Formerly Bro Caps
« Reply #10 on: Wed, 24 April 2013, 22:14:12 »
That looks sick with those blank DSA caps, Chris.
Offline rknize
    • metaruss
« Reply #11 on: Wed, 24 April 2013, 22:29:34 »
Copy-pasta from the other thread:
Massdrop is making the right move by dropping the aluminum case.  It is a royal PITA.  The finish is rough, to say the least, and the fitment is awful.  There is a lot of error in the cuts, so the PCB wouldn't even fit into the case.  A lot of grinding, milling, drilling, filing, and polishing, I finally got it to work.  Not perfect, but tolerable at least.
It's loaded up with lubed browns and the "qwerty-kinesis-mod" layout to start.  Between the matrix layout and blank keys, typing is a huge challenge.
Russ
Offline ekw808
  • Ekw
« Reply #12 on: Wed, 24 April 2013, 23:09:04 »
Damm Glod, your Ergo makes me jelly, I've got a long ways to go on mine before it looks anywhere near that.
Offline daerid
    • Rossipedia
« Reply #13 on: Wed, 24 April 2013, 23:29:38 »
I think when I end up putting mine together I'm going to make a GUI layout creator for it. I have a feeling I'm going to be re-programming this thing quite a few times, and I want that to be as easy as possible.
Offline SmallFry
Re: Re: Post your Ergodox!
« Reply #14 on: Wed, 24 April 2013, 23:38:31 »
What about the massdrop configurator?
Offline Glod
    • YouTube Channel
« Reply #15 on: Wed, 24 April 2013, 23:52:17 »
yeah the configurator is a gui layout editor, the thing rocks!
Offline daerid
    • Rossipedia
Post your Ergodox!
« Reply #16 on: Thu, 25 April 2013, 00:24:44 »
Not quite as easy as I'd like. I want to configure it, hit save and it uploads to the device.
« Reply #17 on: Thu, 25 April 2013, 00:38:42 »
Also things like macro keys, shifted symbols, and other more advanced keyboard features would be nice to have in a gui too.
Offline Lunartuna
  • Good bye money!
« Reply #18 on: Thu, 25 April 2013, 08:40:48 »
I know who is going to win this thread.  :cool:
Shine 2 TKL - Choc Mini
Offline Larken
« Reply #19 on: Thu, 25 April 2013, 09:12:04 »
I actually liked the transparent acrylic look, but the dirt that was getting on it daily finally annoyed me enough to do something about it.
| Ergodox #1 | Ergodox #2 |
Offline mashby
  • What Up Shoney? (ツ)_/Ż
    • Mashby
« Reply #20 on: Thu, 25 April 2013, 09:16:36 »
Larken, it looks like you've made a Predator version.  :p
Offline Tarzan
  • formerly known as Greystoke
« Reply #21 on: Thu, 25 April 2013, 09:17:32 »
I noticed the book-matched veneer as well...  Stealth look on a wood desk!
« Reply #22 on: Thu, 25 April 2013, 09:23:06 »
Here's a gross pic of mine with some random devlin caps. Ignore the blur, dust and other things :D
Offline Larken
« Reply #23 on: Thu, 25 April 2013, 09:24:31 »
it was some leftover vinyl I had, lol. I figured it'll go really well with the brown DSA retro gb  ;D
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #24 on: Thu, 25 April 2013, 10:41:19 »
I like the random devlin caps on it.
Offline WhiteFireDragon
    • youtube
« Reply #25 on: Thu, 25 April 2013, 11:49:10 »
This post has an amazing custom case with the ergo dox. I would post it, but it's not mine to post so I'll just link it:
http://geekhack.org/index.php?topic=22780.msg866727#msg866727
Offline esoomenona
  • Gnillort?
« Reply #26 on: Thu, 25 April 2013, 11:51:29 »
I really wanted to buy one of these. Maybe if they do a third round, or maybe I can grab one in the Classifieds some day.
Offline daerid
    • Rossipedia
« Reply #27 on: Thu, 25 April 2013, 12:06:35 »
Yeah, that board of his is inspiring. I really, really like his use of arcade-style buttons for his trackball.
Offline Gupgup
Post your Ergodox!
« Reply #28 on: Thu, 25 April 2013, 12:07:33 »
Mine :D
Offline esoomenona
  • Gnillort?
« Reply #29 on: Thu, 25 April 2013, 12:10:36 »
Maybe we should have a discussion then.
Offline Glod
    • YouTube Channel
« Reply #30 on: Thu, 25 April 2013, 12:56:31 »
maybe i should design a case for the ergodox so that mine doesnt look like everyone else lol
i am pretty sure out of the 2 rounds some people are going to be parting with their ErgoDox
i love mine (obviously) but some people may find they don't like the matrix layout.
i mean that is fine, but realize the massdrop configurator thing saves a file (made for the ic07 firmware) that you just load directly in the teensy loader (which runs on mac, pc, linux) and it takes like 5 seconds to load and restart the teensy.
would be nice to put that effort into making a configurator tool for the phantom. ;)
Offline daerid
    • Rossipedia
« Reply #31 on: Thu, 25 April 2013, 14:09:04 »
True, but I don't own a Phantom, but I will own an ErgoDox :)
Plus, I like getting my hands dirty. I've even toyed with the idea of replacing the controller on one of my RealForces with a Teensy 3.
TBH, I'll probably put a Teensy 3 in my ErgoDox (micro USB ftw) and save the Teensy 2 for some other project.
*EDIT* Damn, looks like the Teensy 3 won't fit in the same pinout as the 2.0, oh well :(
« Last Edit: Thu, 25 April 2013, 14:14:00 by daerid »
Offline Glod
    • YouTube Channel
« Reply #32 on: Thu, 25 April 2013, 14:17:42 »
well the teensy's mini-usb doesn't stick out out of the case so the miniusb wouldn't matter you could still with some work rig a microusb port if you absolutely wanted to.
Offline daerid
    • Rossipedia
Post your Ergodox!
« Reply #33 on: Thu, 25 April 2013, 14:52:45 »
Exactly what I was thinking. Need to see if I can find a female Micro USB that has the same pin out as the Mini USB that goes on the ergodox pcb
Offline SmallFry
« Reply #34 on: Thu, 25 April 2013, 19:51:00 »
Also the Teensy 3 is different from the 2 in the processor. You'd need to rewrite/recompile the firmware for that processor.
Offline daerid
    • Rossipedia
« Reply #35 on: Thu, 25 April 2013, 22:36:15 »
@SmallFry: I plan on doing that anyways (been programming for 15 years now).
Offline SmallFry
« Reply #36 on: Thu, 25 April 2013, 22:51:12 »
Welp... that covers my life basically. 0.o
Offline Glod
    • YouTube Channel
« Reply #37 on: Thu, 30 May 2013, 21:30:27 »
I am going to bring this thread BACK TO LIFE
i know there are more ErgoDox out there, please share!
More love for what is my favorite board!
I'm going to give a sneak peak of my almost finished ErgoDox #2
Some stuff left to do cosmetically and waiting for Retro. There is an obvious accessory to this ErgoDox that is going to get some attention.
Offline Larken
« Reply #38 on: Thu, 30 May 2013, 21:32:38 »
very nice, Glod. did you make rests yourself?
Offline Glod
    • YouTube Channel
« Reply #39 on: Thu, 30 May 2013, 21:45:56 »
these rests were an experiment/creation by kurplop, kind of a one-time thing he wanted to make.
I sanded, stained, and added varnish to it.
once i finish this ErgoDox i am going to take much better photos with better lighting, this thing deserves better photos. This photo doesnt do it justice.
can't wait for the Retro, should look great with the wooden rests.
Offline Larken
« Reply #40 on: Thu, 30 May 2013, 21:57:02 »
Ah, kurplop, the master craftsman. :D
they're beautiful (much envy here, lol). its great to see that you found a solution to your wrist wrest conundrum.
Offline Glod
    • YouTube Channel
« Reply #41 on: Fri, 31 May 2013, 14:33:14 »
thanks
I'm wondering right now how many assembled ErgoDox there are right now. obvious there are the ones shared in the original ergodox thread recently but there was over 200 ergodox sold and so far only a dozen have been shared.
Offline esoomenona
  • Gnillort?
« Reply #42 on: Fri, 31 May 2013, 17:16:16 »
One day, I wish to post an actual image in this thread...
Offline Glod
    • YouTube Channel
« Reply #43 on: Tue, 04 June 2013, 01:44:02 »
another pic, with a crap camera, this time with retro
DSA Retro by almightyglod, on Flickr
im gonna keep bumping this thread until more people share, im doing exciting things with my other ergodox soon which is now my travel ergodox. can't wait to share that, but i can't until i replace a part i broke.
Gotta say that i think i am done with using normal keyboards. i am still going to collect keyboards and key caps and i plan on building more DIY boards. 3 of the 4 GH60s i am getting are going to be gifted or sold to friends. But the ErgoDox is the best keyboard I've owned. It combines all the things i loved from other keyboards I've owned and has the customized experience you only get from a DIY cherry mx board.
My next keyboard to replace the ErgoDox, if that ever happens, would be another DIY board with the matrix layout or maybe the next offering from Kenesis. A long shot would also be owning a uTron (split ergo topre? ermagawd topre....)
Offline Larken
« Reply #44 on: Tue, 04 June 2013, 01:59:06 »
lol @ Glod. Glad to see someone loves their Ergodox as much as I do mine.
I've since retired most of my other boards ever since I finished building my ergodox, so much so that I can no longer use non-matrix boards (so to speak. I can still use those but find myself thumbing the spacebar when I want to press backspace. It gets annoying).
To continue the conversation from the other thread, your top cover already looks great, though the sides are still a little unsightly. Looking forward to when you're fully done with it, as well as what you're doing with the other one. I'm working on a second one myself, though I'm planning through the process for that one at a slower pace.
Offline Glod
    • YouTube Channel
« Reply #45 on: Tue, 04 June 2013, 02:18:05 »
yeah, not going to sand the sides until probably next Monday or the Monday after but i am going to do it for sure; it is a bit ugly especially considering i have the ErgoDox in a tent/slope so the sides are just staring at me every-time i glance at the keyboard.
kurplop took sanding those edges to another freaking level http://geekhack.org/index.php?topic=22780.msg854128#msg854128
i doubt i can get it to look completely flush like that but as long as the sides of each layer to have the same finish/shine i'll be happy. I may have to my dremel at first. It makes a huge toxic mess when sanding the aluminium.
Offline kurplop
  • THE HERO WE DON'T DESERVE
« Reply #46 on: Tue, 04 June 2013, 07:28:18 »
I'm a bit puzzled regarding why so few have commented on their ErgoDoxes. I can understand not everyone posting pictures, especially if they kept everything stock, but the limited response is surprising. A few have made unfavorable comments, which I think we should welcome, but considering the number sold I would have expected a bigger overall response. I realize that we "ergo" enthusiasts at geekhack are less likely to gush over cute keycaps and other aesthetic considerations, we are more interested in solving ergonomic issues. Do you think that many have found the ErgoDox not to be the "magic feather" they expected and are too embarrassed to admit it after all the excitement?
As for me, I think the biggest problem I have found is that the programability has allowed me to remap by layout so differently from the conventional that I fear I will have trouble using a standard keyboard again.
Offline baldgye
  • Will Smith Disciple
« Reply #47 on: Tue, 04 June 2013, 07:33:35 »
I could never use that keyboard, but my god... that combination is amazing, those rests look amazing and work so well with the caps and the case... it looks like a keyboard from the future... but better and with some retro charm. Really love that alot
Offline vivalarevolución
« Reply #48 on: Tue, 04 June 2013, 13:50:09 »
No worries boys and girls.  I will post my Ergodox when it arrives in the mail, courtesy of my assembler.  With Retro DSA!  From various angles and poses!  Hopefully with good lighting!
Offline Latin00032
« Reply #49 on: Tue, 04 June 2013, 14:47:38 »
Too bad mine didn't come with a metal frame.
It looks like you can hack the Gibson with that.
