Author Topic: $15 credit for switch tester?  (Read 7880 times)
Offline gameaholic
« on: Thu, 23 January 2014, 11:31:43 »
How do I redeem my $15 credit for the switch tester?
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
Re: $15 credit for switch tester?
« Reply #1 on: Fri, 24 January 2014, 13:15:50 »
The deskthority CM rep said it should be on the packing slip.
My tester did not have a packing slip :(
Offline Grendel
« Reply #2 on: Fri, 24 January 2014, 16:53:02 »
Neither did my mine (both.) Would appreciate a CM rep to look into this.
- I'm game !
Offline Carter
  • CM Storm Rep
  • * Moderator
« Reply #3 on: Wed, 29 January 2014, 13:46:12 »
Sorry for the packing slip mishap.
You can find the code by logging into your CM Store account and locate the coupon code in the "Order Detail"
« Reply #4 on: Wed, 29 January 2014, 13:52:22 »
Not seeing it :(
Offline Grendel
« Reply #5 on: Wed, 29 January 2014, 14:12:12 »
I see it in the Order Instructions/Comments section. (Also got a flurry of emails w/ the codes after I PM'ed the order numbers to the rep at DT :)))
- I'm game !
« Reply #6 on: Wed, 29 January 2014, 14:22:19 »
52613-0
^^ Is that the correct screen?
Offline nullstring
« Reply #7 on: Wed, 29 January 2014, 14:52:16 »
How long does the $15 credit last? Does it have an expiration date?
Offline Grendel
« Reply #8 on: Wed, 29 January 2014, 15:56:33 »
Yea, that's the right screen. Weird.
52615-0
- I'm game !
Offline CM Norumu
  • * Commercial Vendor
    • Cooler Master USA
« Reply #9 on: Mon, 03 February 2014, 16:45:22 »
Not seeing it :(
Hey mate, come find us via Live Chat or by phone via the links/info at http://www.coolermaster-usa.com/contact.php so we can help you out directly via your order information. :)
If you wanted to, you can PM me the order number, or if you don't trust me, PM Carter and tell him to pass it on to us at support!
« Reply #10 on: Wed, 05 February 2014, 07:42:28 »
Not seeing it :(
Carter got it worked out! Thanks!
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #11 on: Wed, 05 February 2014, 07:47:24 »
Do these expire?
I'd love to eventually use it on… ahem… a certain Japanese capacitive keyboard…
« Reply #12 on: Wed, 05 February 2014, 07:47:45 »
Do these expire?
I know right....I'm wondering the same thing.
Offline Grendel
« Reply #13 on: Wed, 05 February 2014, 11:42:12 »
Didn't see any expiration mentioned anywhere. What annoys me me is that you can apply only one code to an order.
- I'm game !
« Reply #14 on: Wed, 05 February 2014, 11:43:01 »
Yeah and you can't use the code to order another switch tester either :D
