Author Topic: [SPRiT] R1 R2 (Shipping 92% Completed)  (Read 1783877 times)
Offline Grendel
Re: SPRIT Model 1 : PCBs 60% 75% 87% 110% : ANSI+ISO (Full LED + HW Macro)
« Reply #100 on: Fri, 08 November 2013, 17:16:09 »
Hm, that would mean USB is realized w/ a V-USB type stack since the Mega32A lacks a USB module (AFAIK. The Z-diodes in the parts list point to that too.) Certainly workable, would prefer an on-chip USB module tho (full speed, less load on the MCU.)
- I'm game !
Offline Jmneuv
« Reply #101 on: Fri, 08 November 2013, 18:08:56 »
You can find all the info on the designer's blog, here. It's the A.87
Can't find sprit's 'special edition' in there though, the usual A.87 doesn't support the mentioned extra key spots.
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
« Reply #102 on: Fri, 08 November 2013, 21:34:32 »
This PCB is Very New, Not Mass Produced Yet, So It will take time to put on that topic.
« Reply #103 on: Fri, 08 November 2013, 21:47:03 »
I feel special now :o
QFR | MJ2 TKL | "Bulgogiboard" (Keycon 104) | ctrl.alt x GON 60% | TGR Alice | Mira SE #29 | Mira SE #34 | Revo One | z | Keycult No. 1 | AIS65 | First CW87 prototype | Mech27v1 | Camp C225 | Duck Orion V1 | LZ CLS sxh | Geon Frog TKL | Hiney TKL One | Geon Glare TKL
Offline Fred
« Reply #104 on: Sat, 09 November 2013, 05:56:49 »
Looks cool, and the PCBs even have ISO! Maybe I missed it, but are there several possible layouts for the bottom row? Was looking at the 75% if that matters.
Offline sprit
« Reply #105 on: Sat, 09 November 2013, 06:43:30 »
Hello!  You can follow the 75% IC page !   :)
edited   :  http://geekhack.org/index.php?topic=49902.0
« Last Edit: Sat, 09 November 2013, 10:11:54 by sprit »
Offline Fred
« Reply #106 on: Sat, 09 November 2013, 08:37:20 »
Didn't find anything there, but I'm assuming there are a few possible layouts. I'm in on this!
Do I type here or fiddle with the google doc? I'd be in for one 75% pcb.
Offline sprit
« Reply #107 on: Sat, 09 November 2013, 10:12:46 »
Thank You very much for Your Interest!
« Reply #108 on: Sat, 09 November 2013, 12:33:23 »
I want to run the values I calculated by people here to make sure they make sense.
all keyboards should work fine with 1500 ohm resistors
Example red LED Vf 1.5V
Example blue LED Vf 3.2V
The entire matrix is to be kept under 300 mA and 1500 mW to leave 200 mA or 1000 mW for the controller (just a guess)
Resistor value (1500 ohm)
Compatible PCBs (110%, TKL, 75%, 660%)
Red LED current (2.5 mA)
Blue LED current (1.3 mA)
Red total power (1417.5 mW) for 110%
Resistor value (1200 Ohm)
Compatible PCBs (TKL, 75%, 60%)
Red LED current (3 mA)
Blue LED Current (1.5 mA)
Red total power (1331 mW) for 80%
Resistor Value (1000 Ohm)
Compatible PCBs (75%, 60%)
Red LED current (3.6 mA)
Blue LED Current (2 mA)
Red total power (1377 mW) for 75%
Note, the above assumes the controller will need 200 mA (or 1000 mW) to work. This is just a guess.
Alaricljs taught me to aim for 3.0mA for LEDs and to never exceed 3.4mA to be safe. He gave me this handy link to make the calculations a breeze.
www.ledcalc.com
My hope is that this will help some people out who want to customize these PCBs or get into building custom backlit keyboards who have little to no experience in electronics. I used this for my LZGH.
The link will require you to fill in the following fields:
- Supply voltage = 5v (? See Note below)
- Voltage drop across = Each LED has a foreword voltage range that you can find in the item description on eBay etc. Use the lower end of the range to start with.
- Desired current = 3.0mA - 3.4mA
Number of LEDs connected = 1 (Since they are all fed individually)
When you hit calculate it will provide you with the nearest higher rated resistor. This is what you will need to buy. It will also show you the circuits total current consumption which should be close to what you entered as your desired current. (3.0mA - 3.4mA) This is for bright LEDs within a safe operating range. 3.4mA being brighter than 3.0mA of course.
NOTE: One thing I don't know is if all keyboards provide the same supply voltage. My LZGH was 5v. Are they all different? Can anyone answer this for me?
Anyway, playing around with this LED calculator should give you specific resistor values for all your keyboard building needs!
I hope this isn't derailing this thread too much. It is relevant after all.
I think you misunderstand the issue, sir. Alaric knows his stuff, but he was quoting safe values for an 87 key keyboard or smaller. If you run 108 LED's to 3.4 mA (even 3 mA) you will draw 324 mA just from that. Now it might work on a fullsize keyboard, but it only leaves 150 mA or so for the controller. As I said, I dont know what sort of current the controller will need, so I wanted to leave it at a safe  200 mA +
As far as LED calculators, of the 8 or so I've tried, I prefer linear's led wizard ( http://led.linear1.org/led.wiz ) for simple calculations like this one (ledcalc is not bad, just well suited to other sorts of led arrays. TG3 does a similar thing on the BL82, by stringing their led's into strings of two with a resistor)
Almost all modern LED's can operate safely at a much higher current than 3.4 mA. As long as you keep it under 10 mA you will most likely be safe and not burn the LED out (many are rated for 18 mA or more).
As far as supply voltage, I've yet to encounter a keyboard that doesn't use 5V, though I only have so many keyboards with LEDs. 5V is a good value, as it's readily available from USB / PS/2 and it's low enough that small resistance values are needed for current limiting.
I was able to find the following on winkeyless's page on the A87uEX
1. 키의 수가 많아졌으므로 Full LED를 PS/2에 연결하여 사용할 경우 텐키리스의 경우보다 저항값을 높혀주는 것이 안전 할 것으로 생각합니다.
하얀색/보라색 : 820 ->약1K
빨간색/노란색 : 1.3K -> 약1.6K
파란색/초록색 : 900 -> 약1.1K
1. The greater the number of keys Full LED jyeoteumeuro the PS / 2 when connected to the tenki nophyeo resistance values ​​than in the case of leases that are thought to be safe.
White / Purple: 820 -> approximately 1K
Red / yellow: 1.3K -> approximately 1.6K
Blue / Green: 900 -> approximately 1.1K
If a GH'er more knowledgeable in Korean than google translate would like to contribute a better translation, it would help understanding. I notice that his value for red  (1.3k-1.6k) is similar to my estimate of 1500
For a 1.5v LED, a resistor of 1.3K will result in 2.693 mA through each diode. Now looking at the blog, I see 111 key (matrix tenkey) and 108 key layouts. Taking the 111 key as a "safe" example, that will result in almost exactly 300 mA taken by the LED array (leaving 200 mA for the controller)
It also looks like you can wire up the numlock key on the tenkey separately (as a true numlock key) or as just another LED in the array, though it may require a jumper.
So I thought A87 boards were not assembled but with the MCU installed. I am just fine soldering the rest of the components myself. Are we getting everything soldered (even the LEDs) Maybe it's better to not have the LED resistors soldered, or maybe instead to produce a few different boards for people with different LED configurations. 1500 ohms should work for all LEDs regardless, but if I want mine to be as bright as possible with white or blue LEDs I will need to desolder some resistors and replace with lower value ones.
Finally: sprit you're awesome! Thanks for all the excellent work you're doing to get this group'buy to happen! I'll do what I can to support you.
« Last Edit: Sat, 09 November 2013, 12:49:52 by dorkvader »
Offline sprit
« Reply #109 on: Sat, 09 November 2013, 13:24:03 »
I have been doing revise his layouts and I do manage all the final  PCB designs for the International Users.
I'd like to summarize and show the simplest way, after our further discussions here.
Mr. Dorkvader suggested Two kinds of  PCB Versions :  All Parts 100% Pre-soldered  /  Only Controller parts and diodes pre-soldered.
I would follow You Guys Opinions as much as possible.
I have been preparing to provide Some Extra Resistors for LEDs,  With Each PCB.
High Quality Resistors and diodes might be provided for anyone need it for free.
« Last Edit: Sun, 10 November 2013, 00:27:24 by sprit »
Offline sprit
« Reply #110 on: Sat, 09 November 2013, 13:29:11 »
43299-0  43297-1  43303-2  43315-3
« Last Edit: Sat, 09 November 2013, 17:10:32 by sprit »
Offline sprit
« Reply #111 on: Sat, 09 November 2013, 14:42:22 »
*All PCBs are  1.6T Thick PCB, ANSI+ISO, All and All ! SMDs are Factory pre-soldered, the latest Firmware and KeyMap loaded and Tested.
  100% Red Alert! Ready for the Full Functionality.
Excellent!
Now I've made it no secret I'm disappointed with the KMAC's programming (some options, like toggle function keys is listed as an option, but doesnt' actually work)  and I'm worried about other upcoming PCB programming. I like how this comes with a working firmware preinstalled (very good for testing!) but I'm interested to know how to reprogram it? I'm okay with updating a file, recompiling firmware (As long as you tell me what libraries I'll need) or using a GUI, I just want it to be possible to reprogram and support for features.
Thanks for bringing us these excellent designs!
I notice some features are listed on the website
http://winkeyless.kr/entry/ps2avrU
PS/2 and USB, and it sues the capslock LED to tell you information about it. Nice!
you can choose which one by holding P or U at plug in. Nice!
Support for several LED modes and brightness control. Essential!
Sleep mode for power saving on USB. Thoughtful!
Three layers. Enough for me!
But I don't know korean:
http://winkeyless.kr/entry/ps2avrU-firmware-%EB%B0%8F-utility
English User Guide Will be Available on the time of shipping.  Started  working on It.
Key Mapping       http://winkeyless.kr/entry/%ED%95%98%EB%93%9C%EC%9B%A8%EC%96%B4-%ED%82%A4-%EB%A7%A4%ED%95%91-%EB%B0%A9%EB%B2%95
HW Macro           http://winkeyless.kr/entry/%ED%95%98%EB%93%9C%EC%9B%A8%EC%96%B4-%EB%A7%A4%ED%81%AC%EB%A1%9C-%EC%82%AC%EC%9A%A9-%EB%B0%A9%EB%B2%95
Firmware  and  Source    http://winkeyless.kr/entry/ps2avrU-firmware-%EB%B0%8F-utility
« Last Edit: Mon, 11 November 2013, 22:40:42 by sprit »
Offline sprit
« Reply #112 on: Sat, 09 November 2013, 15:31:55 »
In for 1 %75 pcb. Thanks Sprit!
Will this pcb support Cherry PCB Mount stabilizers?
All PCBs support the Cherry original PCB-mount Stabilizers.   If You Adopt a GH Phantom Plate, You can put Cherry original Plate-mount Stabilizers.
43309-0
« Last Edit: Sun, 10 November 2013, 03:01:58 by sprit »
« Reply #113 on: Sat, 09 November 2013, 19:19:48 »
English User Guide Will be Available on the time of shipplig.  Started  working on It.
Excellent resources (I was not able to find them on winkeyless.kr myself). Thanks for posting them.
This looks like a really good design I think.
Offline sprit
« Reply #114 on: Sat, 09 November 2013, 21:04:40 »
But in my opinion, PCBs are a little bit expensive.  Mainly because I insist on Colors, All parts pro-soldered, numerous fine-tuning on layouts and compatibility...  and of relatively Small MOQ?
I dont know...   Apologies.
« Last Edit: Sat, 09 November 2013, 22:59:55 by sprit »
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #115 on: Sat, 09 November 2013, 21:15:10 »
I think the price is more than reasonable when you take into account all the hard work that has obviously gone into producing them.
Offline Vintage
« Reply #116 on: Sat, 09 November 2013, 21:22:56 »
And Dosesn't this pcb also include a controller as well? In place of a teensy that would normally be about $20 bucks?
CM QFR w/ MX Reds  | Logitech G900
Offline lotus1109
« Reply #117 on: Sun, 10 November 2013, 01:55:49 »
Put me into the list?
Interested on 1x 87%. Thanks! :)
Offline longweight
  • philanthropist
« Reply #118 on: Sun, 10 November 2013, 03:36:25 »
Oh yes, does it include the controller?
Offline sprit
« Reply #119 on: Sun, 10 November 2013, 03:57:10 »
* All PCBs are  1.6T Thick, ANSI+ISO, MCU controller +  All
the latest Firmware and Key-Maps loaded and Tested.  Just snap Your Switches !
(Edited for better Clarity)
« Last Edit: Sun, 10 November 2013, 04:02:13 by sprit »
Offline naokira
  • The King in the North
« Reply #120 on: Sun, 10 November 2013, 03:58:10 »
the google doc needs request?
does this mean the first batch is ready?  :)
FaceW in LZ-CE
Offline sprit
« Reply #121 on: Sun, 10 November 2013, 04:00:48 »
I locked for the Temporal Check  for 10 min !   Sorry! :)
Offline Jmneuv
« Reply #122 on: Sun, 10 November 2013, 04:01:33 »
Thanks for the quick replies.
When do you expect to receive the sample boards?
Offline naokira
« Reply #123 on: Sun, 10 November 2013, 04:02:25 »
oh i thought it is ready already :)
When will we proceed to the first batch?
FaceW in LZ-CE
Offline sprit
« Reply #124 on: Sun, 10 November 2013, 04:07:33 »
Already got them last week,  The Final Test done for 60%  75%  87%, and 110%.
110% going to be Two Versions.  left- or,  right- handed  "Num keyPad + F1~F12 column"
« Last Edit: Sun, 10 November 2013, 23:56:09 by sprit »
Offline sprit
« Reply #125 on: Sun, 10 November 2013, 04:10:32 »
Alas!  MOQ = 50pcb matters.  the First batch is possible at any time, according to our Agreement with the PCB Factory.
60756-0  60809-1
« Last Edit: Sat, 12 April 2014, 04:12:17 by sprit »
Offline naokira
« Reply #126 on: Sun, 10 November 2013, 04:15:50 »
Yehey!!! *naokira gets excited*
FaceW in LZ-CE
Offline Jmneuv
« Reply #127 on: Sun, 10 November 2013, 04:18:30 »
Could you please post some good photos of those pcb's then? That would certainly help with moq too!
Offline sprit
« Reply #128 on: Sun, 10 November 2013, 04:52:50 »
OK, People can find the Pics in each links.
60%     PCB
http://geekhack.org/index.php?topic=49899.0
75%     PCB              http://geekhack.org/index.php?topic=49902.0
87~94% TKL             http://geekhack.org/index.php?topic=50075.0
Offline Jmneuv
« Reply #129 on: Sun, 10 November 2013, 05:09:51 »
For the TKL you claim: 87 + 5 + 3 = 95 Keys.
If that's correct, this picture must be outdated.
43361-0
Offline sprit
« Reply #130 on: Sun, 10 November 2013, 06:57:30 »
thanks !!  Jmneuv  87 +2(1+1 BackSpace,  1+1 R shift) + 5 keys around Arrow keys (as You Beautifully pointed out  :thumb:
1 more key is ISO L shift  >/  key
« Last Edit: Sun, 10 November 2013, 07:23:43 by sprit »
Offline Jmneuv
« Reply #131 on: Sun, 10 November 2013, 07:45:22 »
That's super awesome, thanks for clearing that up. Extra keys+programmable=killer.
But why don't you take a picture, even just with a phone?
Offline sprit
« Reply #132 on: Sun, 10 November 2013, 08:02:09 »
Oh !  thanks ! Jmneuv !  There is Already GH90 and GH94 in GeekHack.  So I thought it's forgivable, Sorry for that !
« Last Edit: Sun, 10 November 2013, 09:07:20 by sprit »
Offline longweight
  • philanthropist
Re: SPRIT Model 1 : PCB for 60% 75% 87% 110% : ANSI+ISO (Full LED + HW Macro)
« Reply #133 on: Sun, 10 November 2013, 08:08:10 »
The OP could be a lot clearer, why don't you remove all of the case images? Just have a few PCB shots and a link to the case thread to keep things clean.
Offline longweight
  • philanthropist
« Reply #134 on: Sun, 10 November 2013, 08:32:09 »
People are excited about the PCB alone, the OP is very messy and long. The case / plate thread should be completely separate so that people can understand what is going on.
Offline Jmneuv
« Reply #135 on: Sun, 10 November 2013, 08:37:30 »
The board is largely revised, it's like a different product, of course i need to see it before i can commit!
Offline longweight
  • philanthropist
« Reply #136 on: Sun, 10 November 2013, 08:42:18 »
OP looks much better now :)
Offline sprit
« Reply #137 on: Sun, 10 November 2013, 08:43:35 »
ANYONE Pushes Me too Much will get Nothing!   FGS
« Last Edit: Sun, 10 November 2013, 08:45:09 by sprit »
« Reply #138 on: Sun, 10 November 2013, 08:47:07 »
Lol
Offline bianco
« Reply #139 on: Sun, 10 November 2013, 10:45:54 »
just signed up for the full board (110%) version
will consider adding one more pcb when i see the metal case.
btw, i think i missed out or got confused on what the color of pcb will be?
thanks again sprit
Offline sprit
« Reply #140 on: Sun, 10 November 2013, 18:59:22 »
thanks again sprit
Terima kasih !  Color Option will open soon ~
Offline bianco
« Reply #141 on: Sun, 10 November 2013, 19:52:07 »
great! thank you sprit
i'll definitely consider a clear/transparent acrylic case if the pcb is white.
just like in the pictures that you posted before... which i can't seem to find again.  ^-^
Offline sprit
« Reply #142 on: Sun, 10 November 2013, 20:13:25 »
I love that Combo too! :  A Clear/Transparent Acrylic case with a White PCB.
« Last Edit: Mon, 11 November 2013, 03:27:24 by sprit »
Offline IMHB
« Reply #143 on: Mon, 11 November 2013, 15:24:14 »
a few quick questions:
do you recommend adding plate to this? and does metal plate comes in different colors as well?
acrylic plates are all transparent? and what do they feel like compare to a metal plate?
Personally I love the white pcb with a clear acrylic case but considering if I'm getting a steel plate then it'll cover up the color of the pcb....
And yes I do have both PCB mount and plate mount switches ready for this keyboard~
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #144 on: Mon, 11 November 2013, 16:38:19 »
yeah just to add on to this. I'll like to know too how does acrylic plate feels like. :D
Offline sprit
« Reply #145 on: Mon, 11 November 2013, 18:54:15 »
Fatal Question !   You got My Heart!    :thumb:
Yes!  Metal plate comes in different colors!    Spamming Colors....
                   All Plate have Colors,  Acryls have Transparent Colors too.
I recommend Both for No plate, or Adding plate to this
                  PCB is well considered for the Lovers of Soft Key Feeling.   For the Plate Lovers too.   I am really on both side.
Acryl Feels basically Softer than Alu plates, but depend on its thickness.
                  I am a Fan of PolyAcryl, PolyCarbon too!  (And Alu, Stainless Steal, Steal...  The Strong Materials.)
« Last Edit: Mon, 11 November 2013, 21:00:29 by sprit »
Offline IMHB
« Reply #146 on: Mon, 11 November 2013, 20:13:19 »
I recommend Both for No plate, or Adding plate to this  :  PCB is well considered for the Lovers of non-plate Key Feeling.   For the Plate Lovers too.   I am really both side.
Acryl Feels basically Softer than Alu plates, but depend on its thickness.   I am a Fan of PolyAcryl, PolyCarbon too!  (And Alu, Stainless Steal, Steal...  The Strong Materials.)
so....do you have any polycarbon cases available for this as well? or right now the acryl is the only choice...
Because from what I heard, Acryl cases are kinda fragile and easy to break...and I do plan to travel with this keyboard very often...
Offline sprit
« Reply #147 on: Mon, 11 November 2013, 20:58:05 »
I have been working on Polycarbon quiet a long time for my designs.
The Big Problem with P-Carbon is too much cost for machining, almost same as Metals
But As I said in my IC,  I will do some PC too.
Offline sprit
« Reply #148 on: Mon, 11 November 2013, 21:53:44 »
« Last Edit: Mon, 11 November 2013, 22:19:29 by sprit »
Offline r3n_uneducated
« Reply #149 on: Mon, 11 November 2013, 21:56:55 »
Great Spirit <3
but your vids make me feel dizzy :))
Own: Rosewill 9000 Vintage Black
