Author Topic: Compaq Deskpro 286 AT Keyboard  (Read 3394 times)
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« on: Tue, 10 December 2013, 13:49:42 »
i am assumming this will work with the adapter
anybody know what kind of switches?
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
Re: Compaq Deskpro 286 AT Keyboard
« Reply #1 on: Tue, 10 December 2013, 15:53:30 »
Do you have one, or is this one on somewhere like eBay? AT keyboards work, but you may need to try a couple of PS/2 to USB adapters before you find one that works — my Tulip 286 keyboard (Monterey K101) won't work with a Blue Cube, but does work with a Belkin adapter.
If you have the keyboard, you'll need to pull a keycap and upload a photo — I can't find anything on this keyboard anywhere. There are no tell-tale signs that I can pick up on from the keycaps or case. The caps lock key reminds me of Keytronic foam and foil, but that's all I can think of.
Bore Awards
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #2 on: Tue, 10 December 2013, 16:55:49 »
no but was thinking abt grabbing one
was hoping someone knew abt the switch...............probably isn't mx
i feel you abt the converters.............so far the only one i have tried that is bullet proof on everything is my zio tek
my belkin died last month :(
  • RIP
    • Boring twaddle
« Reply #3 on: Tue, 10 December 2013, 17:13:45 »
Well, one can only hope that, over time, enough people make the effort to add their keyboards to the Deskthority wiki (or similar — not sure how far off the Keyboard Database is) such that it will be possible to look up most "notable" keyboards in existence and get basic details. I'll let you calculate the odds on that happening.
I'll also let you ponder on what a "notable" keyboard would be. With a database-driven site, it should be fairly easy for everyone to simply post every single keyboard they have access to, good and bad.
My wild guess for the Compaq is either NMB Hi-Tek linear (corner LEDs definitely supported) or Key Tronic foam and foil (don't know if corner LEDs are actually supported with those), but it could be anything, and I have no idea. The LED positions rule out Alps, and imply not Cherry either (not unless it's pre-MX). Someone recently found a Scandinavian microcomputer keyboard that turned out to have Honeywell Hall Effect, so you can have some real surprises.
Bore Awards
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #4 on: Tue, 10 December 2013, 20:18:10 »
yeah............keytronic foam was what i was thinking
when u say nmb linear do you mean space invaders?
if i grab one of course i will give you whatever you ask for the wiki
awesome site!!
  • RIP
    • Boring twaddle
« Reply #5 on: Wed, 11 December 2013, 02:50:30 »
Yeah space invaders. Doubtful, though.
Bore Awards
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #6 on: Wed, 11 December 2013, 15:17:24 »
looks like maybe this whatever this is........................?
  • RIP
    • Boring twaddle
« Reply #7 on: Wed, 11 December 2013, 17:16:09 »
Key Tronic buckling rubber sleeve — tactile foam and foil.
Bore Awards
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #8 on: Wed, 11 December 2013, 18:26:40 »
u da mannnnnn :thumb:
  • RIP
    • Boring twaddle
« Reply #9 on: Wed, 11 December 2013, 18:34:00 »
The picture above is from a different keyboard to the one I was looking at, which is this one:
http://www.ebay.com/itm/161132205544
Here's the basic unbranded version without the black styling:
http://www7.ocn.ne.jp/~hisao/image/keytro84.htm
The only branding is the "K.T.C" (Key Tronic Corporation) on the PCB. Even the switches are not branded.
Looks like they just altered the case of this model to Compaq's specification. Same layout including LED style, same font, everything.
Switch:
http://deskthority.net/wiki/Key_Tronic_foam_and_foil
Bore Awards
