Author Topic: what options are available for Cherry ML keycaps?  (Read 1980 times)
Offline jacobolus
« on: Wed, 09 April 2014, 22:25:46 »
The ML keycaps I’ve seen are all printed ABS, kind of flimsy and cheap feeling, and most are smaller than standard keycap size [which is fine for some purposes].
Does anyone know sources for interesting Cherry ML keycaps?
Are the SP ones any good? Will they do double-shots? PBT?
Are there other keycap vendors who sell ML caps? Blanks? What kind of cap sizes are available?
Offline davkol
  •  Post Editing Timeout
Re: what options are available for Cherry ML keycaps?
« Reply #1 on: Thu, 10 April 2014, 12:29:53 »
AFAIK there's essentially only SP or harvesting lasered/dyesub POM/PBT from Cherry G84 boards.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Thu, 10 April 2014, 14:09:31 »
The Tandberg ones have some kind of cool keys, I think they are dyesubs. You can find the dyesub ones if they have an S model like G84-****S** / S****
P models are pad printed abs, L models are lasered.
Offline jacobolus
« Reply #3 on: Thu, 10 April 2014, 15:45:59 »
Wow, those Tandberg ones are quite something. That keycap shape should avoid the problem ML switches tend to have with tilting and binding when you press on a corner.
« Reply #4 on: Thu, 10 April 2014, 22:11:23 »
There are also various old laptops that use ML and you can find some Dolch units (the ones with a trackpad) with ML switches.
Offline Monophonic
« Reply #5 on: Fri, 18 April 2014, 05:18:05 »
What about desktop keyboards? I've only ever seen one style.
