Author Topic: Best home keycap printing methods.  (Read 5545 times)
Offline jmchargue
« on: Mon, 14 October 2013, 13:23:05 »
I refuse to believe that stickers are the only option for DIY key legends. Anyone have any experience with printing their own, or have heard of the best methods and practices?
Offline Linkbane
Re: Best home keycap printing methods.
« Reply #1 on: Tue, 15 October 2013, 02:48:28 »
You said that you don't want stickers, but most non-hand-done printing methods require expensive machinery. You might be able to ask imsto, feng, etc.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
« Reply #2 on: Tue, 15 October 2013, 03:05:51 »
Balderdash indeed.  If you can find a method that is reliable... let me know :D
« Reply #3 on: Tue, 15 October 2013, 03:36:51 »
If you would be content with side-printed caps, you could use waterslide decals, which looks much better than stickers.
There is waterslide decal paper for both laser and ink-jet printers available in hobby stores.
Offline terran5992
  • One With The Cup Rubber
« Reply #4 on: Tue, 15 October 2013, 04:07:33 »
You could use a permanent marker to draw on the blank keycaps or a sharpie knife to engrave them
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #5 on: Tue, 15 October 2013, 10:57:30 »
Dry transfer, and waterslide + clearcoat are two methods you can try out. If you use good protective clearcoating they can last quite awhile.
Offline apaskal
    • Pro et Contra gadget reviews
« Reply #6 on: Fri, 29 August 2014, 00:49:21 »
Is this good idea to use 500MW laser power DIY mini laser engraving machine?
http://www.aliexpress.com/item/-/1969154933.html
My personal blog —  Pro et Contra gadget reviews!
Offline berserkfan
« Reply #7 on: Fri, 29 August 2014, 08:26:10 »
Anyone knows about laser ETCHING machines? At that kind of price it is worth trying out if the engraving machine you linked to can also etch.
