Author Topic: ANSI Model F AT mod - 8.25.2013  (Read 20719 times)
Offline The_Beast
  • I like wood ಠ_๏
« on: Mon, 19 August 2013, 14:09:31 »
So AKIMbO was nice enough to trade me his Model F AT! It's a great board, however it's not prefect. So I plan on:
 - 2x backspace
 - Standard ANSI enter and \| key
 - Making the spacebar uniform to the rest of the keys
 - sanding and re-painting the front plate (it's a bit rusty)
 - And maybe replacing the LEDS to a nice blue color
This is the standard layout Model F AT
As you can see, I've already taken apart the entire thing and I want to get this done as soon as possible.
Got my plate painted today
Here are some pictures of the foam backer as well
I had 2 small rust spots on the back plate. Sucks that I had to mess up the amazing finish, but it had to be done. Plus, I'll almost never see it so it's not a huge deal
And I can't believe how good the PCB looks!
I'm just waiting on barrels and then I should be done with this mod other than an external Soarers box
« Last Edit: Sun, 25 August 2013, 01:33:24 by The_Beast »
Offline Techno Trousers
  • ʘ_ಠ
Re: ANSI Model F AT mod
« Reply #1 on: Mon, 19 August 2013, 14:21:41 »
Nice! Looking forward to this one. I have an F 122 with a new homemade foam mat ready to go back together, but I need to get some more spring clamps to make that possible.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #2 on: Mon, 19 August 2013, 14:22:21 »
So you need to replace thet foam mat?
  • ʘ_ಠ
« Reply #3 on: Tue, 20 August 2013, 00:22:11 »
I hand cut a new one from some art store foam, since the original was falling apart when I opened the keyboard. Now I just need to compress the plates and foam pad back together under the tabs if I can. I may have to do the fohat.digs bolt mod method, but I'd prefer to avoid drilling if I can. I'm planning to get some extra clamps so I can compress and slide everything together. I need about six hands for that beastie!
Offline The_Beast
  • I like wood ಠ_๏
« Reply #4 on: Tue, 20 August 2013, 00:28:39 »
The foam mat I have is pretty nice yet. I'll have to post some pictures of it.
Now I just need to decide whether or not I'm going to do an internal or external Soarers mod.
External I could use with another model F (if I ever get one) and it would keep the stock look.
Internal I loose the super long cable (which would be nice) but I'm not sure how well I could make the detectable cable look...
« Reply #5 on: Tue, 20 August 2013, 06:37:18 »
Get the clamps at Home Depot.
I am re-writing the guide and plan to remove the part about cutting off the tabs.
I have come to the conclusion that it was a bad idea.
"The Trump campaign announced in a letter that Republican candidates and committees are now expected to pay “a minimum of 5% of all fundraising solicitations to Trump National Committee JFC” for using his “name, image, and likeness in fundraising solicitations.”
“Any split that is higher than 5%,” the letter states, “will be seen favorably by the RNC and President Trump's campaign and is routinely reported to the highest levels of leadership within both organizations.”"
Offline wcass
« Reply #6 on: Tue, 20 August 2013, 11:39:17 »
you can use binder clips (office supply) for clamps too.
for replacement foam, i like 1/16" neoprene from McMaster-Carr. cheap and available in extra soft, soft, firm.
http://www.mcmaster.com/#8647k102/=o5cbw5
  • ʘ_ಠ
« Reply #7 on: Tue, 20 August 2013, 12:28:39 »
Ooh, that's a great tip. I was going to use art supply foam, but it's more like 1/8" thick and smells kind of funny. What density do you use?
Offline Moosecraft
  • HHKB Pro
« Reply #8 on: Tue, 20 August 2013, 12:36:49 »
Looking forward to see your work. I've always wondered how a Model F feels like even though all buckling spring keyboards scare me away because of their high actuation force.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #9 on: Tue, 20 August 2013, 13:10:18 »
Ohhh, he speaks! Do I have to replace the foam if the original one is still in good shape?
I like 55g clears and 55g blacks. I also love BS boards...... so I wouldn't worry about it too much.
« Reply #10 on: Tue, 20 August 2013, 14:38:07 »
You do not have to replace the foam unless it has deteriorated badly. I have re-used some pretty ugly ones.
The art foam I got was no more than 1/16" thick and came in fancy colors.
If anybody buys a sheet of neoprene and wants to sell pieces (about 8" x 20") I would buy one or 2 if the price was good.
Offline sleepy916
« Reply #11 on: Tue, 20 August 2013, 14:43:15 »
Yeah putting back a 122 F with your bare hands is damn near impossible. My restoration is on hold until I can put the sucker back too.
Offline wcass
« Reply #12 on: Tue, 20 August 2013, 15:01:09 »
i don't recall if i used soft or extra soft when a replacement was needed, but if your foam is in good shape, keep using it.
do you plan on splitting the space bar to add "alt" keys?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #13 on: Tue, 20 August 2013, 15:05:54 »
That's great! I think it looks pretty decent. It's pretty flat, but there are no rips in it. If not, there are a few local fabric stores where I might be able to pick up a foam or neoprene sheet for cheap
I really don't use alt that much so I'm going to keep the standard spacebar.
Offline Moosecraft
  • HHKB Pro
« Reply #14 on: Tue, 20 August 2013, 15:32:31 »
[/quote]
Well I do wish to try one eventually but right now I'm still exploring cherry land :p
« Reply #15 on: Tue, 20 August 2013, 15:40:48 »
In my guide, I showed 2 spring clamps on either side, and a long clamp to make it slide. That is about $20 in clamps from Home Depot but it makes the assembly simple, clean, and easy.
If you know any carpenters, they are sure to have them.
  • ʘ_ಠ
« Reply #16 on: Tue, 20 August 2013, 15:41:02 »
Sounds like a lot of us are doing this project, in one way or another! fohat.digs, I'm about to buy 2 feet of the super soft to try out. I should be able to make 6 8x21 sheets out of that, and I only need four sheets (2 F 122s, and two spare sheets for future use). I'll send you the two extra pieces when they come in.
Offline sleepy916
« Reply #17 on: Tue, 20 August 2013, 15:55:13 »
I need a long clamp, I did buy two clamps and tried doing it by tapping a hammer on one end but it never fully locked in. I will try it with a long clamp when I get time after moving.
« Reply #18 on: Tue, 20 August 2013, 16:09:02 »
I know that the long clamp might cost $10-$15 but you need it.
No doubt you now understand that there are 200+ little parts that need to stay precisely in place whilst you wrestle this wildebeest.
With everything clamped and < slowly > moving sideways and horizontal, you can get it all perfect, using lots of pressure, and nothing will jump out of place.
  • ʘ_ಠ
« Reply #19 on: Tue, 20 August 2013, 19:16:25 »
If anyone has a Harbor Freight tools nearby, you should be able to get some cheap clamps. I wouldn't buy tools there to use for serious woodworking purposes, or expect them to last a long time, but for this kind of use it should be fine.
  • ʘ_ಠ
« Reply #20 on: Tue, 20 August 2013, 19:30:47 »
Actually, this looks like a really sweet pipe clamp that would be totally perfect for this project. $10 apiece, plus the cost of some 3/4" pipe. I already have a pair of bar clamps or I would probably get this. They also have 3" spring clamps for $3 apiece, so I'll be picking up four of those.
http://www.harborfreight.com/3-4-quarter-inch-pipe-clamp-with-base-94053.html
Offline JBert
« Reply #21 on: Wed, 21 August 2013, 06:19:08 »
I did get an XT back together using four clamps, a hammer and some pieces of wood to spread the impact. You should keep the caps off, and then it's just the spacebar which can be a problem.
I managed to beat that one too using some fishing wire to keep it in its position, though I'll have to look up if I still got the pictures from before the great GH blackout.
The storage list:
Currently ignored by: nobody?
[/SIZE]
« Reply #22 on: Wed, 21 August 2013, 07:28:37 »
The small ones (XT & AT) are relatively easy. I have done them by hand without undue problem, but I have big strong hands.
To hold the spacebar in place, I used a loop of thread with a weight (I used a wrench) going around the stem (the mechanism was upside down, of course) as I slid it together. Afterwards, I simply pulled the thread back out.
Offline The_Beast
  • I like wood ಠ_๏
Re: ANSI Model F AT mod - 8.21.2013
« Reply #23 on: Wed, 21 August 2013, 19:12:35 »
Got my plate painted today! More updates in the OP!
Offline wcass
« Reply #24 on: Thu, 22 August 2013, 22:40:15 »
a very nice job on that plate.
i noticed that all of the stabilizer mounts are missing. will you be putting them back in?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #25 on: Thu, 22 August 2013, 22:44:10 »
I did take them out to paint it. I don't think I'll be adding them back one since I just just use some inserts and model M caps
Also, I noticed 2 small rust spots on the back plate so I painted those. Kinda sucked since the finish on the back plate is super cool, but I'll never see it again unless I open the case so it had to be done.
Offline YakMN
« Reply #26 on: Thu, 22 August 2013, 23:33:48 »
I just got a Model F AT in today, and am looking forward to doing an ANSI mod. I would like to do backspace bigger, move blackslash, shrink down enter, and put in a shorter space bar so I can add in extra modifier keys (basically make it like a Model M layout in the core area).
I see references to a guide to a model F ANSI mod, but I can't find it. I search around a bunch, but it's hard to search for "Model F" on GH. The forum finds F's everywhere. I found these guides:
http://www.teamliquid.net/forum/viewmessage.php?topic_id=260143&currentpage=251
http://geekhack.org/index.php?topic=8893.0
I still have a couple questions:
1. to do the space bar shortening, do I drill new holes through the metal backplate? (I havent' disassembed this one, but it looks like you would need to make your own holes from other people's pics).
2. What is a good source for donor barrels? I have a Model F XT around that I don't use, but I'd prefer not to sacrifice it unless necessary. I have a lot of Model Ms (I rather foolishly assumed I should buy some extras to last me, as they broke down. That was 10 years ago, and I'm still on the first one (of course), but Model Ms look like a big solid sheet of plastic.
3. stabilizer inserts... is there a source for these?
I'm thinking bright orange or something for the backplate painting. The blue above looks great, but it isn't maybe very visible once the keys are back on? Maybe just hard to see in a photo?
« Reply #27 on: Fri, 23 August 2013, 07:12:31 »
For the Enter and Backspace question, you can use the same technique that I showed for the larger Model F.
http://geekhack.org/index.php?topic=37753.msg939433#msg939433
I don't remember the barrel setup for the spacebar on the AT, but the spacebar has to accommodate the existing understructure, unless you plan to add a dummy barrel to accommodate another spacebar. The location would have to be perfect and it would be tricky.
I have not had an F-AT apart in a long time, and don't remember the PCB layout, but every existing switch probably has a barrel hole associated with it, even if it is empty.
The F-122 barrels have a "buttress"-like alignment tab on the barrel itself at about "4:00-o'clock" on the side, and the XT uses an upright rounded stud separate from the barrel at "6:00-o'clock" I do not remember which type the AT uses. I have spares of both, if you want to PM me.
You can get barrel insert stabilizers from a Model M (presumably you are parting out the worst one for your keys) by fishing them out with a bent paper clip. Be careful not to damage the inside surface.
« Last Edit: Fri, 23 August 2013, 07:57:26 by fohat.digs »
Offline wcass
« Reply #28 on: Fri, 23 August 2013, 20:40:11 »
here is a link to my project. it was from before the blackout, so pictures and attachments are missing, but instructions for adding ALT keys and M space bar (and stabilizer) are there.
http://geekhack.org/index.php?topic=25919.0
you might find the templates for new foam pad and cutting the barrel plate (ALT keys mod) useful, so i'll re-post them here for anyone that needs them. print what you need at 100% and check that the measurement matches the value. if it doesn't, you might need to scale to 99% or 101% to get it right.
« Last Edit: Fri, 23 August 2013, 20:41:46 by wcass »
Offline YakMN
« Reply #29 on: Fri, 23 August 2013, 22:21:20 »
fohat: thank you! That's the guide I was looking for. Kept seeing references to it. Pretty amazing write-up, by the way. So I can get the stabilizer insert thingie from another Model M: no problem. I'm going to have to steal a backslash, enter key, keypad enter, backspace, spacebar, and a couple 1.5x modifier keys anyway. So looks like I probably need 2 hammer assemblies and 2 or 3 barrels, depending on how the space bar goes. The AT barrels also have the buttress thing at 4 o'clock. In the photos, I would say they look identical to the 122 key barrels.
Wcass's mod, the he posted just above, must be where I got the idea for the short space bar + keys.
Wcass, your template doesn't show a barrel on the left side of the spacebar, acting as a stabilizer. Looks like from this photo anyway, that Model M spacebars expect a stabilizer barrel there? Did you have any trouble without using one?
Offline wcass
« Reply #30 on: Sat, 24 August 2013, 00:11:39 »
the M doesn't actually use that barrel. the space bar stabilizer is similar to the stabilizer on 2x model F keys - it uses a wire and wire hold-downs like an anti-sway bar on a car. i used folded sheet metal to make hold-downs and fixed them to the barrel plate with JB Weld. place one hold-down between the comma and period barrels and another between C and V. if you look at that picture of the M barrel plate, you will see them there.
Offline YakMN
« Reply #31 on: Sat, 24 August 2013, 07:56:53 »
Oh, I think i understand now. I thought that link was just bad. ;)
You don't use that product you linked to as the spring, you use it as the HOLDER for the spring bar, and you just re-use the Model M spacebar spring. right? That makes sense and is very straightforward.
Offline The_Beast
  • I like wood ಠ_๏
Re: ANSI Model F AT mod - 8.24.2013
« Reply #32 on: Sat, 24 August 2013, 15:34:07 »
Another update! I'm just waiting on some hammers and this mod should be done!
« Reply #33 on: Sat, 24 August 2013, 15:38:31 »
Replacing the foam is by far the hardest part of cleaning a model F. Good to see yours was in such great shape. I have some replacement foam that didn't work out, so now I'm trying it again with some felt.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #34 on: Sat, 24 August 2013, 15:39:23 »
I thought it didn't look that good, so it's great to hear that I can reuse it!
Offline sleepy916
« Reply #35 on: Sat, 24 August 2013, 15:41:39 »
More hammers? I remember having enough switching the setup to ANSI, unless you were going to mod the spacebar.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #36 on: Sat, 24 August 2013, 15:44:58 »
Hmm, thinking about it, I should have enough since the 1x \| can be used for the 1.5 sized one above the enter........
Akimbo said I needed one and he knows more about this then me.
Offline sleepy916
« Reply #37 on: Sat, 24 August 2013, 15:50:23 »
Unless you are doing something different with your numpad, like more single 1x keys, you won't need more.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #38 on: Sat, 24 August 2013, 15:51:42 »
Nope, just a ANSI enter and backspace. This is great! I might put it back together tonight then! I'll just have to steal some inserts and model M caps from my 65% M since I don't have enough.
Offline The_Beast
  • I like wood ಠ_๏
Re: ANSI Model F AT mod - 8.25.2013
« Reply #39 on: Sun, 25 August 2013, 01:33:41 »
oh yuss!
I also lighted the spacebar so it is more uniform! Now just a Soarers to get the number pad working how I want to without an AHK program.
« Last Edit: Sun, 25 August 2013, 02:44:54 by The_Beast »
Offline AKIMbO
  • HHKBro
« Reply #40 on: Sun, 25 August 2013, 10:49:11 »
Awww yusss.....nice F AT.
| KBD75 (box reds)
Offline Game Theory
« Reply #41 on: Sun, 25 August 2013, 11:12:36 »
Congratulations on the sweer F AT.
... he's just a poor kid from the stupid ages.
Realforce 104UG | Realforce 91U | IBM SSK | IBM 5251 BeamSpring | IBM Model F XT |  IBM Model F AT | IBM SSK | Filco Majestouch 2 TKL (MX Blue) | KMAC LE (MX Green)| Northgate Omni Key 101 | Avant Stellar Prime
Offline sleepy916
« Reply #42 on: Sun, 25 August 2013, 23:13:00 »
Good job, now clean that enter key on the numpad!
Offline The_Beast
  • I like wood ಠ_๏
« Reply #43 on: Sun, 25 August 2013, 23:21:22 »
That enter sucks. I have the white insert in the empty barrel, but that enter doesn't have the leg that goes inside the white insert so it isn't very stable. Same problem with the 0 key. :(
So right now I have a blank enter key that does have the leg and I'll need to find a printed set that has those. Maybe a printed unicomp set will do the trick
The one downfall is it sucks for gaming :(. Tried playing some BF3 and I couldn't jump while sprinting since I think this board only has 2KRO
« Reply #44 on: Mon, 26 August 2013, 07:12:00 »
Those long keys have either wire stabilizers or insert stabilizers, but not both. If you have tabs as you mention in post #26, then you can put them back in. Problem might be that F wires are thinner than M wires .....
Offline YakMN
« Reply #45 on: Mon, 26 August 2013, 21:54:45 »
Don't be afraid of the soarer mod. It's dead easy. I used the smallest breadboard I could find, to minimize soldering. I don't hate soldering, I'm just bad at it. I ordered the breadboard and a DIn-5 plug from mouser, and it literally took 5 mins to solder. there are only 4 wires! And then about 30 mins playing with the soarer config before I got what I wanted. Of course now I'll spend 3 hours making it fit pretty into the project box, but if you don't want an adapter cable, you could skip all that and just put it right into your AT case.
Offline Grr8
  • Quack!
Necro-Thread
« Reply #46 on: Sat, 19 April 2014, 12:10:47 »
Hi,
Since this has most of the information I needed for fixing up my AT Model F, I think this is the right place to ask.
And this is a very hard thread to find searching on Google...
Ok, I have a AT Model F. The foam has nearly completely disintegrated.
The issue I am having is key presses do nothing unless the keyboard is standing on the edge. Then it is intermittent.
Is this a bad foam issue, a loose assembly issue, or something else?
Thanks for any help.
Daily Driver: Poker II Backlit (Ducky Mini-fied) + Amazon o-rings. Future daily driver IBM AT Model F (restoring now). For fun: IBM SSK 1397681 (NIB), IBM SSK 1391472, IBM Industrial 101 Square label 1388032, IBM Industrial 101 Black label 1394946, IBM 1391401 (bolt-modding now), IBM 1370477, IBM 42H1292 (USA), IBM 52G9700 IBM, and more....
Ducky Shine w/Blues + WASD o-rings, Ducky Shine 3 TKL w/Browns + ebay o-rings, Rosewill RK-9100 w/Blues, Apple Wireless (slim), Apple Wireless White A1016, Apple Extended II ADB. Next? HHKB2Pro?
« Reply #47 on: Sat, 19 April 2014, 16:52:33 »
I discuss this in my guide.
http://geekhack.org/index.php?topic=48786.msg1122437#msg1122437
I think that the art foam sheets, $1 at Micheal's, are about as good as anything. Not to thin, not too thick.
Offline Grr8
  • Quack!
« Reply #48 on: Sat, 19 April 2014, 20:49:33 »
Hi,
Thanks read that all now, and will have to get organised with clamps and try it all again.
So the symptom of a plate not sitting together right is no key presses working?
Or is it a symptom of bad foam needing replacement?
« Reply #49 on: Sun, 20 April 2014, 09:39:38 »
These things are monstrously strong but fickle, too.
I have been working on one for a couple of weeks that looks and feels perfect but just won't play.
First, do you think that your problem is electrical or mechanical in nature? Do the keystrokes register with a proper click? You will sometimes get a nice click if the plates are wrong, but do make sure that your mechanical operation is right. Are some of them working, and others not?
The foot moving up and down changes capacitance, and that is a fairly narrow range. If the plates are too close together or too far apart, they will stay open or closed all the time instead of changing. If you have the sliding force fit positioned properly, you will likely have most keys working with some "zones" gone dark.
I have had boards which worked even though the original mat was a dead shredded sheet of gritty slime. Before I took them apart, that is.
