Author Topic: IBM key caps  (Read 64740 times)
Offline wcass
IBM key caps
« on: Sat, 01 June 2013, 13:30:25 »
Function keys
24029-0
Arrows
24033-1
Terminal symbols
24035-2
Terminal text
24037-3
Blue legends
24039-4
the tenkey caps with this set have black numbers and blue text/arrows
« Last Edit: Sat, 01 June 2013, 14:30:04 by wcass »
Offline megaxpop
Re: IBM key caps
« Reply #1 on: Sat, 06 July 2013, 09:39:27 »
it looks so nice after many years! :D
Re: IBM key caps
« Reply #2 on: Sat, 06 July 2013, 21:37:24 »
I have a set of IBM keycaps with CAD symbols front printed that I can photograph if you like. I also have some medical keycaps, but those are from unicomp, so not sure if you want them. One of the "model C" keyboards has F1-F12 front printed on the numberrow, though I don't have it. I have also catalogues two types of the "bottom half" of a keycap and four different variations of relegendable (clear) tops.
Just say what you need and I'll take pictures.
Offline wcass
Re: IBM key caps
« Reply #3 on: Sat, 06 July 2013, 21:51:02 »
i think it would be OK to post all "IBM compatible" key caps here; so Unicomp, Signature Plastics, moogles even.
stems, stabilizers, and barrel inserts are part of the cap too, so feel free to post pictures of those. they may be useful references for wiki and forum posts.
« Last Edit: Sat, 06 July 2013, 21:53:14 by wcass »
Offline listokei
    • ListoKei Blog
Re: IBM key caps
« Reply #4 on: Mon, 12 August 2013, 07:56:10 »
Terminal symbols, Blue legends looks great!!!!  :thumb: :thumb:
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
Re: IBM key caps
« Reply #5 on: Mon, 12 August 2013, 23:32:04 »
keep an eye on those F keys. the_ed has been known to kill* for F keys ordinally larger than F12.
*in a non-fatal way
Offline wcass
Re: IBM key caps
« Reply #6 on: Tue, 13 August 2013, 20:13:20 »
*in a non-fatal way
i've been know to give away anything i am not using. and i don't use most F keys and certainly none above F12.
i plan on bringing a box of caps to the KeyCon, so if anyone is looking for a missing cap ...
Re: IBM key caps
« Reply #7 on: Tue, 13 August 2013, 20:32:45 »
*in a non-fatal way
I was, but a long way from KeyCon.
