Another factor might be that you (at least I do) tend to press the space bar with your thumb, which is inherently stronger than your fingers.
Quite a few people have removed the extra spring, and probably kept it.
You might try a WTB thread. Someone might even give one to you!
Thanks
I've been fine-tuning that wire spring I made and it feels pretty good now. I hope it holds up.
Is there a difference between springs used in different weight switches, like 45 or 55g? Also, the 87U, it only has a spring in the center of the space bar, right? I've never actually seen one
The wiki seems to say that only the ones with the short Japanese style space bars had ones in the center, and the longer space bars were supported by one on each end, though mine just has stabilizers on the sides and I don't think that would make sense.
