Author Topic: [IC] RETRO RGB  (Read 8787 times)
Offline OnTheBrink
  • Work Hard. Play Harder.
    • Wired In Store
[IC] RETRO RGB
« on: Mon, 12 May 2014, 13:51:49 »
POLL: http://tinyurl.com/of76uqm
I am going to try to do my first GB if the interest is there. Going to start gauging ANSI interest first. Will probably run this through Signature Plastics as their prices were best if my memory serves correct a while ago.
Like I said, this is my first GB so any insight would be appreciated as in what files I need to get for SC to print the set and what documents people would need to fill.
Going to go with a darker blue due to problems with the legends last GB.
Image taken from Paranoid's thread here (http://geekhack.org/index.php?topic=50784.0)
« Last Edit: Sun, 18 May 2014, 13:54:53 by OnTheBrink »
Re: [IC] RETRO RGB
« Reply #1 on: Mon, 12 May 2014, 13:55:41 »
Will you use SP's group buy system?
And are those legends 7bit's?
Offline OnTheBrink
    • Wired In Store
Re: [IC] RETRO RGB
« Reply #2 on: Mon, 12 May 2014, 14:19:36 »
Most likely and yeah they're 7bits. He was kind enough to let us use them last IC, so I'm hoping he'll allow it again. This time, I'll take this all the way.
Re: [IC] RETRO RGB
« Reply #3 on: Mon, 12 May 2014, 14:43:45 »
Those are from 7bit's R4.  You should find a photo of the real thing and post it.
IMHO, they didn't come out very nice.
Offline pasph
Re: [IC] RETRO RGB
« Reply #4 on: Mon, 12 May 2014, 15:48:27 »
7bit made a mistake with that light blue color, legends are barely readable
Offline Harrowed
  • My wallet has been hacked
Re: [IC] RETRO RGB
« Reply #5 on: Mon, 12 May 2014, 15:55:43 »
I think those would work on grey keys...
Ergodox MX Blues | Rosewill RK-9000
Offline pasph
Re: [IC] RETRO RGB
« Reply #6 on: Mon, 12 May 2014, 16:01:47 »
Or with a darker blue like soware...
Re: [IC] RETRO RGB
« Reply #7 on: Mon, 12 May 2014, 16:10:46 »
Is this IC for a full set, or RGB modifiers? In either case, if 7bit agrees to let you use the legends, then he would be able to let SP know that it's okay to let you use the setup files as well.
Offline OnTheBrink
    • Wired In Store
Re: [IC] RETRO RGB
« Reply #8 on: Mon, 12 May 2014, 16:58:15 »
Yeah, he did that last time. SP just needed the permission. Perhaps since the legends aren't clear on the white keys, perhaps we should just go for the modifiers and the function keys.
What do you guys think?
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
Re: [IC] RETRO RGB
« Reply #9 on: Tue, 13 May 2014, 00:06:09 »
Just do the whole lot.  If you just do modifiers only they won't go with other key-sets easily.
All you have to do is change some colours so they are easily seen during the day or night.  White and light blue is a perfect example where they almost cancel each other out and they become opaque.  Just darken the blue slightly and it should be alright  :thumb: .
Online HoffmanMyster
Re: [IC] RETRO RGB
« Reply #10 on: Tue, 13 May 2014, 02:01:15 »
I'm potentially interested depending on how this shapes up.  I'm hesitant to go in if it's just modifiers, as I don't think they'll go very well with any other sets I have.
Offline n0rvig
Re: [IC] RETRO RGB
« Reply #11 on: Tue, 13 May 2014, 02:09:14 »
Great idea! That'd make this really pop
Offline feizor
Re: [IC] RETRO RGB
« Reply #12 on: Tue, 13 May 2014, 02:54:16 »
Looks good!
Offline Paranoid
Re: [IC] RETRO RGB
« Reply #13 on: Tue, 13 May 2014, 05:21:28 »
I would definitely make it with a darker blue, these were really not so visible. Bear in mind that in my picture up there I used blanks, so you won't see a thing on those obviously.
Offline bianco
Re: [IC] RETRO RGB
« Reply #14 on: Tue, 13 May 2014, 06:02:03 »
interested. but would there be an alternative color for the alphas/base? something other than white?
Offline OnTheBrink
    • Wired In Store
Re: [IC] RETRO RGB
« Reply #15 on: Tue, 13 May 2014, 07:42:08 »
I agree on the darker blue, so darker blue it is. I'll update the OP.
Offline pr0ximity
Re: [IC] RETRO RGB
« Reply #16 on: Tue, 13 May 2014, 09:28:23 »
I'd be interested in a modifier pack. Think I'd prefer DCS profile.
| Flickr | KMAC 1.2 | Koala | GSKT-00-Z | GSKT-00-AEK | GON NerD60 | Jane V2 CE | Whale | J80S | Ibis | Pro2 | Pro1 | 356mini | 356CL DGE | G80-5000 HAMDE | IBM 1390120 | IBM F AT | IBM F122 | IBM 3101 | Zenith Z-150
Offline archer
Re: [IC] RETRO RGB
« Reply #17 on: Fri, 16 May 2014, 10:13:35 »
SoWaRe blue would look great on these! That would essentially be my dream set. Count me in!
Also, the R4 Retro alphas are actually a really light grey, not white. I hope that you preserve that coloring. Light grey + SoWaRe blue would be beautiful.
« Last Edit: Fri, 16 May 2014, 10:16:17 by archer »
Offline FrostyToast
  • Litshoard
Re: [IC] RETRO RGB
« Reply #18 on: Fri, 16 May 2014, 10:17:15 »
I would so buy a set of these! I've been looking for something to go with my sprit keyboard.
Quote from: elton5354
Offline OnTheBrink
    • Wired In Store
Re: [IC] RETRO RGB
« Reply #19 on: Fri, 16 May 2014, 10:20:35 »
I'd like to get more interest on these.
I really want to move these to a GB but there aren't enough people yet.
I'm going to update the OP that well be using a darker blue for the legends.
Offline bdtbinh
  • In Geek I trust
Re: [IC] RETRO RGB
« Reply #20 on: Fri, 16 May 2014, 13:29:17 »
Will be in for sure  ;D
U need a poll for people to vote that they are interested or not. And the legend, the alpha of SoWare will suits best.
Offline mrtee0
Re: [IC] RETRO RGB
« Reply #21 on: Sun, 18 May 2014, 07:11:47 »
yup :3
Offline ideus
  • Björkö.
Re: [IC] RETRO RGB
« Reply #22 on: Sun, 18 May 2014, 08:15:37 »
What profile is this?
Offline bdtbinh
  • In Geek I trust
Re: [IC] RETRO RGB
« Reply #23 on: Sun, 18 May 2014, 13:09:14 »
DCS from what i recall
Offline OnTheBrink
    • Wired In Store
Re: [IC] RETRO RGB
« Reply #24 on: Sun, 18 May 2014, 13:55:16 »
The thread has been updated with a poll. Please vote accordingly. Thanks.
Offline TLSC.wipeOut
  • "Who dares, wins"
Re: [IC] RETRO RGB
« Reply #25 on: Sun, 18 May 2014, 14:08:48 »
How much would the set potentially cost?
OTD 456GT with Lubricated 68g Gold Spring MX Clears and GMK Dolch Keycap set
WTB: KMAC2 kit
Offline FrostyToast
  • Litshoard
Re: [IC] RETRO RGB
« Reply #26 on: Sun, 18 May 2014, 14:26:26 »
Would this be dyesub PBT or DS ABS?
Offline ideus
  • Björkö.
Re: [IC] RETRO RGB
« Reply #27 on: Sun, 18 May 2014, 17:59:06 »
Thanks for the answer, I'd prefer DSA though.
Offline luisbg
Re: [IC] RETRO RGB
« Reply #28 on: Mon, 19 May 2014, 00:51:32 »
Interested.
Leopold FC660M - Brown mx switches - black case - white blank keys :: ErgoDox - Blue mx switches - classic case - black blank keys
Offline anoxy
  • Deal with it
Re: [IC] RETRO RGB
« Reply #29 on: Mon, 19 May 2014, 00:53:55 »
+1
Offline bdtbinh
  • In Geek I trust
Re: [IC] RETRO RGB
« Reply #30 on: Mon, 19 May 2014, 00:58:28 »
I already post the poll in our community. Hope we will get the MOQ soon  :thumb:
Offline BlackDragonTribal
  • BDT
Re: [IC] RETRO RGB
« Reply #31 on: Mon, 19 May 2014, 02:54:28 »
Thanks. Good work :thumb:
Offline Yslen
Re: [IC] RETRO RGB
« Reply #32 on: Mon, 19 May 2014, 16:02:43 »
I'd ignored this thread until because I don't really like the look of RGB symbols on black mods, though I know a lot of people did like them.
Looking at that mockup though, the blue on white alphas and blue on black F-keys look really great... it's a shame I'm still not sold on the RGB/symbols. Good luck with the buy, anyway, if it goes ahead I might pick up a set of alphas :D
Offline OnTheBrink
    • Wired In Store
Re: [IC] RETRO RGB
« Reply #33 on: Mon, 19 May 2014, 17:58:59 »
Funny because it's the symbols I like and the fact that the RGB color scheme was subtle. To each his own though. There are plenty of sets people love that make me cringe hehe.
I am eager to see it with a darker blue as well which I feel will really make the alphas pop while still feeling like it's part of the set.
I am going to check with SP since this is gaining some traction but I think the MOQ should be 100 (if not too pricey) and it will obviously be tiered pricing.
I'll update the OP as well as soon as I know more.
Offline FrostyToast
  • Litshoard
Re: [IC] RETRO RGB
« Reply #34 on: Wed, 21 May 2014, 21:46:38 »
Bump! I think this needs more traction.
Offline Elrick
  • Hype Master
Re: [IC] RETRO RGB
« Reply #35 on: Thu, 22 May 2014, 21:37:11 »
Clicked on the POLL to see how it was going and all you did was provide 2 selections of blue on the keys?
You need to do up some graphics (variations) of this key-set otherwise this won't happen.  People need to see what they're buying into otherwise they go to the next Group Buy down the street and sign up for it.  There are far too many GB's here on Geekhack and if you want attention to your key-set and above all else any interest, then you do the showman style of a selling 'pitch'  8) .
Every successful pitch involves lots of graphics to help satisfy any curiosity on what's being available and what will be produced.  Then people decide on those very images that were displayed, it's that simple.  You want greater involvement of buyers then you need to lift your game in displaying the NEW key-set to everyone.  Don't just sell it to the oldies here on Geekhack who know what's going on but sell it to the newer keyboard enthusiasts to help entice their interest into customizing their input device  :thumb: .
In the past some others tried to get GMK/BSP group buys to happen but failed due to their own lack of salesmanship, very little interest was garnered.  Sorry but that's how we operate here on Geekhack especially with newcomers wanting to see what's the latest, greatest key-set currently available to buy.
I don't see why this RGB set couldn't get any more interest in the eyes of Geekhackers here, then setting up a nice display showing everyone what's available.  I've seen far worse setups take off down to SP and get made, later regretting why did they even bother to waste the plastic in making some key-sets in the first place  ::) .
Offline luisbg
Re: [IC] RETRO RGB
« Reply #36 on: Fri, 23 May 2014, 00:27:39 »
Sorry. I am new around here.
Where is the poll? I want to join.
Offline FrostyToast
  • Litshoard
Re: [IC] RETRO RGB
« Reply #37 on: Fri, 23 May 2014, 05:45:01 »
It should be the tiny url at the top of the first page
« Last Edit: Wed, 28 May 2014, 18:19:56 by FrostyToast »
Offline luisbg
Re: [IC] RETRO RGB
« Reply #38 on: Fri, 23 May 2014, 16:45:55 »
It should be the tiny url at the top of the fIrst page
I was blind, it was just. right. there.
Voted :)
Offline OnTheBrink
    • Wired In Store
Re: [IC] RETRO RGB
« Reply #39 on: Wed, 28 May 2014, 17:27:54 »
Just wanted to check in and let people know I am still checking on this. I would probably move it to a GB once we have 100 people interested.
If that is not a good idea, let me know as this is my first time hosting one of these. I would also invite anyone experienced with GBs to help out if they have the time.
However, fear not if you are in on this and are worried. Even if I know squat, I wouldn't have taken this on if I didn't think I could. I can easily research other GBs and follow their process when things get real. It just always helps when someone experienced can drop by with some advice about things that happen behind the scenes.
Offline bdtbinh
  • In Geek I trust
Re: [IC] RETRO RGB
« Reply #40 on: Wed, 28 May 2014, 20:19:57 »
Hope to get GB soon :D
Offline FrostyToast
  • Litshoard
Re: [IC] RETRO RGB
« Reply #41 on: Thu, 29 May 2014, 12:07:43 »
Would it be possible for us to get pics of the set with the new darker legends? That might raise some interest.
Offline archer
Re: [IC] RETRO RGB
« Reply #42 on: Thu, 29 May 2014, 12:28:41 »
If you could somehow get mockups similar to those done for the Granite GB, it could raise interest. Like a previous poster said, it's all about how you market/sell it! Fingers crossed this takes off!
Offline OnTheBrink
    • Wired In Store
Re: [IC] RETRO RGB
« Reply #43 on: Fri, 30 May 2014, 09:27:38 »
Yeah, I took the advise of the above poster and I'm working on darker blue examples. Going to take care of that this weekend.
Offline ideus
  • Björkö.
Re: [IC] RETRO RGB
« Reply #44 on: Fri, 30 May 2014, 13:24:40 »
I suggest to add a second 2.25u shift key to the set. Also I suggest to offer the modifiers as a standalone subset, due to the colors of the legends it may pull some demand as a sophisticated RGB like set, that may match original WoB cherries. Also, the 9 pack, and num pad may be offered as standalone subsets, to allow under-TKL users to get the caps they need only, with some savings. I'd be in for a modifiers set if available with no alphas.
Offline Cods
  • Penumbra SA Mark II please?
Re: [IC] RETRO RGB
« Reply #45 on: Wed, 04 June 2014, 07:56:47 »
Thanks from me also - and I too would prefer DSA.
Model M Industrial, SSK, Unicomp 104, Code TKL MX Green, FC660M MX Green + Clear + White + Grey, FC660C Topre 45g, MagicForce 68 USB and Bluetooth, Whitefox, some optical switch 65% Bluetooth split spacebar thing ... wait, I think I need an intervention. Too late, there’s a couple of new Model Fs on the way.
Too much SA is never enough.
Offline tigersharkdude
Re: [IC] RETRO RGB
« Reply #46 on: Sun, 08 June 2014, 07:49:23 »
I would be very interested in buying just the modifiers
And voted in teh poll
Offline bdtbinh
  • In Geek I trust
Re: [IC] RETRO RGB
« Reply #47 on: Tue, 24 June 2014, 08:31:55 »
Any news from this being GB?
Offline Jokrik
Re: [IC] RETRO RGB
« Reply #48 on: Wed, 25 June 2014, 05:48:12 »
interested if it's DSA/SA profile
Offline Elrick
  • Hype Master
Re: [IC] RETRO RGB
« Reply #49 on: Wed, 25 June 2014, 07:00:18 »
Let us know when you will run this.  Don't let this be another failed Key-Cap Group Buy  :)) .
SA would be nice but fitting the Icon(s) onto the face of an SA profile may be problematic.  You need to ask Melissa about that, DSA has been done to death already hence time to NOT choose anymore DSA profiles for now.
DCS maybe the final choice, but if you want this colour-way and icons, then it has to go this way.
