Are your eyes bleeding? You can always change your theme.
Paid my order, but it was only for 12 keycaps, although I ordered 13.I thought Ivan covered the ones that didn't make it?!
Sorry if I made mistake... it would be easier if you had let me know there was an error before pay. If you paid for something that isn't being made then you can either let me know something else you want or I can fix you with refund on key. PM me!
Some of you may see 2 separate shipping items... this is because you had a larger order which required more shipping than the base fee. I hope this clears things up if there is any confusion.
Does it show a quantity next to international? Mine says 0. I was confused before I saw the zero.
Quote from: Willyc277 on Wed, 04 June 2014, 01:32:08Does it show a quantity next to international? Mine says 0. I was confused before I saw the zero.Show ImageMine is 0 also
Order list.
why does my samurai sound like Japanese Batman?
Oh god, that Mr Sparkle, I should have bought 104 of them, so good, best in show.
These will go ahead with production immediately. There is no relation here really with the black on black stuff. White keys are already on hand at the dyesub place so there shouldn't be any delay on that front.I'm a huge fan of 80's pop trash and horror so it's highly likely there will be other similar stuff to come in the future.
Quote from: JunkFace on Wed, 11 June 2014, 22:24:45Oh god, that Mr Sparkle, I should have bought 104 of them, so good, best in show.That was the key that made me say 'Ok I'm joining this buy, if only for this key'. Then I saw Shibe and a few others
