Author Topic: Poker 2 @ TechKeys  (Read 16718 times)
Offline i3oilermaker
  • * Moderator
  • techkeys.us
    • TechKeys
Poker 2 @ TechKeys
« on: Mon, 06 May 2013, 10:37:12 »
The Poker 2 will be available on TechKeys mid May when it is released.
Red, Brown, and Blue switch types will be available.  More details to come.
Prices will be competitive and shipping will be prompt.
...discuss
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
Re: Poker 2 @ TechKeys
« Reply #1 on: Mon, 06 May 2013, 10:37:51 »
Nice!!!!
Any chance of getting just the PCB?
-Enzo Ferrari
  • * Moderator
  • techkeys.us
    • TechKeys
« Reply #2 on: Mon, 06 May 2013, 10:38:22 »
Nice!!!!
Unfortunately that is not an option.
Offline Permeability
« Reply #3 on: Mon, 06 May 2013, 10:39:17 »
Which type of poker 2 is it? The ones with PBT caps / no LEDs?
Keyboards:
'The Cheat' - lubed 62g Clears
Ducky Shine 3 TKL lubed 45g Reds (Work)
« Reply #4 on: Mon, 06 May 2013, 10:40:50 »
Will there be any support/warranty offered on these?
Offline Lunartuna
  • Good bye money!
« Reply #5 on: Mon, 06 May 2013, 10:46:12 »
Y U NO BLACKS?
Shine 2 TKL - Choc Mini
  • * Moderator
  • techkeys.us
    • TechKeys
« Reply #6 on: Mon, 06 May 2013, 10:59:50 »
It is the no LED version, but it does have LEDs for Space Bar and CapsLock
If units are DOA they will be replaced if the hardware is faulty.  If the firmware is the issue, it can be fixed.
« Reply #7 on: Mon, 06 May 2013, 11:04:35 »
good to know will be keeping an eye out....might have to get my first poker.... 8)
Offline BunnyLake
  • The OG HHKB Master
  • X
« Reply #8 on: Mon, 06 May 2013, 11:04:41 »
in for one with browns
Offline codymaust
« Reply #9 on: Mon, 06 May 2013, 15:29:53 »
Y U NO BLACKS?
Agreed.
Would love one with blacks but might just go for one with reds. Great news either way!
Offline elton5354
« Reply #10 on: Mon, 06 May 2013, 15:36:52 »
if <$90, YES!
Offline Lunartuna
  • Good bye money!
« Reply #11 on: Mon, 06 May 2013, 20:34:30 »
Honestly if I was going to pick one up with would be one with Blues. I have a Reds and Blacks boards yissss.
Offline SmallFry
« Reply #12 on: Mon, 06 May 2013, 20:40:05 »
Do you know how these are to be programmed at the current time?
  • * Moderator
  • techkeys.us
    • TechKeys
« Reply #13 on: Mon, 06 May 2013, 21:50:13 »
Yes
Programming Usage
Press PN + Programmed key, OR
Press Toggle(FN+Right SHIFT) to light up the spacebar left LED first. Then press the programmed key directly. If
you press PN + Programmed key at this moment, it will output the original key code.
Offline TheBinary
« Reply #14 on: Fri, 10 May 2013, 00:21:04 »
I'm looking forward to checking out one of these as soon as you get them in!
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #15 on: Fri, 10 May 2013, 08:55:20 »
Yes
Programming Usage
Do you know if it will be possible to re-assign the Fn and/or Pn keys elsewhere?  Specifically I would like to use the bottom right mods as arrow keys, and cannot do that to the Poker because the Fn key cannot even be seen by AutoHotKey or xkeymap.
 - Ron | samwisekoi
« Last Edit: Fri, 10 May 2013, 08:57:10 by samwisekoi »
Offline codymaust
« Reply #16 on: Fri, 10 May 2013, 09:17:15 »
Slightly off topic, but how difficult is it to swap out springs on a poker?
Not sure if Reds would be a good choice... but if I can swap in 55g springs fairly easily its a different situation
  • * Moderator
  • techkeys.us
    • TechKeys
« Reply #17 on: Fri, 10 May 2013, 09:26:50 »
Yes
Programming Usage
 - Ron | samwisekoi
The only DIP settings are as follows:
The original pokers were not plate mounted, so it was easy to switch stems/springs.
Poker 2s are plate mounted so I have to assume it will be hard to open switch housings without de-soldering first.
  • * Moderator
  • techkeys.us
    • TechKeys
« Reply #18 on: Thu, 16 May 2013, 10:47:54 »
Update - These will ship to me on 5/23
« Reply #19 on: Fri, 17 May 2013, 11:23:52 »
thanks for the update i3oiler
Offline tipo33
  • "Ski"
« Reply #20 on: Fri, 17 May 2013, 13:33:13 »
Why I gotta go to Italy? :(
KM4COL    R.I.P.  SmallFry
« Reply #21 on: Thu, 06 June 2013, 06:02:59 »
Any update on the poker 2, is it still incoming?
  • * Moderator
  • techkeys.us
    • TechKeys
« Reply #22 on: Thu, 06 June 2013, 07:57:45 »
I really hope so - communication with vortex has been difficult.
Offline BunnyLake
  • X
« Reply #23 on: Thu, 06 June 2013, 07:59:28 »
in the mean time i demand new keys to be made available at techkeys
  • * Moderator
  • techkeys.us
    • TechKeys
« Reply #24 on: Thu, 06 June 2013, 08:00:57 »
Ok :)
« Reply #25 on: Thu, 06 June 2013, 22:02:28 »
Ok :)
Tease ;)
Offline Lu_e
« Reply #26 on: Fri, 14 June 2013, 18:03:16 »
No blacks?
  • * Moderator
  • techkeys.us
    • TechKeys
« Reply #27 on: Mon, 24 June 2013, 12:49:28 »
These are coming Soon™
Offline noctoocto
« Reply #28 on: Sat, 29 June 2013, 01:59:32 »
  • * Moderator
  • techkeys.us
    • TechKeys
« Reply #29 on: Sat, 29 June 2013, 08:41:00 »
No - just preparing for launch
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #30 on: Sat, 29 June 2013, 09:12:28 »
Does that mean you have them now?
 - Ron | samwisekoi
  • * Moderator
  • techkeys.us
    • TechKeys
« Reply #31 on: Sat, 29 June 2013, 09:41:16 »
Yes - Orders placed this weekend will go out on Monday
Offline whiteduck
« Reply #32 on: Sat, 29 June 2013, 09:47:24 »
it appears to be live!
-wd
Offline KangarooZombies
  • HHKB Pro
  • ʕ•ᴥ•ʔ
« Reply #33 on: Sat, 29 June 2013, 15:18:59 »
It seems like you made it the best option to buy it here, for US residents at least. Thanks.
Having a bad day?
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #34 on: Sat, 29 June 2013, 16:48:22 »
Ordered one with Brown switches.
Maybe those will have ad-free space bars!
Glad I waited.
 - Ron I samwisekoi
  • * Moderator
  • techkeys.us
    • TechKeys
« Reply #35 on: Sat, 29 June 2013, 20:44:43 »
They will have both spacebars :P
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #36 on: Sat, 29 June 2013, 21:13:38 »
Really?  I was joking.  Cool.
Thanks very much!
 - Ron I samwisekoi
Offline codymaust
« Reply #37 on: Thu, 04 July 2013, 16:29:02 »
Trying so hard not to order one ~____~
  • * Moderator
  • techkeys.us
    • TechKeys
« Reply #38 on: Thu, 04 July 2013, 16:30:02 »
There is one promo left - the next Poker to be purchased ships with a Hapster and Metallic Poker Set :P
« Reply #39 on: Thu, 04 July 2013, 17:50:34 »
I wish I hadn't already spent money on a GH60 and Pure PCB :(  The Poker II looks fantastic and this is a great promo.  Who doesn't want a hapster?
Offline Jason1313
« Reply #40 on: Thu, 04 July 2013, 18:15:02 »
Gah, just bought my Poker 2 from techkeys like two days ago  :(
  • * Moderator
  • techkeys.us
    • TechKeys
« Reply #41 on: Fri, 05 July 2013, 00:24:40 »
If you are Jason P then you got one of those slots :)
« Reply #42 on: Fri, 05 July 2013, 00:32:47 »
Welcome to Geekhack, Jason1313!
Nice achievement get with your first post :)
Offline Jason1313
« Reply #43 on: Fri, 05 July 2013, 13:59:03 »
Jason W but I hope I still won!
Yeah, I signed up for the DS $8/$9 groupbuy, but this is pretty sweet too!
Offline Cafiend
« Reply #44 on: Fri, 05 July 2013, 14:55:06 »
Offline Cafiend
« Reply #45 on: Fri, 05 July 2013, 14:56:53 »
bad pic but his keys are beautiful  ;D
« Reply #46 on: Fri, 05 July 2013, 23:12:55 »
Cool!  Hope you ordered some yellow ;)
Offline Potologue
« Reply #47 on: Thu, 11 July 2013, 18:08:32 »
Got my poker 2 with metallic poker set and hapster today. It's significantly more pimp in person than in pictures.
« Reply #48 on: Fri, 12 July 2013, 11:13:38 »
