Hi,
most of the testers have already received the GH60 rev. B. The faster we test everything, the earlier we'll produce the final boards.
Let's not hurry too much though, we need well-tested boards.
There are a couple of things that have to be tested: compatibility with various layouts (ISO, ANSI, HHKB, etc), compatibility with extension modules, etc.
We also need to make sure that it's possible to implement full backlighting with the extension module and that the board fits various cases.
I've already tested alixinhzai's case and it fits nearly ok. It was necessary to scrape a thin layer of the USB receptacle's cutout to fit the acrylic plates, but other than that, it's okay.
I'd be very interested in getting a report about how the USB looks in various cases - whether it's centered or shifted.
Here's the current firmware, version 0.2, for rev. B only: ukbdc_gh60_revB-0.2.hex (21.28 kB - downloaded 422 times.)Here's the development version of firmware, version 0.3-dev, for rev. B:
ukbdc_gh60_revB-0.3-dev.hex (21.28 kB - downloaded 702 times.)
Slightly modified gui:
* removed sha1 check for firmware generation (overwrite base_firmware.hex with any other firmware version you want to generate layout-ful firmware)
* added all possible extra keys to gh60.xml
Download:
ukbdc_gui_b.tar.gz (35.15 kB - downloaded 668 times.)
Windows users might need to copy the usb directory from the previous version for w7.
Remember about programming the layout after flashing. The firmware comes with no layout.
For those who want to use 0.3 firmware on rev. A, here it is:
ukbdc_gh60-0.3-dev.hex (21.28 kB - downloaded 501 times.)
