Author Topic: [IC] ALPS ansi key cap set (07-25 update)  (Read 55689 times)
Offline calavera
« on: Wed, 17 July 2013, 02:36:12 »
I will try to keep this as simple as possible.
This is an interest check for Alps DCS profile double shot keycaps to go hand in hand with my ALPS PCB/plate project.
Color inspiration
Actual SP color: BFP/GC combo
Divided into the following three sets.
  • Set 1: 89 keys (TKL)
  • Set 2: 17 keys (Numpad)
  • Set 3: 11 keys (Mod kit)
  • Set 4: Vintage set (Mod kit)
  • May or may not be in the final order
Combo stems:
Side stems will be cherry mount only.
07-25 update
Looking into stem locations and stab wire options. Any help/pics of your alps board would be appreciated.
« Last Edit: Sat, 27 July 2013, 13:05:52 by calavera »
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
Re: [IC] ALPS key cap set (ANSI)
« Reply #1 on: Wed, 17 July 2013, 02:44:23 »
I would take it in the time you say ALPS.
Considering that this is one of the few (the only) ALPS project, maybe the color combo is a bit weird (ie: dolch replica alps would probably have more success) BUT I like it!
PS: I'm updating right now the keyboard color chooser with calibrated colors! Check it in an hour or so!
Offline calavera
« Reply #2 on: Wed, 17 July 2013, 02:48:27 »
Here are some other colors combos I did:
« Reply #3 on: Wed, 17 July 2013, 02:57:55 »
That second one is sexy.  I might be in for a set depending on pricing and how much money I have at the time.
Offline AKIMbO
  • HHKBro
« Reply #4 on: Wed, 17 July 2013, 06:14:54 »
Mmmm tasty alps key caps.  I like all the color combos. Dolch replica would be even better then the space cadet color scheme.
| KBD75 (box reds)
« Reply #5 on: Wed, 17 July 2013, 06:18:11 »
I like #2 can we call it batman!
« Reply #6 on: Wed, 17 July 2013, 06:18:30 »
I'd buy a set or three probably! And I like the Space Cadet themed one
« Reply #7 on: Wed, 17 July 2013, 06:43:49 »
Did SP fix whatever issue they had with the stabilized keys? Melissa never got back to me about that.
Offline pasph
« Reply #8 on: Wed, 17 July 2013, 06:49:38 »
in that set there will be also a 1,75 shift?
Will all the stabs be Costar?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #9 on: Wed, 17 July 2013, 06:53:27 »
11 keys Tsangan has 1.75u shift.
My vote for stabs goes to cherry mounts (you can use costar or cherry stabs) very easy to find, but standard alps stabs would be fine too.
Offline pasph
« Reply #10 on: Wed, 17 July 2013, 06:57:41 »
Then why 89 Keys and not 87?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #11 on: Wed, 17 July 2013, 07:06:12 »
two versions of `~ and \| probably (just my guess)
Offline bazemk1979
« Reply #12 on: Wed, 17 July 2013, 07:18:23 »
calavera if this GB is related to the mini you should mention that 1.75 shift is included in the GB.
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #13 on: Wed, 17 July 2013, 07:50:49 »
Consider me in, I have hundreds of vintage Alps switches just waiting for a custom build.
Offline Sai
« Reply #14 on: Wed, 17 July 2013, 07:57:17 »
i like this set
i might be in for this since i am going to get ducky alps board soon.
do you have any price range in mind ?
Offline Tarzan
  • formerly known as Greystoke
« Reply #15 on: Wed, 17 July 2013, 08:00:29 »
Interested!
And another vote for the gray color option, perhaps a smidge darker, not so washed-out?
Offline bueller
  • MX baller
« Reply #16 on: Wed, 17 July 2013, 08:14:28 »
I actually like the colour combo in your "inspiration" photo, would love to see a mockup with grey alphas and the blue mods.
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #17 on: Wed, 17 July 2013, 08:17:39 »
I'm down. IIRC SP doesn't have all the molds for a complete TKL..
-Enzo Ferrari
Offline Tarzan
« Reply #18 on: Wed, 17 July 2013, 08:23:23 »
Yes, indeed.  Nice saturated colors.  I'd definitely be in for that color scheme.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #19 on: Wed, 17 July 2013, 08:25:58 »
they miss tooling for the stems of all keys over 1.75u (just the stems not the whole key)
Offline calavera
« Reply #20 on: Wed, 17 July 2013, 08:45:51 »
Updated post with mock up pics to show what keys are included in each set.
I asked Melissa about combo stems and she gave me tier pricing quote on the three sets so I think SP is capable of that at least. I'll update when I get a response of whether normal alps stab mount is possible for the full set. Then we move on to the stabilizer compatibility.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #21 on: Wed, 17 July 2013, 08:50:46 »
I totally love your color choice... BUT PLEEEEASE make an unbranded winkey! A diamond would be perfect, or add it as an option
Offline calavera
« Reply #22 on: Wed, 17 July 2013, 08:53:17 »
Yeah those are just space fillers to give you an idea of what the keys are. Nothing is final.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #23 on: Wed, 17 July 2013, 08:53:56 »
thanks! :)
Offline bueller
  • MX baller
« Reply #24 on: Wed, 17 July 2013, 09:54:16 »
I like the idea of a combo stem, 4 out of the 5 boards I've stripped have had Cherry stabs. Makes life a lot easier as well considering WASD sell the parts dirt cheap.
Offline calavera
« Reply #25 on: Wed, 17 July 2013, 11:03:21 »
Picked a few tones of blues, updated thread.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #26 on: Wed, 17 July 2013, 11:07:00 »
I would go for higher contrast (and better retro fidelity)
Recently Krogenar scanned the color ring and we finally have some decently calibrated pictures.
I think BFP is a great choice
28427-0
« Last Edit: Wed, 17 July 2013, 11:12:42 by Matt3o »
Offline calavera
« Reply #27 on: Wed, 17 July 2013, 11:16:00 »
I think BFK is closest to the inspiration pic. BO comes close in second I think. Not a big fan of all the others.
Offline calavera
« Reply #28 on: Wed, 17 July 2013, 11:16:37 »
Do you have a link to the calibrated scans?
Offline Tarzan
« Reply #29 on: Wed, 17 July 2013, 11:16:55 »
BFK would be my top choice.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #30 on: Wed, 17 July 2013, 11:20:37 »
http://www.flickr.com/photos/compactkey/9293611207/
Offline calavera
« Reply #31 on: Wed, 17 July 2013, 11:29:39 »
Thanks. Looks like BDH, BFK, or BO are all good choices. Does he have scans on the grey tones too?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #32 on: Wed, 17 July 2013, 11:32:36 »
yessir
http://www.flickr.com/photos/compactkey/9293654159/in/photostream/
(hint: just next/prev in the link I gave you to discover a wonderful world of colors :) )
Offline calavera
« Reply #33 on: Wed, 17 July 2013, 11:51:23 »
I picked the closest color and narrowed it down to these:
Fonts don't have to be white either, could be orange.
EDIT: Going through round 4 and found a similar theme has been done.
http://deskthority.net/resources/image/8196
http://deskthority.net/marketplace-f11/doubleshot-replacements-round-4-t1376-3960.html
http://deskthority.net/wiki/Round4_SPH
« Last Edit: Wed, 17 July 2013, 11:55:55 by calavera »
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #34 on: Wed, 17 July 2013, 11:55:44 »
« Reply #35 on: Wed, 17 July 2013, 11:55:52 »
Offline Batmann
« Reply #36 on: Wed, 17 July 2013, 12:05:43 »
Awesome, I would go BFP on GC
great idea Calavera
and also great mockups  ;)
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #37 on: Wed, 17 July 2013, 12:20:18 »
BDH is an old favorite of mine (it's the blue from my RGBY kits).  Interested!
Offline Tarzan
« Reply #38 on: Wed, 17 July 2013, 13:27:25 »
BDH with that white looks very sharp.  Nice contrast, and a rich color.
Offline UniClown
« Reply #39 on: Wed, 17 July 2013, 13:46:27 »
GC is much better than GSM. GSM almost seems to have a green/blue coloring in it as well whereas GC is a more pure grey.
Offline bueller
  • MX baller
« Reply #40 on: Wed, 17 July 2013, 14:05:07 »
Yeah I'd go BDH/GC, looks sweet.
Offline Tarzan
« Reply #41 on: Wed, 17 July 2013, 14:08:14 »
+1
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #42 on: Wed, 17 July 2013, 14:36:19 »
I'm on board for at least one set. And I like the the colorway of the OP., but open to the others as well.
« Last Edit: Wed, 17 July 2013, 14:38:17 by mashby »
Offline phetto
  • HHKB JP
« Reply #43 on: Wed, 17 July 2013, 15:09:34 »
Will these have those too-short-shifts like in R4?
Offline cgbuen
    • cgbuen.io
« Reply #44 on: Wed, 17 July 2013, 15:16:54 »
In. This pretty much gets rid of my fear of sourcing caps when thinking about building ALPS boards.
Offline agodinhost
  • Soylent green is people ...
    • Dr Ian O Xaman
« Reply #45 on: Wed, 17 July 2013, 15:33:48 »
Ahhhhhhhhh
I want this one
How much it will cost?
One eye? One arm?
Goshhhhhhhhhhh
Offline calavera
« Reply #46 on: Wed, 17 July 2013, 15:38:44 »
BDH/GC mock up.
Gonna work on a dolch theme now.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #47 on: Wed, 17 July 2013, 16:40:46 »
BDH/GC mock up.
Yep..........count me in big time. Gotta have tsangan and num pad.
dolch would be nice, but like your BDH/GC mock up as well ;D
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #48 on: Wed, 17 July 2013, 17:12:45 »
enough dolch, go for something original :)
what do you think of...
Offline bazemk1979
« Reply #49 on: Wed, 17 July 2013, 17:19:47 »
bad ass!!!
