Author Topic: Project -- Pixel #1: Wreck 'Em  (Read 3340 times)
Offline pixel5
    • pixel5
« on: Thu, 05 September 2013, 17:56:46 »
Was going to wait to post this until later, but I ended up acquiring the parts I need a lot sooner than expected. So I'm making this thread as a commitment to my new hobby: custom keyboard building! Hopefully as time goes on I'll be able to customize more and more about the keyboards I make. I've chosen to make my first one as a tribute to my alma mater; Texas Tech University.
This thread will be a blog of my progress with many pictures to come, including as much of a how-to guide to handwiring a keyboard as I can do. Planning stage is done, I can't wait to get my hands on it!
Planning
Form factor: 60%
Layout: ANSI Standard
Components:
  • Acrylic Case w/integrated plate
  • Teensy 2.0
  • Cherry MX Black switches (some vintage, I believe, going to try to make alphas and mods match each other at least)
  • More customization components, I won't be listing them yet.  :cool:
Next Step: Parts (In transit)
Update 1:
It's going to be a while before I can do much with this, so I'll post this in case someone was curious about the case/getting one for themselves. This is the Ali acrylic case in all black. I just want to say that the vintage black switches are pretty good. Just a hair lighter than standard blacks. I did blind tests to confirm it wasn't just placebo.
« Last Edit: Mon, 23 September 2013, 17:37:34 by pixel5 »
Poker II
Quickfire Rapid
BUY MY CRAP
Offline tjcaustin
  • King Klaxon
    • Buy stuff
Re: Project -- Pixel #1: Wreck 'Em
« Reply #1 on: Thu, 05 September 2013, 18:01:56 »
Red stems, black springs, bruh.
« Reply #2 on: Thu, 05 September 2013, 19:29:08 »
This is a project I can really get my guns up for.
Anything I can help with, just let me know.
Long live the Matadors!
Offline UniClown
« Reply #3 on: Thu, 05 September 2013, 19:46:13 »
Good luck. I'm interested on how your case will turn out.
Offline TheFlyingRaccoon
  • HHKB Pro
  • Cable maker and future engineer
« Reply #4 on: Thu, 05 September 2013, 19:47:52 »
Neat project, make sure to post lots of pics!
HHKB Pro 2   SmallFry Keyboard
Offline pixel5
    • pixel5
« Reply #5 on: Thu, 05 September 2013, 21:02:14 »
You went to tech?
Poker II
Quickfire Rapid
BUY MY CRAP
« Reply #6 on: Thu, 05 September 2013, 21:13:09 »
You went to tech?
Sure did. :)
Offline pixel5
    • pixel5
« Reply #7 on: Thu, 05 September 2013, 21:27:39 »
You went to tech?
Sure did. :)
I'M GONNA ASK THE QUESTION: What years?
Poker II
Quickfire Rapid
BUY MY CRAP
« Reply #8 on: Thu, 05 September 2013, 21:35:07 »
Sent you a PM.
A hint for the rest of you: I'm old. :P
Offline domoaligato
« Reply #9 on: Thu, 05 September 2013, 21:36:40 »
Planning
Form factor: 60%
Components:
  • Teensy 2.0
Sir you might want to add a metal poker plate to your list...
all acrylic cases to not allow the switches to lock into place using a acrylic plate because the acrylic plates are too thick.
with ali's case that I sold you, you can use a metal poker plate to lock the switches in place together with the acrylic plate.
the case that is one the way comes with 2 plate layers.
one of the 2 will not be used when you are utilizing a metal plate.
I would suggest you find one with the removable switch hole design.
If you can't find one in the classifieds then the_beast may be able to help you.
If you need any help with this I can also assist as I have already hardwired a alps keyboard also.
Offline pixel5
    • pixel5
« Reply #10 on: Thu, 05 September 2013, 21:45:55 »
Why would it come with a plate fitted for Cherry MX switches if the switches couldn't lock into it? That makes little sense to me.
Poker II
Quickfire Rapid
BUY MY CRAP
« Reply #11 on: Thu, 05 September 2013, 21:48:25 »
It's meant to be used with a Poker PCB, which has mounting holes for PCB-mount switches.
I have extra SS Poker plates if you need one.
Offline domoaligato
« Reply #12 on: Thu, 05 September 2013, 23:45:36 »
the switches are normally soldered down to the pcb so they really do not need to lock into the plate because the thickness of the 2 acrylic plates together takes up all the extra space that would normally sit between the plate and pcb.
the case is very very stable for a acrylic case and has very little flex.
You will like it a lot.
I would also take jdcarpe up on his offer as that is really the best way to accomplish what you are looking to do.
Offline pixel5
    • pixel5
« Reply #13 on: Mon, 23 September 2013, 17:38:03 »
Did a small switch/case test. See OP.
Poker II
Quickfire Rapid
BUY MY CRAP
