Author Topic: [GB] Tai Hao (ANSI + Add-On Pack) Keyset Group Buy [ALL SHIPPED >> REFUND ISSUE]  (Read 1185694 times)
Offline thestage
Re: [GB] Tai Hao (ANSI + Add-On Pack) Keyset Group Buy (ANSI Price Revised)
« Reply #150 on: Tue, 13 May 2014, 02:07:18 »
If we don't hit the MOQ for purple, I'd definitely be interested it in buying a set by whatever other means are available as well.
« Reply #151 on: Tue, 13 May 2014, 02:30:02 »
How much is the purple set not in the GB?
i can gather the orders and ask for a better price from china vendor
the listed price in taobao is around 23 dollars
maybe 2-3 dollar mark down will be possible if we have enough order
but do not expect to have the add-on pack that we are having now
Yeah I can almost guarantee you tons of people would like that set, even at that price.  Speaking of which, I'd buy it at the non-GB price.  But do still run a GB.  We all like saving money.
Offline GhostofHarry
« Reply #152 on: Tue, 13 May 2014, 02:54:07 »
alright, maybe i can seek for vendors that still got those in stock
Offline Harrowed
  • My wallet has been hacked
« Reply #153 on: Tue, 13 May 2014, 03:52:10 »
Made some calculations from current 110 orders.
If the target MOQ is 300 then that MOQ for Dolch ANSI would be met with approximate amount of 303 total orders. MOQ for Granite ANSI would be met with approximate amount of 478 total orders. MOQ for Olivette ANSI would be met with approximate amount of 500 total orders.
Estimated how many orders we need to reach 4.5$ tier for each add-on pack then? With current order rate Dolch add-on would hit the ultimate target when total of 423 orders have been made. Granite add-on would need approximate amount of 717 total orders and Olivette add-on 767.
So I think 500 orders total would be good goal (to start with at least). Make sure you advertise this in deskthority (LOTS of ISO users) and other places all over the internet.
Ergodox MX Blues | Rosewill RK-9000
« Reply #154 on: Tue, 13 May 2014, 04:03:37 »
MOQ are counted seperately
different colour and different set has different MOQ, so we need 300 for all of them
Offline Harrowed
« Reply #155 on: Tue, 13 May 2014, 04:25:15 »
And I'm calculating them separately :D What I mean that with current order rate with 500 orders from 500 people  MOQ of 300 for each set would be probably met. When I talk about one order I mean order from one person possibly containing several sets. Let's phrase it this way:
In 303 orders from 303 people there will be approximately 300 Dolch ANSI sets ordered with current order rate (and less for others). With 500 orders there will 300 or more sets ordered for all three (with current order rate).
« Reply #156 on: Tue, 13 May 2014, 04:31:36 »
ic...i got what u are saying
what we lack are some big orders like last time.
there will be orders that takes 50 or so of each set
maybe some other forums, or vendors here.
ofcuz we cant count on those orders.
but they make big changes
actually i should add around 40 add on pack each to the order,
one chinese vendor has asked for that
Offline Blackehart
« Reply #157 on: Tue, 13 May 2014, 11:05:29 »
I can always get u a purple set :)
Even if it's not in the gb
Thanks a lot! Yep, I meant the 6.25. Now I can Dolch up my Leopold 200, I am even more excited for this!
Would it be better for me to order now and amend my order later if my friend(s) decide to join my order. Or should I wait a week or so and do it all together? I am just thinking in regards to you getting a better idea of the numbers etc...
I don't think anyone is going to worry over $1 per pack. But you should try to negotiate them down to $14.50 :p
I shall take a picture for u of how the space at looks like
And for the $1 mark up, I will try to ask taihao to give that to us for free if we got enough order
just ordered one of everything, including Add-on pack. Hopefully more people will jump on these add-on packs.
By the way Harry, do you think its possible for them to make 6 unit spacebar? Thank you and let me know
Tainan only have 7x 6.25x and 5x space bar mold
So I think it's hard to get a 6x spacebar
I'd love a purple set and another (mebbe two) when the moq is set!
-Blacke
Offline minho
  • i'm kind of back
« Reply #158 on: Tue, 13 May 2014, 16:28:06 »
Henry, I just had a thought...
If one of the main sets don't hit MOQ but the addon pack does, will we have the opportunity to cancel our order? I wouldn't be interested in an Olivette addon set unless I can also get the base set for it too :(
Offline feizor
« Reply #159 on: Tue, 13 May 2014, 16:32:27 »
Thats very unlikely. No one is going to buy the add on without the base pack.
Offline swornxin
    • Nailed Down Custom Pins
« Reply #160 on: Tue, 13 May 2014, 16:49:06 »
Really hoping these all hit MOQ.  Has a link been posted on other forums, or is this GH exclusively?
EDIT:  Also, after a reading a little, I'm getting a little worried that the space bar stem layout will not be compatible with my QFR/Poker II.  Does anyone have some insight to this?  Thanks.
« Last Edit: Tue, 13 May 2014, 17:30:52 by swornxin »
Octagon - 62g Cherry tactile greys
Phantom - 65g Cherry tactile greys
FC660M - Cherry blues
KC60 - Gateron browns
Offline OnTheBrink
  • Work Hard. Play Harder.
    • Wired In Store
« Reply #161 on: Tue, 13 May 2014, 17:33:34 »
Wait, so these are only $14 $15 for a full set?
Why so cheap? If that's the case I am getting at least two sets. Probably all 3.
Offline Pacifist
  • on hiatus
« Reply #162 on: Tue, 13 May 2014, 17:37:03 »
as stated before
So many options. Why are these keycaps so cheap?!
Big MOQ+China+thin
Offline minho
  • i'm kind of back
« Reply #163 on: Tue, 13 May 2014, 17:41:07 »
The Addon pack has a MOQ of 100 while base has MOQ of 300 though
Offline OnTheBrink
    • Wired In Store
« Reply #164 on: Tue, 13 May 2014, 19:18:49 »
as stated before
Big MOQ+China+thin
Thin? It says they are double-shot.
Offline Pacifist
  • on hiatus
« Reply #165 on: Tue, 13 May 2014, 19:23:26 »
as stated before
Big MOQ+China+thin
So?
Offline nuclearsandwich
« Reply #166 on: Tue, 13 May 2014, 19:24:30 »
as stated before
Big MOQ+China+thin
They're indeed doubleshot but they're OEM profile and not much thicker than regular ABS keycaps. Think Signature Plastic's DCS profile but taller.
Offline swornxin
« Reply #167 on: Tue, 13 May 2014, 19:29:05 »
If I've decided to buy more sets, should I just go through the order form again, or should I PM the OP.  Thanks.
Offline OnTheBrink
    • Wired In Store
« Reply #168 on: Tue, 13 May 2014, 19:29:38 »
as stated before
Big MOQ+China+thin
So?
Damn man, what's your problem?
as stated before
Big MOQ+China+thin
Okay cool, thanks for clarifying.
Offline minho
  • i'm kind of back
« Reply #169 on: Tue, 13 May 2014, 19:35:23 »
as stated before
Big MOQ+China+thin
So?
Not sure where the conflict begins, but just FYI, doubleshot keycaps can be thin. The doubleshot legend plastic is probably just in the top part of the keycap, not on the sides, resulting in thin keycaps.
Offline OnTheBrink
    • Wired In Store
« Reply #170 on: Tue, 13 May 2014, 19:42:15 »
as stated before
Big MOQ+China+thin
So?
Ahh, I understand now. I always thought double shot just meant the whole key cap was double molded.
I am learning more everyday but still very much a newb. Thanks for clearing that up. Some of this stuff can get confusing/overwhelming, especially when you see 100 things you want lol.
I put myself down for two sets. The Dolche and the Granite. I really like the Dolche especially. How do these kinds of double shot ABS feel vs. thin PBTs (which I am using now)?
« Last Edit: Tue, 13 May 2014, 19:43:48 by OnTheBrink »
Offline Pacifist
  • on hiatus
« Reply #171 on: Tue, 13 May 2014, 19:48:49 »
About the same. PBT will be slightly better because its more dense
Offline OnTheBrink
    • Wired In Store
« Reply #172 on: Tue, 13 May 2014, 19:56:42 »
Cool, thanks for the info guys.
« Reply #173 on: Tue, 13 May 2014, 20:44:18 »
About the same. PBT will be slightly different because it's more dense.
FTFY
« Reply #174 on: Tue, 13 May 2014, 22:51:37 »
The first Tai Hao GB provided double-shot blanks for some of the modifiers.
That was very funny ;)
Offline retrochick
  • goodbye my wallet
« Reply #175 on: Tue, 13 May 2014, 22:53:38 »
I ordered 1 of each plus the add on pack for each set. Maybe I will finally get my dolch set after all :)
Offline Badwrench
  • ummmm.....I forgot
« Reply #176 on: Tue, 13 May 2014, 23:26:22 »
Added a dolch.  I need a set that is more subdued, all I have are bright colors.
« Reply #177 on: Wed, 14 May 2014, 00:00:27 »
For clarifying...
Taihao keycaps are made in tw
Not china
I asked if they can send me things from china to reduce shipping cost
they said they were produced in tw
and has no way to reduce the shipping
Also. All the MOQ are 300, and has not compatibility problem with normal layouts like poker 2 and qfr
« Last Edit: Wed, 14 May 2014, 00:49:20 by GhostofHarry »
Offline skuko
« Reply #178 on: Wed, 14 May 2014, 00:47:34 »
Also. All the MOQ are 300, and has not compatibility probe=problems with normal layouts like poker 2 and qfr
you had me confused for a second there.
« Reply #179 on: Wed, 14 May 2014, 00:49:45 »
sorry that was typed in ipad ;D
Offline feizor
« Reply #180 on: Wed, 14 May 2014, 04:09:49 »
Everyone on GH will be rocking these.
Offline Dr Xav
« Reply #181 on: Wed, 14 May 2014, 05:44:18 »
First GB, let's hope it goes well ;)
Offline kittykatmax
« Reply #182 on: Wed, 14 May 2014, 11:43:06 »
Sorry for the noob question, but for a QFR tenkeyless do you just need a base set?
Offline swornxin
« Reply #183 on: Wed, 14 May 2014, 11:57:39 »
Yup.  The base set will work.
Offline Razor Lotus
« Reply #184 on: Wed, 14 May 2014, 18:30:28 »
http://item.taobao.com/item.htm?spm=a230r.1.14.23.WzP2t2&id=38085962577
More pictures on what they look like i suppose? Looks great! :D
« Reply #185 on: Wed, 14 May 2014, 18:47:37 »
I probably shouldn't be as excited about a Dolch set as this.  And it's not even original Dolch!
I probably should ordr a set :))
Offline Mhugh003
« Reply #186 on: Wed, 14 May 2014, 19:03:32 »
Just wanted to make sure I have this right so I dont miss out..
All stages end on May 31st, and we dont move on to the next stage until the prior has all of the MOQs met?
I only want the purple set, but not sure the GB will make it that far.
Offline Razor Lotus
« Reply #187 on: Wed, 14 May 2014, 19:42:15 »
Welcome to GH haha.
I don't think all of them end on May 31st? I just think he will start the next one when the prior MOQ is met. I think one of the reasons why he went with these colour options first was cause they gathered the most interest in the interest check thread.
I'm fairly sure the gb for the purple set will come. I've been noticing a few people wanting that as well
Offline Mhugh003
« Reply #188 on: Wed, 14 May 2014, 20:45:56 »
Thanks ^^
That makes more sense then, I appreciate the help!
I'll keep an eye out for when the third stage starts.
Offline lightsout714
« Reply #189 on: Wed, 14 May 2014, 21:07:04 »
Don't think I can pass these up.
Offline mark_thaddeus
« Reply #190 on: Wed, 14 May 2014, 23:21:11 »
Can someone confirm if my calculation is correct?
I want to get the "dolche" and "granite" and I will be paying via Paypal so the computation is:
$14 + $14 = $28 for the two sets
$5+$3+$3 = $11 shipping plus tracking
$28 * 104.4 = $34.796 for two sets plus paypal and 0.30
$45.796 - Grand Total
Did I get that right?
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #191 on: Wed, 14 May 2014, 23:23:02 »
The price was raised from $14 to $15 a set.
Some of Ye ole  Keyboards -->
OTD Koala:  62g Old MX-Blacks   |   LZ-GH V2:  MX-?62g   |   KMAC2:   62g Tactile MX-Greys   |   LZ CLS s:   62g Vintage MX-Blacks   |   X60:   62g Vintage MX-Blacks   |   GON NerD 60:  62g Old MX-Clears   |   Filco MJ2 (Beige) TKL's:  62g MX-Clears  &   62g Vintage MX-Blacks   |   IBM '91 SSK
WTB/WTS/WTT ---->
« Reply #192 on: Wed, 14 May 2014, 23:25:25 »
Ok adjusting it to $15:
$15 + $15 = $30 for the two sets
$30 * 4.4% = $31.62 for two sets plus paypal and 0.30
$42.62 - Grand Total
Is this correct now or do I add the 4.4% including the shipping?
« Last Edit: Wed, 14 May 2014, 23:29:44 by mark_thaddeus »
« Reply #193 on: Wed, 14 May 2014, 23:25:27 »
Those price tiers are very nice as we go down. I wonder where we may be at with Dolch now, expected to break 100?
Offline Zeal
    • Zeal Generation Inc.
« Reply #194 on: Wed, 14 May 2014, 23:31:24 »
Is this correct now?
No.
PP fees should be multiplied with the shipping fees as well, since the receiver of the money gets deducted the final amount. I'm also not sure how you got your numbers either. I saw it in the $50 range before I quoted your post :P
2 sets = $30
$5 shipping + $3 full set + $3 tracking = $11
$41 * 1.044 + 0.3= $43.10 USD
« Reply #195 on: Wed, 14 May 2014, 23:37:52 »
No.
2 sets = $30
Than you Zeal for clearing that up!
Apologies if the computation was confusing, it was basically adding the $31.62 (w/ 4.4%) and $11(without 4.4%) Shipping to get to my numbers ($42.62).
Since you mentioned that shipping is included then yeah it's $41 + 4.4% ($1.804c) + $0.30c = $43.108 USD
Offline Zeal
« Reply #196 on: Wed, 14 May 2014, 23:40:38 »
No.
2 sets = $30
$43.104* which gets rounded down  :p
Offline swornxin
« Reply #197 on: Wed, 14 May 2014, 23:46:35 »
Isn't the MOQ on the ANSI set 300 and the ISO addon is 100? Pretty sure the tiered prices were for the addon only.
Offline minho
  • i'm kind of back
« Reply #198 on: Thu, 15 May 2014, 00:52:44 »
Yes.
Could anyone enlighten me as to what we would do if the AddOn pack for a set somehow hits its MOQ of 100 but the base set doesn't reach 300? I wouldn't really want an add-on pack without the base set.
« Reply #199 on: Thu, 15 May 2014, 01:27:58 »
although a tiered price starting from 100 order is set,
i didnt expect u guys to get one set of them without the ANSI
this would not happen
