Gentlemen, I present to you keyboard science, the like of which the world has never seen the like of which.
Ok, so VesperSAINT and I were talking about the dome weighting on the FC660C in
this thread. I have owned 3 different Leo FC660Cs, and based on my experience with them, I believe that the later models have substantially heavier weighted domes than the earlier ones, even approaching RF 55g territory. I have seen other users make similar comments on GH, so I wanted to resolve this.
So, I did some real keyboard science.
HypothesisH
0: There is no difference in dome weighting between my older model and my newer model
H
1: The dome weighting on the newer model is heavier than that of the old model.
Procedures and Data CollectionI currently have 2 FC660Cs in my possession. A blank one I purchased new from EK in Feb 2014 and have used as a daily driver since then. Serial #944. The second one, printed, I purchased from another user who got it as part of an early batch last year, and used it for 2-3 months. Serial #419. So, to the best of my knowledge, they have been used an approximately equal amount, canceling out any potential difference due to "break in."
I popped off a bunch of keycaps on both keyboards, like this:
Perfect for using nickels (5 grams each). The home row is nice and flat, and with surrounding keys popped off, there is no interference with the distribution of weight.
I gently added nickels on top of each of these five keys until the domes collapsed, and recorded the weight in grams that finally triggered the collapse. When I was reaching the peak # of nickels, I gently slid them on from the side so as to not cause extra force due to downward acceleration. I did 10 trials for each of these five keys, and as my final data point, used the mode (hell yeah
Then, I did the same for the other four easily accessible keys on the home row (D, G, J, L) , for a total of nine data points per keyboard. Could have done more, obviously, but I was getting bored.
From this summary data, I could see that there was an approx. 5g difference in means in the direction I expected.
AnalysisTested equality of variances with f test
Accepted the null hypothesis, variances are equal, did t-test for means
I rejected the null hypothesis with a two-tailed test at p=0.05, there was a statistically significant difference in dome weighting between the two models, the later one being heavier.
Discussion/ConclusionThe data supported and confirmed my hypothesis, however my sample size was super small and there are tons of potential confounding variables here. However, the best analysis I can do with what I have suggests the new Leo's are really different. I would like to compare these results to a similar nickel test on an RF 55g. Even though the newer model had a mean depression force of 57.2g, I think my RF 55g (which is not handy right now) nevertheless feels heavier.
Good news: if any of you guys want to repeat the nickel test using the procedure I outlined above, I can collect your data and add it to my analysis and we can try to corroborate the hypothesis, and/or get a sense for what serial numbers have the new, heavier domes
SCIENCE, *****es
