Author Topic: Just got my sampler, really like the clears... any CM XT or similar with clears?  (Read 50232 times)
Offline oryan_dunn
Title kinda says it all.  I really want to get greens for work, but I'm sure the noise would be too much.  I have a brown at home, and while I like it, it's just too light for me.  So, I'd like to get a clear board for work.  Just a no-frills 104 key.  Any advice?
Offline Pacifist
  • on hiatus
CODE
KC108?
There was a shine 2 model with clears but its really hard to find
or get somebody to swap switches for you
Offline oryan_dunn
Thanks for the tips, I'll look into those.
http://mechanicalkeyboards.com/shop/index.php?l=product_list&c=50
The only one they have in stock is a Deck for $207 which seems crazy
Something like this would be perfect
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=466
or a Cherry G80-3000 with clears.  I've read that other people who get the tester prefer the clears, but clears are even harder than greens to find.  You'd think if CM put clears on the sampler, they'd have a keyboard available with them.
Offline missalaire
  • Great Finder of Great Finds
Well, the Deck does come with PBT key caps. It is pricey though, yes.
Your best bet is to probably just buy some MX clear switches from mechanicalkeyboards.com and find someone to mod a board for you with them.
Offline oryan_dunn
Yeah, if I was going to do that, I'd just do that myself.
Since my work would be paying for the keyboard, I don't think I want to invest my own time and money into it.  I'm sure Rajiv has heard it before, but it'd be nice if they made a clear version of the XT.  If I wanted clears for home, I'd swap them in a heart beat, but I really do prefer the greens, and at home noise isn't an issue.
Offline naasfu
  • The Curator
  • CURSE YOU HE-MAN
Code with Clears is supposed to be available in April:
http://www.wasdkeyboards.com/index.php/blog
Offline oryan_dunn
Thanks for the link.  I wasn't quite sure what the code keyboard was.  Looks good, though wish they had a cheaper version without backlighting.  $150 will be a hard sell.  It's hell having to order anything through my works 'approved' supplier list.  It's a special kind of hell to order something from an 'unapproved' supplier list.  I'm sure the company will spend 10x the price of a keyboard with all the man-hours they'll spend on approvals.
