NEW USERS, READ THIS!
will you do it in 45g spring?
Are you planning to sell the dark grey spring if you decide to mod it with another custom springs? I am quite interested in heavy springs
These are the same stems as reds right? Accept for the stem color of course
PRICE DROP - £50 for 104 fully lubed switches. TAKE THESE OFF MY HANDS!!!
Quote from: Photekq on Mon, 05 August 2013, 14:32:44PRICE DROP - £50 for 104 fully lubed switches. TAKE THESE OFF MY HANDS!!!What if someone doesn't want them lubed or springs swapped?
How much will that be in USD?
Quote from: daerid on Sun, 04 August 2013, 11:23:3445g case mounted topre > 55g plate mounted topre > 45g plate mounted topre > 65g Plate mounted Ergo Clear > plate browns > plate reds > plate bluesyeah i thought ergo clears had to be less than 65g.
I thought stock clears springs are 65g?
TOO BAD FOR YOU
Quote from: jonathanyu on Mon, 05 August 2013, 14:52:02How much will that be in USD?Roughly $60
I will take the heavy springs if the buyer decide to have the spring swapped.
