Author Topic: [WTS] Realforce 87 10AE U55g Silent YF110S  (Read 48124 times)
Offline fknraiden
  • Trade Count: (0)
« on: Wed, 07 May 2014, 19:15:01 »
WTS:
REALFORCE 87 10TH Anniversary edition. Model YF110S
Basically new. Swapped the variable domes for uniform 55g.
Stock silenced topre sliders, not hypersphere or the mx compatible ones.
Does not come with original box or spare keycaps. No idea what happened to it.
Unnoticeable keycap wear.
$340 shipped priority 2 day conus
Sold:
Hypersphere silencing rings $45 Shipped
Slightly reduces travel distance, I think its pretty decent, definitely quiet. Moreso than my stock silenced RF.
I have a few more laying around I'll include, but this is enough for a RF87. Note, you cannot put one on the left control.
IBM SSK $300+3%PP+$25 S/H CONUS
Bought from someone who sent 7+ of these to Maxx Wood over at Phosphorglow to have these bolt modded by the best.
I really hate to let this thing go, but it's become more of a show piece for me, and I can really use the money for more pressing stuff.
This thing is super clean. haven't seen many others without this lack of "antiquing".
It should go without saying, but every key works and are the original 1 piece caps.
Just realized I didn't get a photo of the cable, but its the original beige half coiled PS2>SDL. pics upon request.
I have a nice foam padded box I'll be shipping it in, so shipping will probably be more than the usual large flat rate.
Please let me know if you have any questions.
www.imgur.com/a/1BEYy
60% bent plate $35 Shipped
They appear to accept a plate mounted cherry stab, and support switch top removal.
Made from 316SS.
Painted cyan. Not as blue as in photos.
Complete hardwire kit $115+Shipping (~15$)
Was going to do another build but never got around to it.
Comes with everything you need. CoolerMaster case with removable plug.
Full 104 Cyan on White set from Feng(new) OEM profile ABS
90 MX blacks(vintage)
Teensy 2.0
costar stabs and inserts
Will include a ton of magnet wire(not photod)
I do have the rubber skids and the collapsible feet. let me know if you wanted them painted.
NEW Cherry Red full set from Ivans pbt r4 Cherry profile, dyesubbed legends $70 Shipped
Realforce 87 variable $130+ship(~$15)
Bought from EK about 4-5 months ago, but it also has brand new domes and springs on it.
Unfortunately I cant seem to find the box. but will be packed just fine for shipping.
Comes with PBT and ABS spacebar.
Will trade for topre clack.
60% bent plate
Bought these to put a couple kb's together, didn't end up getting around to that.
They have started to oxidize and have a little rust build up on them. I'm sure it would come out with sandpaper, or even a dremmel if you have one handy.
Made from 316SS
I guess some of you cant see well, but these WILL NOT WORK WITH A POKER OR OTHER 60%
$40 Shipped
I can also spray-paint these "Gloss Seaside". I haven't used it yet. but looks just like cyan.
3x 1.25u bottom row blanks from the WoP GMK pack
GMK Dolch
1 base set.
1 color pack
2 extra matching 1.5u alts from cmyk pack.
Extra 7u spacebar.
No gloss, some marks from keypuller on bottom edges.
Comes in GMK ziplock bag.
Duck Lightsaver v2! With lubed 85g gold springs and tactile grey stems. 2x3mm cyan leds. Green side leds
Been my baby for close to a year now.
Not a single scratch or dent anywhere on the case. Perfect.
This will be a combo deal and I'll get to that in a few.
This originally was sold to me with a v1 plate, if you know anything about the differences you already know that it doesn't support a 1800 layout. I got a replacement v2 pcb and took a dremel to the bottom row of the plate, see below. You can also refer to my work log below.
https://geekhack.org/index.php?topic=69866.msg1678285#msg1678285
I will also include 2 acrylic cutouts for the side leds and 2 1u blockers that match the black case(not pictured)
I will also be including the old v1 pcb. It has been mostly scrapped, diodes removed and a few traces pulled, repairable and marked in pen.
NOXIOUS V2 with "bleed"
Looking for a BS clack or bro bot. Let me know what you got. Can add money to trade.
I will add another picture with a timestamp when I get home. These are from my post in WDYGITMT THREAD.
REALFORCE 87UB (45g Variable)
scratches on bottom, some shine on case top above arrow cluster near return. otherwise amazing.
Purple(lavender?) mods available for an extra $10.
IBM Model M 1391401
Bolt Modded, Cleaned, includes original SDL>PS2 and PS2>USB adapter.
Comes with light blue sheet from Maxx Wood @ phosphorglow.net
IBM Model M 1391401
* Bolt Modded, everything has been cleaned. Steel sanded, polished and the back has been coated in rusto clear coat
* Full set of Green Dyesub pearl/pebble keycaps from Unicomp.[$40]
* Universal Model M USB Controller(TMK and Soarer compatible)[$38]
* Light green colored underlay from Maxx  @phosphorglow.net
* Will include: USB-A>USB-B cable, Original controller, and keycaps.
124 Vintage Blacks
from wyse keyboards[plate mount] all tested with meter.
Used Filco 104 ANSI WoB set, keys are shiny and heavily used. will clean before ship.
100x Tactile Grey springs[Brand new]
96x MX Clear Pcb mount.
Brand new, desoldered once, all contacts are practically new: tiny bit of solder at base.
96 MX Blue plate mount +1 Mx white
pic is a clear, got mixed up, will come with 1x white. Practically new, includes sip sockets already in switch.
Poker II mx clears, white 2x3x4 leds
Used for 4 months or so. near perfect, no scratches or dents, all switches feel nice and i've never had any problems. keycaps not included.
Dyesub novelties
Dolch cherry
shiney on some keys, none completely glossed over.
45g springs from Originative
Dolch extras
Stepped caps is now centerstemmed, scrapes on left side, all keys are slightly used.
GMK Purple Extras
Poker II PBT keyset w/ blank
GMK(EK) Mods+WASD+Arrows
40 Cherry MX Clear switches Plate Mount
GMK Esc's
61 used cherry mx brown plate mount
SP DSA Black extras
broken costar stabalizers that are glues into the Right Shift(dont ask) could take a donor if you'd like i'll include it.
Assorted Novelties(Esc's gone)
GMK Code
GH set
5 SP keys
All prices include shipping. International pays difference.
« Last Edit: Tue, 09 May 2017, 17:06:52 by fknraiden »
Offline fknraiden
  • Trade Count: (0)
Re: [WTS]stuff [WTB] TKL MX Blue
« Reply #1 on: Thu, 08 May 2014, 20:13:16 »
updated WTS
Offline RojoNinja
  • Trade Count: (0)
« Reply #2 on: Thu, 08 May 2014, 20:23:21 »
Blank poker 2 mods and GMK purple keys, gah I wish I had money.
 GLWS
Offline billnye
  • ability man
  • Trade Count: (0)
« Reply #3 on: Thu, 08 May 2014, 20:25:20 »
YGPM!
Offline t2russo
  • Trade Count: (0)
« Reply #4 on: Thu, 08 May 2014, 20:27:55 »
gmk escapes, code, wasd, red and blue mods plz
Offline Blackehart
  • Trade Count: (0)
« Reply #5 on: Thu, 08 May 2014, 20:54:23 »
"hope you had more of that slick purple set" bump
Offline Siilver_Samurai
  • Trade Count: (0)
« Reply #6 on: Thu, 08 May 2014, 22:53:59 »
Interested in the poker set.
"Empty your mind, be formless. Shapeless, like water. If you put water into a cup, it becomes the cup. You put water into a bottle and it becomes the bottle. You put it in a teapot, it becomes the teapot. Now, water can flow or it can crash. Be water, my friend.”
― Bruce Lee
Offline findingthelimit
  • Trade Count: (0)
  • Rawr
« Reply #7 on: Fri, 09 May 2014, 18:39:50 »
Sorry to jack this thread for a question, but the keycaps sold at EK are from GMK? Implying they're Cherry profile and PBT? :O
Poker 2 reds, GH60 42g ergo clears
Offline fknraiden
  • Trade Count: (0)
« Reply #8 on: Fri, 09 May 2014, 19:43:30 »
The "authentic cherry double shots" are abs and made by gmk
Offline fknraiden
  • Trade Count: (0)
Re: [WTS]stuff [WTB] TKL MX Brown
« Reply #9 on: Sat, 10 May 2014, 03:53:29 »
Update WTB
Offline fknraiden
  • Trade Count: (0)
Re: [WTS]stuff [WTB] GHpad
« Reply #10 on: Tue, 13 May 2014, 21:58:38 »
bump
Offline fknraiden
  • Trade Count: (0)
« Reply #11 on: Wed, 14 May 2014, 23:53:36 »
Still looking
Offline fknraiden
  • Trade Count: (0)
Re: [WTS]stuff [WTB] "MX Clear switch
« Reply #12 on: Sat, 24 May 2014, 17:56:43 »
Updated
Offline slickmamba
  • Trade Count: (0)
« Reply #13 on: Sat, 24 May 2014, 21:12:09 »
What are the sizes on the DSA caps?  If they fit the ergodox (1.5s and 2)  I will take it!
Hi :)
Offline fknraiden
  • Trade Count: (0)
« Reply #14 on: Sat, 24 May 2014, 21:53:57 »
I can double check all the sizes when I get home, but they are a modifier pack for ansi missing a right shift
Offline fknraiden
  • Trade Count: (0)
Re: [WTS]stuff [WTTF] 60% mx clear
« Reply #15 on: Wed, 28 May 2014, 05:35:36 »
Updated
Offline fknraiden
  • Trade Count: (0)
« Reply #16 on: Sat, 31 May 2014, 23:17:36 »
Updated
Offline RESPRiT
  • Trade Count: (0)
  • HHKB = ❤
Re: [FS]stuff [WTTF] 60% mx clear
« Reply #17 on: Sat, 31 May 2014, 23:33:46 »
How many springs are there?
Offline fknraiden
  • Trade Count: (0)
« Reply #18 on: Sun, 01 June 2014, 00:01:47 »
Sherry's site says its 100-110. haven't counted them.
http://www.originativeco.com/collections/accessories/products/springs
Offline Willyc277
  • Trade Count: (0)
« Reply #19 on: Sun, 01 June 2014, 14:15:07 »
PMed about novelties.
Offline fknraiden
  • Trade Count: (0)
Re: [FS] stuff [WTB] mx switch tops
« Reply #20 on: Wed, 04 June 2014, 07:37:22 »
bump
Offline fknraiden
  • Trade Count: (0)
Re: [FS]switches cap and such[WTB] mx switch tops
« Reply #21 on: Thu, 05 June 2014, 08:41:05 »
updated
Offline fknraiden
  • Trade Count: (0)
Re: [FS]switches caps and such[WTB] mx switch tops
« Reply #22 on: Fri, 06 June 2014, 12:43:01 »
Bump
Offline minho
  • Trade Count: (0)
  • i'm kind of back
« Reply #23 on: Sat, 07 June 2014, 01:50:53 »
edit:nvm, misread price. sorry zz.
Offline fknraiden
  • Trade Count: (0)
« Reply #24 on: Thu, 12 June 2014, 04:38:04 »
updated
Offline margo baggins
  • Dungeon Dweller
  • Trade Count: (0)
  • Get back to work!
« Reply #25 on: Thu, 12 June 2014, 05:58:23 »
Hello,
Can I get that GMK code please? Send me details etc. Can you ship to the UK?
I got boards.
Offline adventurepoop
  • Trade Count: (0)
  • I make keyboards, I guess.
« Reply #26 on: Thu, 12 June 2014, 10:44:15 »
I would want that new key, it looks dsa right??
Offline fknraiden
  • Trade Count: (0)
« Reply #27 on: Mon, 30 June 2014, 18:16:14 »
Bump
Offline IMHB
  • Trade Count: (0)
« Reply #28 on: Fri, 04 July 2014, 20:04:34 »
PMed about the switches a few days ago... please reply
Offline fknraiden
  • Trade Count: (0)
« Reply #29 on: Fri, 11 July 2014, 22:33:14 »
bump/update
Offline fknraiden
  • Trade Count: (0)
« Reply #30 on: Fri, 01 August 2014, 04:03:19 »
bump
Offline Ekmod
  • Trade Count: (0)
« Reply #31 on: Mon, 04 August 2014, 12:38:00 »
YGPM
Offline fknraiden
  • Trade Count: (0)
« Reply #32 on: Fri, 17 October 2014, 14:10:44 »
Bump
Offline Dakine234
  • Trade Count: (0)
  • Live, Love, ALOHA
Re: [FS]novelties
« Reply #33 on: Fri, 17 October 2014, 19:15:50 »
You still have the green keycap at the bottom right?  If so whats the finish on it?
Poker II mx blues + Custom Poker X with mx clears, blues and old blacks
Offline Pliny
  • Trade Count: (0)
  • has 1800 fever
Re: [FS]novelties
« Reply #34 on: Sat, 18 October 2014, 02:53:24 »
YGPM  ;)
"He will never, ever give you up. And, most importantly, he will never, ever let you down.”
- Melania T.
Offline pyroman07
  • Trade Count: (0)
Re: [FS]novelties
« Reply #35 on: Sat, 18 October 2014, 06:30:04 »
I'm interested in the Aperture novelty.  I'll try to remember to message you tomorrow or Sunday because it is 4:30AM and I have work tomorrow afternoon.
« Last Edit: Sat, 18 October 2014, 15:47:02 by pyroman07 »
Offline Lurch
  • Trade Count: (0)
Re: [FS]novelties
« Reply #36 on: Sat, 18 October 2014, 10:20:13 »
I'll take the gh set if still available
Quote from: Flyersfan1
Offline fknraiden
  • Trade Count: (0)
Re: [FS]novelties [WTB] Dolch base and color pack
« Reply #37 on: Sun, 19 October 2014, 16:39:36 »
bump
Offline pyroman07
  • Trade Count: (0)
« Reply #38 on: Wed, 22 October 2014, 01:11:11 »
I sent you a PM a few days ago if you didn't see.
Offline fknraiden
  • Trade Count: (0)
Re: [FS]novelties [WTB] lightsaver
« Reply #39 on: Wed, 22 October 2014, 17:11:41 »
Bump
Offline fknraiden
  • Trade Count: (0)
Re: [FS]R2 dyesubs [WTB] GMK keyset
« Reply #40 on: Wed, 26 November 2014, 23:28:16 »
bump
Offline fknraiden
  • Trade Count: (0)
Re: [FS]R2 dyesubs, Dolch alphas [WTB] GMK keyset
« Reply #41 on: Sat, 06 December 2014, 17:50:16 »
bump
Offline fknraiden
  • Trade Count: (0)
« Reply #42 on: Sun, 07 December 2014, 17:58:07 »
bump
Offline fknraiden
  • Trade Count: (0)
« Reply #43 on: Mon, 08 December 2014, 17:26:07 »
Bump
Offline fknraiden
  • Trade Count: (0)
« Reply #44 on: Wed, 10 December 2014, 18:33:54 »
bump
Offline fknraiden
  • Trade Count: (0)
« Reply #45 on: Fri, 12 December 2014, 00:07:45 »
bump
Offline fknraiden
  • Trade Count: (0)
« Reply #46 on: Sun, 14 December 2014, 18:25:33 »
bump
Offline fknraiden
  • Trade Count: (0)
« Reply #47 on: Thu, 18 December 2014, 18:19:45 »
bump
Offline fknraiden
  • Trade Count: (0)
« Reply #48 on: Fri, 19 December 2014, 23:24:04 »
bump
Offline fknraiden
  • Trade Count: (0)
« Reply #49 on: Sun, 21 December 2014, 21:12:03 »
bump
