Author Topic: TEX Beetle  (Read 6908 times)
Offline catherio
TEX Beetle
« on: Mon, 29 July 2013, 12:26:42 »
This is my first time posting a review, so I'm not sure yet what information will be of most use. That said, here are my impressions of the TEX Beetle keyboard, along with some photos. Hopefully people will find this information helpful. Please don't hesitate to get in touch if there's something else you'd like to know! (also posted at http://deskthority.net/keyboards-f2/review-tex-beetle-t6220.html)
-- Background and use case --
The TEX Beetle is my second-ever foray into the world of mechanical keyboards. My first mechanical keyboard was a KBC Poker that I borrowed from my friend Jesse for a few months. At that point my primary motivation had nothing to do with the feel of the keyboard - I was simply looking for a *small* keyboard to carry around, and he suggested I try out a tenkeyless to see if I liked it. I enjoyed the feel of mechanical keys so much that I now use a tenkeyless mechanical keyboard as my primary keyboard even when I'm docked into an external monitor. I've now returned the Poker to Jesse and swapped it out for this TEX beetle of his that I'll be borrowing for a few more weeks until the one I ordered shows up.
To tell a bit more about my use case, most of my computer use is coding and writing, not gaming. I have a single X-series laptop that I use for everything. At home and at work I plug it into an external monitor. I also like to work in libaries and coffee shops, and while traveling on trains and planes. When I'm away from the office I use a laptop stand and collapsible mouse in addition to the external keyboard, to ensure a neck-strain-happy setup:
-- Layout --
A few notes about the layout of the TEX beetle.
- The mini-USB port is in the top left.
- The arrow keys are normal-sized, and accessible without doing anything special. I really appreciate this because I use the arrow keys a lot when I'm coding in an environment other than an emacs buffer (like when I'm writing MATLAB). You can see they're actually even larger than the arrow keys on a Lenovo X-series laptop.
- The top-left key is escape, not tilde. Tilde is to the right of the up-arrow.
- Some keys are accessible using the X-shaped function key:
  - Pg Up and Pg Dn live under O and L. I find this to be a very accessible place for them: I can press the X key with my thumb and access them easily. Home, end, and so on are all in the same neighborhood.
  - Delete lives under Backspace. This is also intuitive and accessible.
- The right-shift is tiny. Fortunately this doesn't bother me: the KBC Poker had forced me to adapt to left shift, because on that layout right shift doubled as the up-arrow. But if I try to use right shift on the TEX beetle, I end up hitting the question mark key most of the time.
- If you want to change anything about the layout, like switching caps lock and control, you can use the function keys to toggle swaps L1 through L7, as shown in a diagram on the bottom of the keyboard. A series of lights indicates the currently active mapping.
-- Shape, size, appearance --
There's nothing unexpected about the outward shape, size, or appearance of this keyboard, so I'll just provide a few pictures to give you a sense of what it looks like:
This picture should give you an idea of the keyboard's size keyboard relative to my hand.
Here's a shot of the shaping/angle of the keys.
And here's the printing on the keys, to give a sense of the font.
-- Construction --
My first observation about this keyboard was that it feels very durably built. The metal frame has quite a bit of heft to it. Also, you can see in these photographs that the keyswitches are not attached directly to the circuitboard, but instead are mounted on the frame. This is in contrast to the Poker, which has the keyswitches directly attached to the cirbuitboard.
Mounting the keyswitches on the frame instead of the circuitboard has a number of effects, all of which I really appreciate. First of all, the frame does not have any "give", whereas a circuitboard is bendy. As a result, with the TEX Beetle (as contrasted with the Poker) it feels like the keys have less travel and take less force to press. With the Poker, the springiness of the circuitboard actually did add some additional travel distance.
The reduced springiness also makes it feel more like my fingers are "floating" on the keys, psychologically speaking. It's easier for me to pay attention to not bottoming out and not clacking hard on the keys, which gives the appearance at least of being less tiring on my hands (I'm not sure whether it makes an actual physiological difference, but it feels more pleasant!)
Finally, and very importantly, this keyboard is *quieter*. I think that's a a joint function of the construction itself and the reduced desire to clack obnoxiously on the keys.  The one potential downside is that this keyboard is heavier than the KBC Poker normally is. That said, the Poker I was borrowing from Jesse was one he had augmented with additional weight to make it feel heftier and slide around less. The additional weight in the TEX Beetle certainly makes it feel solid and stable, even if it makes it more annoying to carry around in my backpack.
-- Verdict --
Good enough to spend money on - I have ordered one of my own!
Pros: Well-constructed, quiet, function keys and arrow keys are easy to access, layout is easy to change. Good feel - very "solid".
Cons: Right shift is small, frame is heavy.
« Last Edit: Mon, 29 July 2013, 12:29:05 by catherio »
Offline Hypersphere
Re: TEX Beetle
« Reply #1 on: Mon, 29 July 2013, 16:54:35 »
Thanks for an excellent review. I have had the Tex Beetle in my sights for some time, as I am looking for a 60%-size keyboard, preferably with dedicated arrow keys, a highly intuitive Fn layer, excellent build quality, and easily replaceable keycaps.
Thus far, I have found that the Leopold FC660M comes closest to meeting these criteria. My only quibble with the Leopold is that its layout, while eminently practical, is not as aesthetic or symmetrical as a purely 60% or a fully tenkeyless board.
Therefore, my search continues. With these criteria in mind, what are your views on the relative merits of the Tex Beetle, Poker II, Pure Pro, Leopold FC660M (Cherry switches) or FC660C (Topre switches), Filco Minila, HHKB Pro 2, or others in the ~60% category?
Offline Sniping
Re: TEX Beetle
« Reply #2 on: Mon, 29 July 2013, 17:00:47 »
^ I do recall him saying that this is his second mechanical keyboard. That being said, you can't really compare MX keyboards to Topre ones, they're very different in feel, so it's more of a choice in preference. imo this looks better than the FC660M and Filco Minila but that's preference as well.
Offline Hypersphere
Re: TEX Beetle
« Reply #3 on: Mon, 29 July 2013, 18:43:03 »
Good point. Thanks also for voicing your preferences. Despite the fact that personal choices in keyboards are often subjective, they contribute to the collective weight of evidence against or in favor of a given product. This can help others with their decisions, especially if reasons are given for the preferences.
Offline Thimplum
  • Master of all Ponies
Re: TEX Beetle
« Reply #4 on: Mon, 29 July 2013, 18:45:42 »
^^^^ For thinkpad
TP4 FOR ADMIN 2013
Offline Thimplum
Re: TEX Beetle
« Reply #5 on: Mon, 29 July 2013, 18:47:11 »
Nice review, by the way.
Unless it's a G81.
TP4 FOR ADMIN 2013
Offline catherio
Re: TEX Beetle
« Reply #6 on: Mon, 05 August 2013, 21:29:28 »
Right, this is only my second keyboard, so I can't offer a lot of compare-and-contrast. Glad to have provided a helpful review nonetheless! (Also, @Sniping: s/him/her, s/his/her =P)
Offline PointyFox
Re: TEX Beetle
« Reply #7 on: Mon, 05 August 2013, 21:32:15 »
Nice shootin' there, Tex.
