Author Topic: Buying a filco - searching for Croatian layout caps  (Read 8631 times)
Offline Mirek028
« on: Mon, 28 October 2013, 05:40:54 »
Hi KeyboardCo,
I'm getting ready to buy a Majestouch2 full size in ISO layout with MX browns - but apparently the usually provided layouts are UK, German, French or Swedish-Finnish.
As I'd like to have a Croatian layout board I am looking into acquiring a separate keycap set in Croatian layout.
Before searching elsewhere, I'd just like to check if you offer or have the ability to procure such keycap set -or another solution.
Thanks in advance for the information :)
Offline wsjudd
  •  Moderator
    • The Keyboard Company Blog
Re: Buying a filco - searching for Croatian layout caps
« Reply #1 on: Mon, 28 October 2013, 06:49:25 »
Hi Mirek,
I'm afraid we just have what is available on our site - and while we do have a Croatian keyboard, we don't have any Croatian keycap sets. Sorry!
Cheers,
Will
Blogs & Social Media
Offline Mirek028
« Reply #2 on: Mon, 28 October 2013, 06:56:38 »
Hi Will, thank you for the feedback.
By "Croatian keyboard" I presume it means "not mechanical and not filco"?
If that is the case I will probably be purchasing the 105Key UK filco anyway, and try to find caps elsewhere. Your website says that 105key UK full size with MX browns are in stock - is that correct?
Thanks in advance.
Rgds,
Miroslav
Offline wsjudd
  •  Moderator
« Reply #3 on: Mon, 28 October 2013, 07:00:46 »
Hi Miroslav,
Yes, unfortunately it's just a standard rubber dome keyboard, not of much interest :)
And yes, we do have some UK 105 browns in stock:
http://www.keyboardco.com/keyboard/uk-filco-majestouch-2-nkr-tactile-action-keyboard.asp
Let me know if you have any other questions!
Offline Mirek028
« Reply #4 on: Mon, 04 November 2013, 12:05:13 »
Hi Will,
The Filco MJ2 arrived today and I couldn't be more impressed with it, typing is really a pleasure now - and I haven't even started really using it.
Many thanks to everyone at the Keyboard Co for the great service (and the coaster, too :) ). We will certainly be in touch again, I doubt this will be my last mechanical keyboard.  :D
Cheers!
Miroslav
Offline wsjudd
  •  Moderator
« Reply #5 on: Mon, 04 November 2013, 12:16:16 »
Really glad to hear that Miroslav! I hope you continue to enjoy your keyboarding, and feel free to share any feedback you have with us :)
