Author Topic: Mouse Recommendation  (Read 2155 times)
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« on: Thu, 20 March 2014, 13:11:22 »
I in the market for a new mouse and wanted to get an expert opinion this time
Requirements:
-Usable for FPS gaming
-Under $100
-Wired
-I'm used to fatter shaped mouses like these:
http://www.walmart.com/ip/22339619?wmlspartner=wlpa&selectedSellerId=0&adid=22222222227000000000&wl0=&wl1=g&wl2=t&wl3=41833582510&wl4=&wl5=pla&wl6=19880599990&veh=sem
http://www.cyborggaming.com/prod/rat7.htm
So that would be a huge plus, but not a dealbreaker :)
I also have a claw grip.
« Last Edit: Thu, 20 March 2014, 13:38:49 by hwood34 »
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
Re: Mouse Recommendation
« Reply #1 on: Thu, 20 March 2014, 13:27:12 »
Since you're doing FPS gaming I recommend an optical mouse.
If you want a fatter shaped mouse I would say get the Mionix Naos 7000 which is on massdrop -> https://www.massdrop.com/buy/mionix-naos-7000
I think this is what you might be looking for.
Otherwise I'd suggest these to start you off with the.
Zowie EC EVO CL, Logitech G400, CM Spawn, Death Adder, SteelSeries Rival,
Let us know your grip style if you don't like those and need some more feedback!
« Last Edit: Thu, 20 March 2014, 13:32:28 by the1onewolf »
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #2 on: Thu, 20 March 2014, 13:39:42 »
Sry bout that, updated OP, but that Naos looks great :)
Offline vun
  • Just one more thing
« Reply #3 on: Thu, 20 March 2014, 14:40:36 »
Naos is too flat for claw grip, I'd recommend looking at something like a Zowie or Spawn/Xornet.
Offline daerid
    • Rossipedia
« Reply #4 on: Sat, 22 March 2014, 21:07:57 »
^^^ +1 for the Zowie EC
Offline Bucake
« Reply #5 on: Fri, 28 March 2014, 09:05:39 »
logitech g400/g400s or zowie fk.
you could also check out steelseries kana v2 and razer deathadder 2013, i read great things about them.
+1 for the Zowie EC
zowie EC is also considered one of the best. so is the zowie AM.
(yep, zowie does great)
Offline MsYutai
« Reply #6 on: Fri, 28 March 2014, 11:42:34 »
All good recommendations so far.
I would also check out the Mionix Avior 7000.
CM Storm Quickfire XT - MX Reds
Roccat Kone Pure Optical|Kana v2|Zowie FK|Logitech g500s|Mionix Naos 7000|CM Spawn|Logitech Performance MX
Offline PolaBurrr
« Reply #7 on: Tue, 01 April 2014, 12:23:54 »
definitely try out the ec before you buy it, as I found that many (including me) find the right slope to be too slanted, like \, so it would be hard for me to pick up the mouse as effortlessly as an ambidextrous mouse. But if that shape works for you, then it is a great mouse. I personally would recommend the kana v2, if you can get it, and use the tape trick.
Offline Protato_Tubby
  • people enthusiast
« Reply #8 on: Tue, 01 April 2014, 16:46:29 »
Roccat Kone. Every time.
DELL AT102W Black Alps | IBM Model M 122 | Matias Tactile Pro 4
Offline boradori007
  • I'm trippin bear balls.
« Reply #9 on: Wed, 02 April 2014, 15:47:55 »
You should try Zowie FK or Kana V2,
