Author Topic: Topre, backlit QFR, backlit Stealth,  (Read 108343 times)
Offline gameaholic
« on: Tue, 07 January 2014, 23:53:52 »
Doesn't look like 2014 is gonna be any better for my wallet.
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
Offline Pacifist
  • on hiatus
Re: Topre, backlit QFR, backlit Stealth,
« Reply #1 on: Wed, 08 January 2014, 00:07:34 »
Topre+MX Stem+BACKLIGHTING=godly
Can't wait.
Offline nuclearsandwich
« Reply #2 on: Wed, 08 January 2014, 00:30:33 »
I didn't think the Topre (Novatouch) was backlit. It certainly doesn't appear to be from the close up photos.
Offline vun
  • Just one more thing
« Reply #3 on: Wed, 08 January 2014, 06:28:30 »
ALSO DAT MOUSE
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #4 on: Wed, 08 January 2014, 06:44:43 »
Damn, that's my next keyboard..... the Novatouch.....nice  :thumb: .
Also got so many key-caps it'll take several days to finally choose which one to place on that keyboard.  Finally a decent 'thorpie' keyboard that you can fully customize, I bet HHKB and REALFORCE are shedding tears when this one gets released to the public, which I just love  ;D .
Probably of note, that the owners here of their current topre's will be selling them in the classifieds to unload their rubbish before the new king arrives on the block.  Nice one CM - always good to see someone kicking the butts of their competitors with such ample zeal.
« Last Edit: Wed, 08 January 2014, 06:49:05 by Elrick »
Offline vun
« Reply #5 on: Wed, 08 January 2014, 06:51:44 »
Why would anyone sell off something like a Realforce to buy a CM Topre board? It makes even less sense than selling off a Filco to buy a QFR with identical switches.
The only thing I can see happening is RF owners wanting to get their hands on the CM stems.
Offline Elrick
  • Hype Master
« Reply #6 on: Wed, 08 January 2014, 07:56:08 »
Now you've hit the nail on the head  :thumb: .  What do you think I meant by "fully customize" a thorpie board?  The choices will be endless thanks to SP, GMK and BSP for starters.
Offline vun
« Reply #7 on: Wed, 08 January 2014, 10:06:19 »
Most Topre boards already come with proper PBT caps though. No way would I choose ABS over PBT or POM. If we're lucky they'll let us buy stems separate from the boards, since going from a RF to CM board will most likely be a downgrade in terms of build quality(seriously, RF boards are so nice).
You're making this sound like CM are whooping the other Topre manufacturers, when in fact they're competing on the same level at best in terms of build quality. Sure, CM's board will be easier to buy and probably cost less, but it will also come with ****ty caps and equal build quality at best, most likely inferior.
Offline BunnyLake
  • The OG HHKB Master
  • X
« Reply #8 on: Wed, 08 January 2014, 10:40:35 »
my issue with this is, as much as i love the idea of topre being more customizable visually, ive never sat down with one of my topre boards and thought " i sure wish this looked like a qfr"
ill be buying one, if only because ill be able to use some keysets from my groupbuys without having to type on mx, that being said, im hoping i can just pillage the stems and sliders from these and pop them in a realforce or hhkb
Offline MJ45
  • HHKB Pro
« Reply #9 on: Wed, 08 January 2014, 10:59:02 »
I'm thinking the same thing, hopefully the stems and sliders will fit the RF-HHKB housings properly, especially since the case top on the HHKB is the stem-slider housing.
Offline Linkbane
« Reply #10 on: Wed, 08 January 2014, 11:02:19 »
Seeing how Topre is selling CM the switches, I think this would make them cry about as much as Cherry would be when they sell Rapids.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline korrelate
  • iubeo stultum esse libenter
« Reply #11 on: Wed, 08 January 2014, 12:05:18 »
Would love to see the pics of the stabilizer under the space board on the NovaTouch TKL.
Just found pics of the stabilizers under the enter key and wondering if the same approach works for the space bar.
http://deskthority.net/keyboards-f2/topre-switch-cherry-mx-compatible-t7076-90.html
For my part... I don't even care if they stick with Costar Stabs. Probably, I would prefer it: after I lubed my stabs on my Filco I was thrilled with the results (and Cherry Plate mount stabs me no likey and Cherry PCB mount stabs pop out if you try to pull off caps that fit too tightly).
Topre REALFORCE
« Reply #12 on: Wed, 08 January 2014, 13:12:24 »
The one thing I'm worried about is that this might kill off any future Topre custom keycaps (sets or individual), especially if other manufacturers come out with their own Topre/MX keyboards.
Those of us with Topre boards who do not want to cut and paste MX stems into them would find ourselves lacking any custom Topre keycaps.
« Reply #13 on: Wed, 08 January 2014, 13:17:01 »
Well according to elitekeyboards topre isn't making any more of the custom caps...so.....yeah.... :(
« Reply #14 on: Wed, 08 January 2014, 13:19:00 »
A keyboard like this would kinda make anyone else think twice about stepping into the void to make custom Topre keys/sets.
Offline BunnyLake
  • X
« Reply #15 on: Wed, 08 January 2014, 13:22:16 »
my guess would be, if topre are actually stopping production on caps, that they will be moving more over to licensing their switch rather than producing keyboards
« Reply #16 on: Wed, 08 January 2014, 13:25:53 »
According to the cooler master rep in the video posted from CES it sounded like there was some exclusivity for the current mx key cap compatible topre switches, at least in the US, not sure about ROW.
Offline BunnyLake
  • X
« Reply #17 on: Wed, 08 January 2014, 13:56:11 »
yeah, i didnt wanna read to much into that, sometimes people word things a bit awkwardly in those situations, it could also be some sort of timed exclusivity or just mean exclusive at this point in time because nobody else has done it, either way, i would guess its the start of more topre licensing as a business model
Offline KangarooZombies
  • HHKB Pro
  • ʕ•ᴥ•ʔ
« Reply #18 on: Wed, 08 January 2014, 14:15:15 »
this this this this this
I cant shake the feeling that Cooler Master is going to cheap out on the case and materials just to sell the board at a lower price to an audience that was previously unable to afford topre.
Having a bad day?
Offline sublime
« Reply #19 on: Wed, 08 January 2014, 14:33:58 »
I enjoy typing on my Topre far more than on any Cherry keyboard I have, and this looks like a great step towards more customization. However, I have this strange itch that the switches won't feel like a "real" Topre due to engineering the MX + into them, but I'd love to be proven wrong.
Also, my elitism is showing now that I'm bugged people will get ahold of Topre switches and start acting like they're God when many people have been there from the start. Writing that out just smells of horrible elitism, but I still feel it.  :p
« Reply #20 on: Wed, 08 January 2014, 14:55:00 »
I wish they would make a full size board with heavy domes
Offline 1pq
  • Hipster Doofus
« Reply #21 on: Sun, 23 February 2014, 22:27:47 »
^^ yes!
Wait—fullsize? Blech.
main kbs:  87UB (55g)  Custom Filco TKL (62g clears)
WTS JD40, Custom Ergoclear Filco
WTB ROHS Red BBv2 (Topre), OG EK Tri-Color Skull (TOPRE)
Offline avtar
« Reply #22 on: Sat, 01 March 2014, 10:11:44 »
Sorry to burst your bubble, but http://deskthority.net/workshop-f7/topre-sliders-mx-caps-t7437-30.html#p148317 Perceiving this as a sporting event with rival teams is a bit puzzling to me. They're just keyboard manufacturers and at the end of the day people will use what feels best to them. I've heard the Novatouch will be coming out of the same factory that produces the FC660C so if you like how that feels then you're fine. If you however prefer how a RF or HHKB feels then this news has little impact.
Offline boradori007
  • I'm trippin bear balls.
« Reply #23 on: Sun, 30 March 2014, 02:42:21 »
Release date on Novatouch?
Offline BucklingSpring
« Reply #24 on: Sat, 05 April 2014, 12:30:04 »
Boards I own, click ->
Offline SSIPAK
  • ★ Bootlegcaps ★
« Reply #25 on: Sat, 05 April 2014, 16:46:15 »
+Bump.
I read somewhere that it will be around April/May. Not 100 percent sure tho
Offline pgeorghiou
« Reply #26 on: Fri, 11 April 2014, 13:51:14 »
I hate to be that person who is asking about the next product before the current one is released but...any idea's on if/when there will be a 55g version of the Novatouch  ;D
This will be my first Topre, and I hear 55g is the way to go. However, if anyone has a different opinion or insight please fill me in!!!
Current hardware:  CMStorm Trigger w/ Cherry Blues
Offline Pacifist
  • on hiatus
« Reply #27 on: Fri, 11 April 2014, 13:53:40 »
Carter has already said that if 45g sells well they will have 55g
Offline Linkbane
« Reply #28 on: Fri, 11 April 2014, 16:09:59 »
Don't wait on it, it'll be at least a year for sure. And instead of listening to the few who are obsessed with 55g, try out both before you evidence what you like. I'm personally partial to lighter switches.
Offline pgeorghiou
« Reply #29 on: Sun, 13 April 2014, 11:32:15 »
Awesome! Thanks for the info. I must have missed that post.
I know a lot of this is subjective, but I like to get a general idea of what other people have to say about the different switches, so thanks for the heads up! The idea of waiting another year for the "ideal" board does not sound appealing.
