Author Topic: Video Request: Typing on the ErgoDox  (Read 3529 times)
Offline daerid
    • Rossipedia
« on: Fri, 07 June 2013, 18:45:13 »
I still have a few more supplies to get before I put mine together (iron needs a new tip), but I'm really curious to see how this thing types. Would it be possible for one of you who have one built to post a quick video? Thanks in advance :D
Offline Sai
Re: Video Request: Typing on the ErgoDox
« Reply #1 on: Fri, 07 June 2013, 19:28:49 »
ahaha. this is what i am waiting for as well. it's strange that no one posted a video yet.
Offline WhiteFireDragon
    • youtube
« Reply #2 on: Fri, 07 June 2013, 22:16:37 »
Plenty of people have these, but I'm guessing not very many are "fluent" at it yet.
Offline Larken
« Reply #3 on: Sat, 08 June 2013, 02:06:33 »
as requested.
basically this is a video of me typing this actual post, although I did go back and edit away certain bits of the post where I start rambling away to keep my fingers moving, so the actual post is a lot shorter than what it originally was when I finished the video. You can watch the full 2 minutes if you want, but its basically the same thing for the entire shot. And if you see me hitting backspace alot at first - its mainly because I haven't had my morning coffee yet.
« Last Edit: Sat, 08 June 2013, 02:09:10 by Larken »
| Ergodox #1 | Ergodox #2 |
Offline Rayne
  • For Science!
« Reply #4 on: Sat, 08 June 2013, 02:19:00 »
this really makes my want to try typing on one of these
Offline Jocelyn
  • 조셀린
« Reply #5 on: Sat, 08 June 2013, 02:21:06 »
as requested.
I just KNEW you were going to be the first person to post a video. Thanks for sharing :)
Offline le_doosh
« Reply #6 on: Sat, 08 June 2013, 02:21:33 »
That looks pretty cool actually. I want to try it
Offline Sai
« Reply #7 on: Sat, 08 June 2013, 02:22:45 »
as requested.
when are we meeting? i want to try !!  :p
Offline Larken
« Reply #8 on: Sat, 08 June 2013, 02:29:00 »
@Jocelyn - Would have done it earlier if my earlier attempt didn't crash and burn (camera autofocus failed the first time - which was why the ergoclear typing sound was an mp3 instead of a video) But this time I set it manually. :)
@Sai - we'll have to ask aranair on that, lol. I'll send him a pm later and see if he can set a date for our meet up.
Offline Sai
« Reply #9 on: Sat, 08 June 2013, 02:40:28 »
alright. thats ok by me
Offline daerid
    • Rossipedia
« Reply #10 on: Sat, 08 June 2013, 02:46:13 »
as requested.
Perfect! Thank you :) If I may ask, what switches/springs/lube are you using? And also layout.. I'm having a hard time figuring out what layout I want to use. I'm a programmer, and the default layout isn't very code friendly.
Offline Jocelyn
  • 조셀린
« Reply #11 on: Sat, 08 June 2013, 02:46:57 »
Huhuhu :)
Offline Larken
« Reply #12 on: Sat, 08 June 2013, 02:52:32 »
ergoclears, 55g springs, superlube oil/grease mixture for stems and sliders, victorinox for springs, stickered. I may switch to krytox if I find it a huge improvement (I'm planning to test it out on another ergodox set when I get 103).
I'm not a programmer, but I write alot, so the layout I'm using might not be too good for you. Feel free to use it as a starting point to tweak your own layout though.
https://www.massdrop.com/ext/ergodox/?referer=7M8A25&hash=67acd02637046ec51918de37912db51c
    • youtube
« Reply #13 on: Sat, 08 June 2013, 04:53:45 »
I noticed you only use the tip if your right thumb to press the key, but use the whole left thumb to press the key.
Offline Larken
« Reply #14 on: Sat, 08 June 2013, 06:24:48 »
yea, all my bad habits are showing through now that I am used to the matrix layout of the ergodox - you probably noticed that I don't rest on the home row either, and just on the F and J scoops, and I don't always press pinky column keys with the pinky. I actually did do all the correct finger pressings to its corresponding columns when I first began to use the ergodox, but I have no idea what happened in between.
The thumb thing has a lot to do with how the keyboards are positioned in relation to my body and the angle it is tilted at. I just do what feels comfortable and that was apparently it. I really do use the backspace (left thumb) and space (right thumb) the way you pointed out in regular use.
