Author Topic: The Ultimate Stabilizer for ALPS boards  (Read 7911 times)
Offline Hak Foo
  • Make America Clicky Again!
« on: Wed, 23 April 2014, 23:10:11 »
A few dys ago, I was wondering if it would be possible to rig Costar-stabilized caps to fit on older boards which have ALPS-style stabilizers.
Unfortunately, a bit of a disaster trying to desolder an AT101W left me in the opposite situation-- Costar-stabilized boards with a glut of ALPS-stabilizer caps.
What can we do?  Force the ALPS-stablilzed caps to work with Costar stabilizer inserts.
What do you need?
Costar-stabiliser inserts.  If you're reading this with any degree of excitement, you probably already have a board or two to scavenge some extras from.
The original ALPS cap wires.  Unfortunately, the Costar wires tend to be too short and the wrong shape to engage the alps stabilizers.
What do you need to do?
Simply remove the "rear lip" of the insert, filing it down to near-flat.
Reinstall the stabilizer inserts, using the ALPS wire.  Save the original wire, in case you ever want to use a more modern cao.
As far as I can tell, this configuration is backwards-compatible, so it should let you swap in newer, Costar-stabilized caps whenever you want, just by changing the wire.
Overton130, Box Pale Blues.
Re: The Ultimate Stabilizer for ALPS boards
« Reply #1 on: Thu, 24 April 2014, 07:14:29 »
Thank you! This is excellent!
Now I need to find some loose costar stabilizer inserts, I can't scavenge any and certainly can't waste them.
"The Trump campaign announced in a letter that Republican candidates and committees are now expected to pay “a minimum of 5% of all fundraising solicitations to Trump National Committee JFC” for using his “name, image, and likeness in fundraising solicitations.”
“Any split that is higher than 5%,” the letter states, “will be seen favorably by the RNC and President Trump's campaign and is routinely reported to the highest levels of leadership within both organizations.”"
