Author Topic: Keycool 84  (Read 3158 times)
Offline sClass
Keycool 84
« on: Tue, 07 January 2014, 14:02:30 »
Hey everyone, I just got my Keycool 84 and I want to customize it more but I don't have many ideas. Post your customized 84s and give me some ideas!
Offline Pacifist
  • on hiatus
Re: Keycool 84
« Reply #1 on: Tue, 07 January 2014, 14:45:40 »
mine had a **** ton of novelty caps on it but then I switched it back to stock with only the red esc and blue arrows.
I like it better just like that
Offline sClass
Re: Keycool 84
« Reply #2 on: Tue, 07 January 2014, 15:01:18 »
I think I'm going to go with blank or side printed key caps with a few novelty keys on it. Dont know if i want one color or multicolored key caps yet.
Offline Pacifist
  • on hiatus
Re: Keycool 84
« Reply #3 on: Tue, 07 January 2014, 15:04:37 »
I can't use blanks on anything other than letters or mods. I can't even remember where ,.;'/[]\ keys are, and I can't touch type number and function keys. But side printed is godly. So is black on black PBT
But the classic red esc is soooo awesome
Offline sClass
Re: Keycool 84
« Reply #4 on: Tue, 07 January 2014, 15:29:46 »
I was also thinking about planks for just the letters and [];'./ ect. and leave everything else as is, but i dont know if i would like how it looked.
Offline Pacifist
  • on hiatus
Re: Keycool 84
« Reply #5 on: Tue, 07 January 2014, 15:48:19 »
kc84 isn't 100% symetrical like a 60%, so It'll look off a bit
Offline sClass
Re: Keycool 84
« Reply #6 on: Tue, 07 January 2014, 16:15:39 »
Ya that was what i was thinking. Might just have to try all blanks then and see if i can manage.
Offline Pacifist
  • on hiatus
Re: Keycool 84
« Reply #7 on: Tue, 07 January 2014, 16:16:57 »
finding a 1.75x right shift blank may be hard unless you find a set specifically for the 84
Offline sClass
Re: Keycool 84
« Reply #8 on: Tue, 07 January 2014, 16:37:01 »
Have you ever seen anyone selling 1.75x blanks?
Offline nzhao20
Re: Keycool 84
« Reply #9 on: Tue, 07 January 2014, 16:52:23 »
Idk but banggood blank pbt keycaps are from keycool so they might fit
Offline sClass
Re: Keycool 84
« Reply #10 on: Tue, 07 January 2014, 17:18:56 »
I checked there and it seems they are just the regular size shift keys.  :(
Offline Pacifist
  • on hiatus
Re: Keycool 84
« Reply #11 on: Tue, 07 January 2014, 18:15:31 »
yea unless u find a 84 specific set on banggood, you have to get a tsang kit for the 1.75x keys
Offline sClass
Re: Keycool 84
« Reply #12 on: Tue, 07 January 2014, 18:43:29 »
Where would you get those at?
Offline Pacifist
  • on hiatus
Re: Keycool 84
« Reply #13 on: Tue, 07 January 2014, 19:03:26 »
When a group buy comes along. Right now the raindrop set has a tsang kit
Offline Pacifist
  • on hiatus
Re: Keycool 84
« Reply #14 on: Tue, 07 January 2014, 19:04:26 »
Offline sClass
Re: Keycool 84
« Reply #15 on: Tue, 07 January 2014, 19:10:08 »
Offline Pacifist
  • on hiatus
Re: Keycool 84
« Reply #16 on: Tue, 07 January 2014, 19:28:57 »
http://geekhack.org/index.php?topic=52475.0
So just watch for group buys from that guy?
bunny's great. Other people will have GBs too
ask ivan, I think he's doing a 1.75x shift in his black pbt set
Offline Pacifist
  • on hiatus
Re: Keycool 84
« Reply #17 on: Tue, 07 January 2014, 19:29:21 »
Offline sClass
Re: Keycool 84
« Reply #18 on: Tue, 07 January 2014, 19:40:22 »
http://geekhack.org/index.php?topic=50935.0
Cool. Thank you for all the help. Getting pretty excited now that I know how good group buys can be!
Offline Lain1911
  • God of the Wired
Re: Keycool 84
« Reply #19 on: Thu, 24 April 2014, 20:37:38 »
Where did you get your keycool?
Offline Pacifist
  • on hiatus
Re: Keycool 84
« Reply #20 on: Thu, 24 April 2014, 21:22:48 »
banggood, both times
Offline minho
  • i'm kind of back
Re: Keycool 84
« Reply #21 on: Thu, 24 April 2014, 21:42:41 »
Are you talking about the one that comes with the KC84 by default...? Because mine looks kinda faded (or rather, it's a grey font that doesn't look all that great on the keycap)
Also, sClass, if you're looking something  cheaper than a group buy, you could always go for either of these: http://www.banggood.com/buy/84-key-caps.html (both out of stock currently though, not sure when they'll be in stock).
Offline sClass
Re: Keycool 84
« Reply #22 on: Thu, 24 April 2014, 21:45:29 »
Yep i got the white ones!
Offline minho
  • i'm kind of back
Re: Keycool 84
« Reply #23 on: Thu, 24 April 2014, 21:52:17 »
Oh nice! You must have been one of the lucky last buyers before they went out of stock then.
