Author Topic: comparing keycaps from a dasIII and a filco mini  (Read 1745 times)
Offline bigpook
« on: Tue, 31 March 2009, 17:11:12 »
The keys on top are from the das
Tilted side angle
the das 'asdf' keys on the filco
Side view
caps lock
height
I am thinking that you could swap the keys from a dasIII to a filco.
Anyone else here have given that a go?
Offline tamasrepus
    • http://blog.samat.org/
« Reply #1 on: Tue, 31 March 2009, 17:56:46 »
I really hate the type face of the font on the Das. It seems like some reject font they included with Microsoft Publisher.
Noppoo Choc Mini w/ Cherry MX Brown
Happy Hacking Keyboard Professional 2, Black w/labels
Topre Realforce 87U, 55g
ABS M1
Happy Hacking Keyboard Lite 2
Logitech diNovo Edge
Sun Type 6 USB
Offline FKSSR
« Reply #2 on: Tue, 31 March 2009, 18:10:59 »
haha.  agreed.
The keys do look similar in size, or at least close enough that they could be swapped.
Add me on Steam | Raptr
Offline bigpook
« Reply #3 on: Tue, 31 March 2009, 19:04:45 »
Quote from: ripster;26373
I'll try swapping a few when I get my Das Keyboard 3 back from RMA.  I better not break a stem or I'll blame you guys.
- Ripster
the key caps come off pretty easily. I use two paper clips to lift them off of the stem.
Online iMav
  • babysitter
  • "En casa del herrero, cuchillo de palo"
« Reply #4 on: Tue, 31 March 2009, 20:43:30 »
Are all the keys swappable (same size)?  Shift, spacebar, enter, etc...
Offline bigpook
« Reply #5 on: Tue, 31 March 2009, 20:57:23 »
Quote from: iMav;26380
Hmm. I will need to check on that. The letter keys seem ok as does the capslock key. I would think enter, shift would be good too; but need to verify that. The space bar could be iffy, but may not need to be replaced?
Let me check on that.
Offline bigpook
« Reply #6 on: Tue, 31 March 2009, 21:01:47 »
iMav
I eyeballed the keys and I am thinking that ALL of them can be swapped out.
Offline itlnstln
« Reply #7 on: Wed, 01 April 2009, 06:47:08 »
I see an obvious problem in the first picture with swapping keys on the Das and Filco.  It looks like the Filco 'board has mislabeled D and F keys.
J/K :D
Offline rush340
« Reply #8 on: Wed, 01 April 2009, 23:15:24 »
Edit: nevermind
I'm interested in seeing of the Filco keys fit the Das though!
Offline bigpook
« Reply #9 on: Thu, 02 April 2009, 04:37:55 »
Quote from: itlnstln;26409
J/K :D
yah, but did you notice that the F key on the Das is already starting to fade?
The das isn't even a year old yet and the lettering is starting to go.
Offline xsphat
  • Enlightened
« Reply #10 on: Thu, 02 April 2009, 04:57:05 »
Quote from: bigpook;26615
So cheap. I might be spoiled by the PFU, Topre and IBM keyboards.
Dell SK-8125
The best keyboard is the one that's in front of you.
Offline bigpook
« Reply #11 on: Thu, 02 April 2009, 05:45:23 »
Quote from: xsphat;26617
Is cheap what it is? For the 130 dollars or so you would think the lettering would stay on for a bit longer.
Offline itlnstln
« Reply #12 on: Thu, 02 April 2009, 06:49:10 »
Yeah, I did notice that the "stems" on the letter F were a little short.  That's a damn shame, really.  That is one thing I am not too fond of on the Costar 'boards; the letters being printed on instead of molded or laser etched, that is.  Even my black Cherry keyboard has laser etched caps (they don't look the greatest, but they won't rub off, either).
Offline bhtooefr
« Reply #13 on: Thu, 02 April 2009, 10:39:21 »
The lettering on my Scorpius M10 is darkening, but not rubbing off like silkscreened letters do. (My ThinkPad's keyboard is a friggin joke, though, with quite a few keys missing most of their printing. Give it a few years, and I'll have a Das ThinkPad. :p)
want mature keyboard discussion? try deskthority.
Offline itlnstln
« Reply #14 on: Thu, 02 April 2009, 10:40:54 »
Quote from: bhtooefr;26647
Strong.
