Author Topic: business cards  (Read 152628 times)
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
Re: business cards
« Reply #150 on: Thu, 09 October 2014, 16:48:41 »
Some of you who have placed recent orders have seen some of the new ones!
Those look great !3oilermaker. Going to have to place some order to nab those.  :thumb:
Offline Sorun
  • Chitos
Re: business cards
« Reply #151 on: Sat, 18 October 2014, 18:22:43 »
Like it a lot albeit I can't for the life of me get the middle key to work. Tried changing the switch and no luck.
Re: business cards
« Reply #152 on: Sat, 18 October 2014, 20:16:54 »
Have you tried shorting the two contacts using a piece of wire?  Maybe there is a small break in the PCB trace.
Offline Sorun
  • Chitos
Re: business cards
« Reply #153 on: Sat, 18 October 2014, 20:28:28 »
Yup with no luck
Re: business cards
« Reply #154 on: Sat, 18 October 2014, 23:07:03 »
The next step might be a clear close-up photo of the other side of the card, so someone who knows what they are doing can check if it looks ok.
Other then that, you might have to ask i3oiler for assistance.
Offline Sorun
  • Chitos
Re: business cards
« Reply #155 on: Sun, 19 October 2014, 04:21:20 »
Alright i'll get on that tomorrow when I have my dlsr. Might be soldering, but the other 2 came out good.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
Re: business cards
« Reply #156 on: Wed, 22 October 2014, 17:38:35 »
Can the expansion ports on these be used to wire a matrix on? As in, can I use it as a Teensy for a 2x4 matrix with the enabler PCBs?
I am asking because I have a 2x4 switch tester that I want to turn into a functional one.
EDIT: D'oh, after I went through this thread again I found my answer. Sounds like a challenge!
« Last Edit: Wed, 22 October 2014, 17:42:37 by JaccoW »
|||My other keyboards :
x
