Author Topic: Topre sliders, MX caps  (Read 90048 times)
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
Re: Topre sliders, MX caps
« Reply #300 on: Thu, 16 October 2014, 02:58:38 »
I found a way to make them cheaper, stay tuned!
Offline Latin00032
« Reply #301 on: Thu, 16 October 2014, 06:13:03 »
Excited!
Offline Latin00032
« Reply #302 on: Thu, 16 October 2014, 06:27:16 »
Now, all we need are mx compatible stabilizers.
« Reply #303 on: Thu, 16 October 2014, 09:03:15 »
I am excite.
Offline Cherry1990
« Reply #304 on: Thu, 16 October 2014, 14:23:04 »
We hope in Europe... :(
You are opening a new world at many of us... :D
PBT forever!
Offline byker
  • Literally Canada
« Reply #305 on: Thu, 16 October 2014, 14:23:32 »
Oooh. Hype!  ;D
Offline Hypersphere
« Reply #306 on: Thu, 16 October 2014, 15:05:14 »
Antenna deployed, awaiting transmission....
Offline Sygaldry
  • Edema Ruh
« Reply #307 on: Thu, 30 October 2014, 15:32:19 »
Posting here to get updates!
null
Offline Vizir
« Reply #308 on: Thu, 30 October 2014, 15:37:48 »
tagged!
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #309 on: Thu, 30 October 2014, 18:03:27 »
okay. I can 3d print them at €3 each. Still very expensive but half of what shapeways can do now.
I have to check quality, though
Offline Hordak
« Reply #310 on: Fri, 31 October 2014, 02:12:54 »
Nice, will you do Type-S too?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #311 on: Fri, 31 October 2014, 02:39:18 »
yeah, no reason not to :)
Offline Hordak
« Reply #312 on: Fri, 31 October 2014, 06:09:52 »
Captain Kirk's nipples!
Offline yicaoyimu
« Reply #313 on: Fri, 31 October 2014, 08:42:24 »
But isn't €3 per slider still more expensive than harvesting a Novatouch?
Offline FrostyToast
  • Litshoard
« Reply #314 on: Fri, 31 October 2014, 08:43:45 »
Yup. That's why you should only grab a few of these for novelties.
Shame that we can't make them as cheap.
Quote from: elton5354
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #315 on: Fri, 31 October 2014, 08:45:46 »
you still need the stabilized keys, so you couldn't cover a full keyboard anyway. this is just if you want to place a couple of novelty keys
Offline yicaoyimu
« Reply #316 on: Fri, 31 October 2014, 08:56:53 »
I see. Thanks for clarifying.
Offline Vizir
« Reply #317 on: Fri, 31 October 2014, 10:46:03 »
Would it be possible to use these just for the space bar since that is the only part we can't harvest from a novatouch without leaving the novatouch with a broken space bar.
Offline cookie
    • Deskthority
« Reply #318 on: Fri, 31 October 2014, 10:46:41 »
There must be a way to cast them in larger batches!
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #319 on: Fri, 31 October 2014, 11:29:50 »
yeah, I could make a mold and resin-cast them... not sure how they would come out though
what keyboard do you want to cover?
Offline Sygaldry
  • Edema Ruh
« Reply #320 on: Fri, 31 October 2014, 11:54:53 »
HHKB possible?
Also, resin molding actually sound like it could work, at least from what I've seen online.
null
Offline Vizir
« Reply #321 on: Fri, 31 October 2014, 12:32:43 »
Hhkb
Offline cookie
    • Deskthority
« Reply #322 on: Sat, 01 November 2014, 14:33:16 »
Hey matt3o, HHKB here! :)
Maybe you need help to make it happen? I am thinking about the exact same thing, maybe we should hook up together?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #323 on: Sun, 02 November 2014, 01:42:43 »
doesn't the HHKB spacebar have weird stem position?
I would definitely need a vacuum chamber for home-made sliders. They are really too small, you risk to throw away half of them otherwise. Any idea where I can find one at a decent pricing?
Offline appleonama
  • Trollo en USA
« Reply #324 on: Sun, 02 November 2014, 01:48:55 »
Great! would throw money at you to help you make them cheaper
Offline appleonama
  • Trollo en USA
« Reply #325 on: Sun, 02 November 2014, 01:49:35 »
dammit double post
anyways nice hopefully you make more progress
« Last Edit: Sun, 02 November 2014, 01:52:34 by appleonama »
Offline Sygaldry
  • Edema Ruh
« Reply #326 on: Sun, 02 November 2014, 10:28:37 »
eBay has 1gallon vacuum chambers for as low as 60 shipped, not sure how much it would cost to get one to you in the EU
null
Offline Hypersphere
« Reply #327 on: Sun, 02 November 2014, 14:56:38 »
Apologies if someone has already asked this:
-- Is it possible to use PBT?
-- If PBT is possible, could you make PBT spacebars for Topre-switch boards such as Realforce or HHKB?
I realize that this involves the added complication of a stabilized key.
Offline Phinominal
« Reply #328 on: Fri, 12 December 2014, 18:00:56 »
Any updates on this so far? Been quietly and eagerly following this thread.
Offline Daphen
« Reply #329 on: Thu, 30 July 2015, 10:09:15 »
Hey guys, do you have any updates for this? Just bought myself a Type-S, so now I'm stuck in Topre-keys-territory. This would be a great solution. :)
« Reply #330 on: Thu, 30 July 2015, 10:20:29 »
Ctrlalt in partnership with JTkeycaps will be releasing sliders soon.
They recently had a group buy for them along with key caps.
« Reply #331 on: Tue, 18 August 2015, 11:15:24 »
Awesome. Definitely keeping their store bookmarked for when they have them on sale.
Offline yehoshuaf
« Reply #332 on: Wed, 26 August 2015, 12:08:58 »
So, shapeways price goes way down if you can make a single model that combines a bunch together that can be snipped apart later. I did this for a similar project here:
http://shpws.me/JIun
Any chance of this happening? or of releasing the model?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #333 on: Thu, 27 August 2015, 04:01:45 »
I'll work on it, promised :)
I simply have too much meat on my plate right now :) Let me finish the WhiteFox and I'll work back on this
« Reply #334 on: Thu, 27 August 2015, 08:23:00 »
WhiteFox?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #335 on: Thu, 27 August 2015, 08:44:06 »
WhiteFox?
My first "commercially available" keyboard :)
Offline yehoshuaf
« Reply #336 on: Thu, 27 August 2015, 10:22:47 »
Lol, k, no pressure. TBH, I didn't search through all the posts to see if this was a plan. I'm happy to do it for you too, if desired.
Offline the_marsbar
« Reply #337 on: Thu, 24 March 2016, 06:27:46 »
Any news on this? :)
Offline klincher
« Reply #338 on: Sun, 01 May 2016, 12:07:50 »
any updates on dis ? :)
