@mkawa
really glad you like it so far.
What I forgot to mention: This will be rather a long-term project since I'm in university at the moment and only visit my parents once a month (that's where all the equipment is) - so I will have 3 weeks of planning and getting stuff followed then 1 week of getting the stuff done
Next visit will be around 24th so let's see what we can do till then
At the moment, I'm trying to figure out how the PCB is working. The capacitors are connected to the switches in one way or another, so I guess I can't just saw them off. I followed the conductor paths as far as I could (pretty difficult cause a lot is underneath the plate). I think, the problem is, that the speaker, memory etc. and the keyboard itself all have the same power source. On a PC keyboard you would have power supply over the PS2 port or anything. This one has a 6 Pin just for sending signals, and Power comes directly from the wall socket (230V in Germany - that's the red plug top left) and is spead all over the keyboard afterwards. There are some voltage converters though, so I guess the whole thing still operates with 12V. I'm not in expert in these things so this is important to understand for me.
So, I think we need a plan on how to build an alternate power circuit with 12V input over PS2 or USB port. Or would a Teensy or something already take care of that?
By the way, of course the big capacitors and things look awesome, but on the other hand, I don't want a 60% keyboard which is wider than my fullsize Qpad
So I don't know, let's see how the project goes first, but at the moment I would rather cut them off.
@Halvar: Wow, that's a possibility I would have never thought of, thanks
First thing that comes to my mind though when I see that, is that wiring under the keyboard would make the whole thing even higher when done. As I said, even without a case, it's more than 1cm higher than my QPad. I see it coming, in the end I will have to cut a hole in my desk for sure
But maybe I could place the controller somewhere between the switches and not underneath (there is about 6mm space between PCB and plate)... I'll keep it in mind and think about it, would be kinda the ghetto solution.
Edit: Just asking, I realised those diodes are kinda expensive (1€ each? If I'm not mistaking...) I could use the ones from a G80-1000HFD though.. hmm...
