Author Topic: [IC] Duck Viper and Eagle  (Read 85784 times)
Offline yicaoyimu
Re: [IC] Duck Viper and Eagle
« Reply #100 on: Sun, 11 May 2014, 09:50:26 »
goddamnit. as if i wasn't already broke enough with all the goddamned lego coming out this summer...
+1.
I need to sell more stuff, but this is a fantastic deal for all that's included.
Just out of curiousity, I noticed some of the pics showed a dedicated number pad unit.  Is that going to be offered as well, or just the two different keyboards?
There's another group buy by Elton for that Butterfly Pad a long time ago. I wish Duck could do another round though.
Butterfly matches the case for the eagle/viper?
http://duck0113.tistory.com/83
Offline Yslen
« Reply #101 on: Sun, 11 May 2014, 17:26:16 »
I've registered my interest in an Eagle, figuring that by the time this group by actually happens I'll be settled in with my new job and able to afford it :D
Both of these boards look great, and the price is actually pretty awesome, even after import costs, considering what I've heard about the quality of Duck boards. I love the look of the Viper... but I have no caps to fit it and about six sets for the more standard Eagle.
Are there any details on the lighting options? Do both models have the down-angled LEDs at the edges / somewhere on the PCB to add these while building? Do we know what kind of LED modes there are for the top mounted LEDs?
Also, where's that blue on beige dye-sub set from? The only sets I've seen like that were winkeyless.
Offline minho
  • i'm kind of back
« Reply #102 on: Sun, 11 May 2014, 18:19:20 »
Don't let this deter you!
The TaiHao Groupbuy has cheap Tsangan sets and base sets and they all look really nice.
Offline Yslen
« Reply #103 on: Sun, 11 May 2014, 20:50:21 »
The issue isn't that I won't be able to get caps for a Viper, it's that I'll be sad that I can't use the caps I have and like. I like the look of the Eagle anyway, though, so we're good :)
Offline yicaoyimu
« Reply #104 on: Sun, 11 May 2014, 20:57:33 »
That's why you should *always* get a tsangan set when you participate a groupbuy.
Offline minho
  • i'm kind of back
« Reply #105 on: Sun, 11 May 2014, 21:11:36 »
Does the group buy include these side windows?
Offline yicaoyimu
« Reply #106 on: Sun, 11 May 2014, 21:20:23 »
I don't think so. Those side windows are not included in any previous Duck groupbuy.
Offline Yslen
« Reply #107 on: Sun, 11 May 2014, 21:20:53 »
I considered it a while back, but decided it would be cheaper and less frustrating to stick with one layout for everything MX. If the price I pay for that decision is having my choice of two amazing looking boards reduced to one amazing looking board... I can live with that :D
/thread derail
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #108 on: Sun, 11 May 2014, 21:33:16 »
ALWAYS buy a Tsangan even if you don't need it now.  But tomorrow, when you fork out that money for a Korean Keyboard - then find out you need those specific extra keys that only a Tsangan could provide.........
Then you're right to tie a rope around the nearest roof beam to hang yourself because you had the opportunity and you let it pass, which here on Geekhack is totally unforgivable  :'( .
Offline Elrick
  • Hype Master
« Reply #109 on: Sun, 11 May 2014, 21:36:26 »
So why would you want to use a double sided tape to attach these pieces onto your keyboard?  Weird what some people would like to see on their keyboards these days.......
Offline elton5354
« Reply #110 on: Sun, 11 May 2014, 21:53:38 »
I find the acrylic sides help disperse the LEDs evenly.  You can see from photoelectric's photos with and without the pieces with LEDs on.  It looks quite nice. :)
« Reply #111 on: Sun, 11 May 2014, 22:42:11 »
I know nothing other than that 7xxx is better than 6xxx.
Sadly, this is not the case.
from wikipedia (still learning this blank board, so copypasta is faster)
6000 series are alloyed with magnesium and silicon, are easy to machine, and can be precipitation hardened, but not to the high strengths that 2000 and 7000 can reach.
7000 series are alloyed with zinc, and can be precipitation hardened to the highest strengths of any aluminium alloy.
7000 is just harder and more brittle IF it's hardened.
6061 and 7075 are common.
6061 density of 2.7 g/cm^3, yields at 240 MPa minimum (for T6 )
7075 density of 2.81 g/cm^3, yields at 430 MPa minimum (for T6 ) and is significantly more expensive to machine. un-heat treated 7075 is only 275 MPa max though.
So if I understand this correctly, the main difference between soft anodized 6061 and hard anodized 7075 is just the hardness?
so anodyzation just increases the thickness of the Aluminium dioxide outer layer. It's a hard ceramic which helps protect the metal underneath (if only rust was less brittle :( ). Hard vs. soft anodyzed are just qualitative terms and don't really mean anything quantitative here.
But they are very different. Hardness, yield strength, ultimate strength, composition, they will likely have different corrosion resistance, but I didn't get far enough to take a class on corrosion.
Offline elton5354
« Reply #112 on: Sun, 11 May 2014, 23:44:20 »
With this amount of interests, it'll take them longer to produce. I'd say maybe end of July to August..
Offline sth
  • 2 girls 1 cuprubber
« Reply #113 on: Sun, 11 May 2014, 23:48:36 »
rats!!
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #114 on: Sun, 11 May 2014, 23:52:54 »
Sorry If this has been stated already. I have just seen "in a few months".    But when will this GB likely start and end?
Some of Ye ole  Keyboards -->
OTD Koala:  62g Old MX-Blacks   |   LZ-GH V2:  MX-?62g   |   KMAC2:   62g Tactile MX-Greys   |   LZ CLS s:   62g Vintage MX-Blacks   |   X60:   62g Vintage MX-Blacks   |   GON NerD 60:  62g Old MX-Clears   |   Filco MJ2 (Beige) TKL's:  62g MX-Clears  &   62g Vintage MX-Blacks   |   IBM '91 SSK
WTB/WTS/WTT ---->
Offline elton5354
« Reply #115 on: Sun, 11 May 2014, 23:53:56 »
After Lightsaver V2 group buy.  Likely the 3rd week of June.
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #116 on: Sun, 11 May 2014, 23:55:42 »
And that will be the start date correct (3rd week of June)?    How long should it run for?
WTB/WTS/WTT ---->
Offline elton5354
« Reply #117 on: Sun, 11 May 2014, 23:57:20 »
Depends on the determined date they can finish producing.
I should know when I start the group buy for this..
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #118 on: Mon, 12 May 2014, 00:00:01 »
Okay, I'm just trying to figure out how long I will have to pay/get the money once you announce that the GB has started.
WTB/WTS/WTT ---->
Offline Elrick
  • Hype Master
« Reply #119 on: Mon, 12 May 2014, 00:14:48 »
Is there any other way to adhere the acrylic than using double-sided tape?
Offline lionblinds
« Reply #120 on: Mon, 12 May 2014, 00:17:32 »
Interested in Eagle
Offline elton5354
« Reply #121 on: Mon, 12 May 2014, 00:18:41 »
Not that I know of...maybe glue?  :)) ;D
Courtesy of photoelectric's photos.  You can see the difference with and without the side acrylic.
https://www.flickr.com/photos/115329034@N04/sets/72157640117516876/
Offline minho
  • i'm kind of back
« Reply #122 on: Mon, 12 May 2014, 00:50:10 »
Is there any way to obtain these windows?
Offline elton5354
« Reply #123 on: Mon, 12 May 2014, 00:54:39 »
Someone can run a mini buy to make these in 'Murica?
Offline epzy
  • HHKB Fiend
  • ded
« Reply #124 on: Mon, 12 May 2014, 01:08:16 »
Someone please!
Offline WinterIsle
« Reply #125 on: Mon, 12 May 2014, 01:28:04 »
Interested with the side acrylics for lightsaver v1 if the price is right  :thumb: .
I wonder if there's option for frost one, might disperse light more evenly.
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #126 on: Mon, 12 May 2014, 01:32:48 »
I would definitely want frosted side acrylics if it were a option.
WTB/WTS/WTT ---->
Offline sth
« Reply #127 on: Mon, 12 May 2014, 01:41:39 »
i want side pieces that look like corn on the cob
Offline CK Briefs
  • formerly calvins1
« Reply #128 on: Mon, 12 May 2014, 01:49:01 »
I'd want side pieces that have the saver 'x' logo engraved onto it :S
Current Keyboards: Orion - 62g ergo clears;
A87 PS2AVR - 59g ergo clears; QFR - stock blues
Offline sth
« Reply #129 on: Mon, 12 May 2014, 02:21:23 »
no no you want cornsides
Offline tbc
« Reply #130 on: Mon, 12 May 2014, 02:28:47 »
so BOTH the eagle and the viper have side LEDS + normal legend leds?
Offline Zeal
    • Zeal Generation Inc.
« Reply #131 on: Mon, 12 May 2014, 02:30:35 »
Yes. Side LEDS are red by default as well.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #132 on: Mon, 12 May 2014, 02:31:44 »
Awesome. =)
Offline pasph
« Reply #133 on: Mon, 12 May 2014, 03:01:43 »
+1
Offline Medow
« Reply #134 on: Mon, 12 May 2014, 07:11:31 »
Interested in Viper. So good...
Also the acrylic sides would be sweet so +1 interest to those.
« Last Edit: Mon, 12 May 2014, 07:24:21 by Medow »
60% ALL THE WAY
Offline Elrick
  • Hype Master
« Reply #135 on: Mon, 12 May 2014, 07:25:04 »
The only glue I know of that won't eat Acrylic or affect Aluminum, is urethane glue.  But once it's applied you can't remove it once it sets within 24 hours.
Offline Medow
« Reply #136 on: Mon, 12 May 2014, 07:30:20 »
+1  :thumb:  :-*
60% ALL THE WAY
Offline tjweir
« Reply #137 on: Mon, 12 May 2014, 08:23:36 »
Apply directly to Viper.  I am so excite.
Pic is from BunnyLake.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #138 on: Mon, 12 May 2014, 08:28:19 »
Does anyone know if these could be replaced for other colors? Not for the group buy mind you, but to customize it after we receive them.
Offline elton5354
« Reply #139 on: Mon, 12 May 2014, 08:48:23 »
You can replace those LEDs. They're the SMD kind.
http://geekhack.org/index.php?topic=53942.0
More detail on photo's thread.
Offline mashby
    • Mashby
« Reply #140 on: Mon, 12 May 2014, 10:05:10 »
Sweet! Thanks for the link Elton.  :thumb:
Offline combataran
« Reply #141 on: Mon, 12 May 2014, 10:44:59 »
Filled in the form twice(accidentally!). Gonna sell my RF87u for this. Can't wait.
Cherry G80-1000HFD | CM Storm Spawn | Keypuller.com - Key Caps News & Database
Offline Yslen
« Reply #142 on: Mon, 12 May 2014, 11:13:39 »
Awesome. =)
How do the LEDs compare to the Lightsaver? Similar features or much more basic? Trying to decide what I really want.
Offline OnTheBrink
  • Work Hard. Play Harder.
    • Wired In Store
« Reply #143 on: Wed, 14 May 2014, 12:10:35 »
oh man, i just realized, with a name like viper, i'm totally going to have to have to put together some keys to match the colonial viper coloration:
Mm that WOULD be a nice color combo.
I much agree.
Offline mashby
    • Mashby
« Reply #144 on: Wed, 14 May 2014, 12:39:05 »
Same basic design. The Eagle/Viper is the 60% version of the Lightsaver.
Offline daerid
    • Rossipedia
« Reply #145 on: Fri, 16 May 2014, 19:54:30 »
Are these going to be programmable?
Offline nuclearsandwich
« Reply #146 on: Fri, 16 May 2014, 20:01:19 »
More than likely they'll be programmable with the same GUI tools and firmware that Duck's other boards use.
Offline Vintage
« Reply #147 on: Fri, 16 May 2014, 22:35:00 »
Very cool stuff. Will resistors (and controller) be pre-soldered or no? And if so, you need a different resistor for different colors of leds, correct?
CM QFR w/ MX Reds  | Logitech G900
Offline yicaoyimu
« Reply #148 on: Sat, 17 May 2014, 02:17:38 »
Diodes, resistors, controller are pre-soldered.
Offline findingthelimit
  • Rawr
« Reply #149 on: Sat, 17 May 2014, 15:32:09 »
Can anyone give me a (relatively) detailed description on the steps I need to take to assemble this board (or the lightsaver V2), or point me to a guide? I'm interested in learning how to build my own Korean custom! Would I need any aftermarket equipment (screwdriver, soldering iron, etc.)? I'm assuming that the diodes are presoldered.
Poker 2 reds, GH60 42g ergo clears
