Author Topic: Kmac happy-like blocks for hammer case  (Read 8537 times)
Offline raphdu57
« on: Thu, 28 November 2013, 00:10:12 »
Hey Imsto,
Would it be possible to manufacture alu blocks like the Kmac Happy has (see here for reference) matching the colours of your last alu case GB ?
That would be awesome and I'm sure a lot of people who bought hammer's case would love to get their hands on these !
QFR with MX brown
Offline raphdu57
Re: Kmac happy-like blocks for hammer case
« Reply #1 on: Sat, 07 December 2013, 10:05:32 »
Any answer? Or is it simply impossible?
QFR with MX brown
Offline imsto
  • * Moderator
    • imsto.cn
« Reply #2 on: Wed, 11 December 2013, 07:32:21 »
it's ok to make it, do you have any more suggestions about it?
is that to make it more like hhkb or to take place of the win keys?
imsto.cn
imsto's AiKB Taobao Shop
IBM Model M*3, IBM M13,M5, IBM with balls.Cherry   3000  3494 3700 4100*6 700*2 11900 8113 DAS4 TG3 KBC PokerDucky09Ducky1087 apple pink alps Ducky bull,tiger,rabbit,dragon version No:0000002
Offline moogle
« Reply #3 on: Wed, 11 December 2013, 07:33:30 »
hhkb! or both ... ;)
Offline imsto
  • * Moderator
    • imsto.cn
« Reply #4 on: Wed, 11 December 2013, 07:41:07 »
about the color, it's not easy to make it to be  exact the same as before.
imsto.cn
Offline raphdu57
« Reply #5 on: Wed, 11 December 2013, 11:48:04 »
Well, i'm looking for a hhkb style, but I'm sure some people would be happy if you could do both.
As for the color, I don't really mind if that's a little offset, as long as it's pretty close !
Now for other suggestions, I see a few possibilities of how it could be made, but I don't know which one are plausible :
  • Use some kind of switch lockers as shown here (see here for reference)
    And then make alu blocks of 1.5u size with a cherry MX stem.  I don't know if that's possible and how hard it would be to do, but it would be the best imo.
  • Make alu blocks and put under/inside a magnet, in order to fix it on the plate (assuming the plate isn't aluminium). However it may cause problem with the pcb (well, I don't know anything about electronics, so I have no clue if it is an issue)
  • Make a simple alu block of the right dimension that people would just put of the plate, no fixation at all. This seems to me the simplest solution, but it would be wobbly...
Maybe someone else has another interesting input to share !
QFR with MX brown
Offline imsto
  • * Moderator
    • imsto.cn
« Reply #6 on: Thu, 12 December 2013, 07:51:02 »
I can not open the link you game, but I think it's easy to imaging and I do also have some ideas about it... maybe it will be possiable.
imsto.cn
Offline imsto
  • * Moderator
    • imsto.cn
« Reply #7 on: Thu, 12 December 2013, 07:51:28 »
maybe make the blocks to all be silver will be better.
imsto.cn
Offline esoomenona
  • Gnillort?
« Reply #8 on: Thu, 12 December 2013, 08:04:45 »
Or having a variety of colors to choose from might be a nice option.
Also, if you made the set just like the one that comes with the KMAC 2, you could have:
2 - 1.5x blocks
2 - 1x blocks
2 - 1.25x blocks
This would allow anyone to pick them up as they saw fit, for whatever keyboard they wanted to use them on (I think the presence of a plate is required to hold the blocks in place properly, and to not make contact with the PCB).
Offline imsto
  • * Moderator
    • imsto.cn
« Reply #9 on: Sun, 22 December 2013, 09:38:45 »
yes correct.
should make a nice design to connect them together.
imsto.cn
Offline raphdu57
« Reply #10 on: Mon, 17 February 2014, 11:27:15 »
Any update on these ?
QFR with MX brown
Offline imsto
  • * Moderator
    • imsto.cn
« Reply #11 on: Thu, 17 July 2014, 05:03:48 »
sorry, no update yet.
imsto.cn
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #12 on: Thu, 17 July 2014, 13:48:03 »
I know matching would be difficult, but I would insta-buy several in Titanium and Black if you ever release them.
Offline yuiop
« Reply #13 on: Fri, 18 July 2014, 03:36:31 »
I hope these get made. I might buy some as well.
My red Kmac 1.2 came with came with matching blockers.  I plan to use them with Imsto's R2 60% case (when I get my stuff from GH60 gb , whenever that might be :-X).  The color is a bit darker than the case but it matches pretty well and doesn't detract from the overall look.
