I tested this "vintage black vs modern black" a while ago, and here's what I found. First off, for those that test a switch or two and make the claim that one is smoother than the other, is bogus. Not only do you need to test very large sample sizes, but you need to be sensitive enough to differentiate between scratchy and smooth.
I had 300 vintage blacks and 400 modern blacks, tested each one individually, and separated each type into 4 different boxes: extremely smooth, smooth, average, and scratchy. The vintage blacks had a higher percentage of smooth switch than modern switches (also implying that the modern blacks had a higher percentage of average and scratchy switches than vintage blacks). You can conclude that
you'll have a higher chance of getting smooth switches if you use vintage blacks, but this doesn't guarantee that every vintage black switch you use will be smoother than every modern black switch. I had a pile of smooth modern blacks, likewise I also had a pile of scratchy vintage blacks.
My personal keyboard uses both vintage blacks and modern blacks, but only the smooth ones. The extremely smooth switches went into the home keys (A,S,D,F) and most common letters (E,T,O,I,etc) according to
HERE.
ive tried new and old switches and i truthfully feel no difference. no linear switch has felt scratchy at all.
I can say with 100% confidence that there are clear differences between the smoothest ones and scratchy ones. It's no placebo. If you can't feel the difference, then simply your fingers are not sensitive to these things, so this whole topic is irrelevant to people that are less sensitive.
PS - moose and Dubsgalore, just get a room and go have sex already.
