Author Topic: Recently Keycap Storage box  (Read 5287 times)
Offline quake4mhg
« on: Sat, 09 November 2013, 16:59:16 »
I get them from an Asian dollar store. They're plastic storage tray in the fridge.
Put package sheet to prevent caps move around.
Tightly fit a 104 set. If few square inches bigger would be better.
Not really flips over when tilt
Great for frequency switch caps, save time to flip each cap around each time  ;D
« Last Edit: Sun, 10 November 2013, 06:04:52 by quake4mhg »
Re: Recently Keycap Storage box
« Reply #1 on: Sat, 09 November 2013, 17:01:21 »
Huh, that's pretty cool! I like how the caps dont get messed up if you tip them and you can stack them. Can you tell us exactly where you got them? Maybe like a Daiso?
Offline Belfong
« Reply #2 on: Sat, 09 November 2013, 17:36:33 »
Nice! These are food boxes or?
Offline quake4mhg
« Reply #3 on: Sun, 10 November 2013, 06:03:10 »
Yes yes, in Daiso :D They're small tray stores food inside the refrigerator.
Offline Belfong
« Reply #4 on: Fri, 10 January 2014, 00:22:01 »
You know, I have been looking for the best way to store my key caps instead of just the ziplock bags. There are a few post about people buying storage from those $1 or $2 dollar shop like Daisho. I am still looking for one which is stackable and easy to access for the full set of keyboards. But for novelty caps, I needed a smaller space and today I found the best and cheapest storage - the clear plastic boxes that came with business cards. And so I present to you, a easy-to-find novelty caps storage box:
Hmm, I could put a card and then put another 15 key caps. With 3 boxes I can store a TKL set.
