Author Topic: [RANT] OMG I hate ABS so much  (Read 19342 times)
Offline ceflame
Re: [RANT] OMG I hate ABS so much
« Reply #50 on: Sat, 07 June 2014, 06:15:27 »
PBT > POM > ABS
Rough texture > Fine texture > No texture
I'm actually like the complete opposite. I've never tried POM, but the rough texture from Vortex's PBT Doubleshots starts to hurt my hands after a while (using blues).
« Reply #51 on: Sat, 07 June 2014, 10:00:57 »
i don't find the texture to be "important".
abs shiny will stick a bit sometimes, during humid weather / hot weather / serious gaming time/   but it's really not enough that I could blame them for performance drops..
I prefer the thick pbt only because the stem is well made/ smooth/ and looser, which makes the keytravel down very smooth.
Offline TheSoulhunter
  • Thorpelicious!
« Reply #52 on: Sat, 07 June 2014, 14:52:46 »
For me the texture is more a "comfort" thing and not about performance...
The sticky feel of non textured caps makes me think the caps are dirty/filthy.
« Reply #53 on: Sat, 07 June 2014, 14:54:59 »
"Grippy" not "sticky." ;)
Offline archer
« Reply #54 on: Tue, 10 June 2014, 10:57:07 »
Does the texture on a SP ABS key wear down into a shiny, smooth surface quickly? I own a couple SP sets, but haven't used them enough to have any shine.
And my 2c for this texture debate is that generally, PBT has a better texture on it compared to ABS. The one exception to this rule: GMK ABS. I love the way GMK ABS feels over any other keycap material.
« Reply #55 on: Tue, 10 June 2014, 14:21:10 »
Just say no to ABS
I prefer the sandpaper feel, and want as much texture for as long as possible personally.
I love no shine and the PBT feels.
DS ABS Cherry caps feel even better when they get that shiny texture. It is very easy to type on them, and the greasy feeling help to "grip" on the caps.
The shiny, greasy texture is the exact reason I'm still on the fence about the current GMK group buy. I have some GMK keys, but seeing (and having to use) glass-smooth-with-finger-gunk-surround ABS keys
 at work is stopping me from spending that much on a keycap set.
The keepers: 660C/Blank 660M/Blues
Offline laffindude
« Reply #56 on: Thu, 12 June 2014, 02:07:46 »
You aren't using the right ABS caps, sir. GMK/Cherry thick ABS are the best. PBT is teh yuck.
This. ABS = awesome.
« Reply #57 on: Thu, 12 June 2014, 05:49:42 »
ABS aren't so bad. It's just the thin or poorly manufactured ones give others a bad rap. Plus it's a pain in the butt to find a decent DS PBT set now a days (still.)
« Reply #58 on: Thu, 12 June 2014, 10:03:54 »
A lot of people are neglecting the fact that PBT will still develop a shine. It just takes a lot longer than it does with ABS caps.
QFR | MJ2 TKL | "Bulgogiboard" (Keycon 104) | ctrl.alt x GON 60% | TGR Alice | Mira SE #29 | Mira SE #34 | Revo One | z | Keycult No. 1 | AIS65 | First CW87 prototype | Mech27v1 | Camp C225 | Duck Orion V1 | LZ CLS sxh | Geon Frog TKL | Hiney TKL One | Geon Glare TKL
Offline Danule
« Reply #59 on: Sat, 14 June 2014, 11:52:42 »
Very true.  I have had my realforce for a little over a year now and it is beginning to develop shine on some of the most used keys.
I like both PBT and ABS.  PBT can be a bit harsh on fingers as it is a harder plastic,  But abs can tend to stick to your fingers if they get sweaty.  Depends on what you are into.
45g Brown Brown Blue
Offline Oobly
« Reply #60 on: Mon, 16 June 2014, 02:41:28 »
POM.... Just go POM....
No hardness, no stick... Fast typing, good feeling. Much happiness. Wow.
I like 'em all if the caps are good quality and nice profile.
What are you talking about? Stem area accuracy doesn't affect the switch feel at all since there is no moving contact between keycap and switch.... (unless they're REALLY badly made and the stem area is too large and contacts the upper switch housing, but I have yet to use a cap that does that).
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Justintoxicated
« Reply #61 on: Mon, 16 June 2014, 19:32:37 »
Meh I really like the quality of the doubleshot ABS keycaps on my blackbird because the LED lighting emits out of the letters perfectly and gives them a a very nice look, they feel good and type really well too.  I think it must be the extra thickness that helps them out. However I don't mind the texture of PBT on the FC660C either, they are both very nice IMO.
Now cheapo ABS keycaps I do not like. Thin, printed, or painted keycaps just don't have the same feel or look!
« Last Edit: Mon, 16 June 2014, 19:34:08 by Justintoxicated »
Offline Danule
« Reply #62 on: Tue, 17 June 2014, 09:16:51 »
Currently i have yet to try pom. But my favorite so far is cherry profile doubleshot abs. Pbt is nice but a bit harsh.
« Reply #63 on: Tue, 17 June 2014, 12:05:55 »
Bro, do you even Lift?
Offline fuzzybaffy
« Reply #64 on: Fri, 27 June 2014, 00:29:00 »
Gotta agree with the OP. For a bit I was actually using a set of ABS caps from WASDKeyboards instead of a set of dye-sub PBTs from Imsto, because I wanted caps in OEM profile (PBTs from Imsto are Cherry profile). Then after a while I just got tired of the texture of the ABS keys - it was like wearing a pair of really uncomfortable shoes, functional but just really uncomfortable - and then switched back to the PBTs from Imsto.
It was an instant improvement, and it made me wonder why I went with the ABS caps from WASD for the sake of OEM profile, to begin with. :( Maybe I just wanted to test them out, and/or thought I would get used to the different texture of ABS.
So, yea... PBT = 1,000,000x better than ABS. IMO, of course.
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #65 on: Fri, 27 June 2014, 00:50:09 »
Don't let that turn you off ABS all together, WASD caps are probably the nastiest ones available IMHO. Check out a GMK set and you'll see what all the fuss is about.
Offline fuzzybaffy
« Reply #66 on: Fri, 27 June 2014, 01:02:18 »
True. I should have mentioned that not all ABS are the same. Perhaps I will check out a GMK set one day! Thanks for the FYI.
Offline SpecTP
« Reply #67 on: Tue, 01 July 2014, 10:22:17 »
I bought some WASD key caps from WASDkeyboards.com and they lasted about 2 months.  All the lettering have worn off.  Are there better options out there for a heavy gamer like me?
Offline tbc
« Reply #68 on: Tue, 01 July 2014, 15:57:08 »
anything is better than WASD.
you're going to want to checkout taihao keysets.  but i'm pretty sure ypu have to buy the whole set, not just wasd.
keypop.net
Offline Oobly
« Reply #69 on: Wed, 02 July 2014, 04:58:28 »
To add some fuel to the fire I have some Cherry profile PBT caps which I really don't like at all... They came on a Cherry G80-3000LCQEU-0 I recently purchased. I prefer my SP ABS caps by a good margin.
They're really thin and cheap-feeling. It's really more about the weight of the caps for me, it seems. The heavier doubleshot SP keycaps feel a lot better than the light lasered PBT Cherry caps, even though I prefer the Cherry profile to the SP DCS profile.
Current favourite caps are medium thickness OEM profile POM blanks, but I am currently using some SP ABS (Nostalgia set) since I need the legends and I suspect the GMK thick ABS caps I have ordered will take the throne when they arrive.
The new Vortex doubleshot PBT caps look very interesting, too. Thick doubleshot PBT with nice fonts and very Cherry-esque profile. There is now also a WoB set in addition to the colour sets: http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=774
Offline quadibloc
  • Layout Fanatic
    • John Savard's Home Page
« Reply #70 on: Thu, 03 July 2014, 19:40:57 »
PBT and POM may be harder than ABS, which does mean that they're better, but I find ABS - at least if the legends are achieved by double-shot molding - quite adequate.
Another hard plastic - but, sadly, not suited either to double-shot molding or to a range of colors - is Bakelite. I think that's what the square keys on an old Flexowriter are made from...
A really hard material - and one which would protect the legends on the keys, thus eliminating the need for double-shot molding - would be some type of glass, if one were thinking of getting really fancy. But that has the drawback of having to wipe oil from one's fingers off the keys all the time, even if it would wipe off easily.
Marble or polished granite, I think, we will have to leave out of consideration.
Offline minho
  • i'm kind of back
« Reply #71 on: Thu, 03 July 2014, 23:09:36 »
All you bored DIY-ers out there, I think we found you a new project.
Offline nukec
  • that rug really tied the room together
« Reply #72 on: Sat, 05 July 2014, 03:49:34 »
So I just put a set of Vortex thick white on black DS PBT caps on my Code keyboard, and HOLY **** IT'S LIKE SEX ON MY FINGERTIPS. How does anybody stand ABS keycaps? They just feel so, ugh... flimsy and fake and just stupid.
Stupid ABS and their stupid feeling stupid keycaps.
</rant>
Just had to get that off my chest.
I agree with this ranter :D
Check my new baby http://imgur.com/a/Abfi6
DSA PBT caps. I am not sure waiting for DCS profile too, but default was DCS, still don't know what feels beter between those 2 profiles :) I think you have more control with DCS.
HHKB Pro2, Poker2 Blue, KBPV60 Brown, DuckyShine3 Brown
Offline daerid
    • Rossipedia
« Reply #73 on: Mon, 07 July 2014, 12:50:29 »
I couldn't really do DSA. I really, really wanted to because I love the way they look. But I had major accuracy problems and had to go back to DCS.
Offline Riptide
« Reply #74 on: Tue, 08 July 2014, 07:28:03 »
excuse me, self confessed noob here... you got me curious... What are GMK/Cherry thick ABS keys are? Looking for a lime green keycaps maybe i could get them in that quality..
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #75 on: Tue, 08 July 2014, 07:38:10 »
GMK has a nice green, but you'd have to wait on a massive interest check then group buy to go through...
Offline Riptide
« Reply #76 on: Tue, 08 July 2014, 08:18:17 »
you cant just buy it? :(
can you send a link? thanx!
« Reply #77 on: Tue, 08 July 2014, 17:24:25 »
GMK is a German commercial keycap manufacturer, and need hundreds of orders for keycap sets before they will start making them.  Usually they need thousands of orders for one set, but Ivan was able to negotiate with them for a lower MOQ for GH.
Offline taylordcraig
« Reply #78 on: Sun, 13 July 2014, 01:59:23 »
QUOTE FROM SKYPE
[9:49:33 PM] taylor craig: i thought i loved pbt raw texture but this buttery smooth feeling of penumbra is amazing...
[11:05:39 PM] taylor craig: okay actually typing on it feels kinda weird. just poking at it felt really nice though
[11:05:40 PM] taylor craig: idk its kinda nice
[11:05:44 PM] taylor craig: fk
[11:06:11 PM] taylor craig:  :-\
[11:50:57 PM] taylor craig: I'm in love with Penumbra.
[11:50:59 PM] taylor craig: Please help.
[11:51:14 PM] *: Deal with it :P
[11:51:55 PM] taylor craig: HOW DOES THIS ABS GARBAGE FEEL SO GOOD
[11:51:55 PM] *: Comment in daerids thread
Here I am.
To tell you thick ABS is so delicious.
At least SP's SA profile.
I have a GMK Dolch set coming.
Offline CaptLock
« Reply #79 on: Mon, 14 July 2014, 09:16:00 »
I;ve only tried ABS
« Reply #80 on: Mon, 14 July 2014, 17:04:10 »
I;ve only tried ABS
You don't know what you're missing ;)
Offline myrddin
« Reply #81 on: Mon, 14 July 2014, 20:17:22 »
I have abs and pbt, really the only difference that I care about is how badly PBT warps.
Personally, I would be happy if the keys came with a completely smooth surface to begin with, I don't need help gripping them, and it isn't like the surface affects my ability to type.
Offline iLLucionist
  • Topre is Love.
« Reply #82 on: Tue, 15 July 2014, 16:10:00 »
Honestly POM are pure perfection.  It baffles me that they never caught on.
Why? What's so awesome about POM? (zero experience with POM, only ABS/PBT)
Offline Crazyhendrix
« Reply #83 on: Sun, 27 July 2014, 05:45:46 »
I actually like the feel of smooth ABS. I just bought a poker ii---like an hour ago. I like it, but the texture on the keycaps compared to my clicky QFS is somewhat distracting. Maybe it's cause I prefer typing on the Cherry MX green more than browns. Gotta keep the peace at home in the night though.
I have 'two' many keyboard. CM Quickfire Stealth(greens) and Poker II(browns)
Offline Daspartic
  • IBM is love IBM is life
« Reply #84 on: Sun, 27 July 2014, 05:56:19 »
I like ABS, but give me PBT all day err day.
IBM Displaywriter (82 key) | IBM Model F 4704 (107 key) |  IBM Model F AT x3 | IBM Model F XT | IBM Model F 3104 x2 | IBM 6112884 (Green Tee mount Alps) | Realforce 87u (55g) | IBM Model M 1390131 x2 | IBM Model M (1391401 '88) | Leopold FC500R (MX Browns) | Wang (725-5971) (Salmon Alps) | Acer 6011 (SKCM Blue Alps) | White Fox (65 g Zealios) | XMIT keyboard (Hall Effect)
Offline Oobly
« Reply #85 on: Sun, 27 July 2014, 10:00:39 »
It's the densest keycap material, so it dampens high frequency sounds well and makes for the heaviest caps. IMHO this makes them feel higher quality than other materials. Also, my fingers glide over them so nicely, due to the surface feeling of the material regardless of actual surface texturing. It's almost like teflon, but doesn't ever feel "sticky" like smooth ABS.
It's also slightly flexible, so has good dampening properties, reduces bottom-out shock and changes the release noise to be less harsh.
POM just rocks.
@Crazyhendrix: If you like Greens, I think you'd prefer Clears to Browns. More tactile and stronger springs.
Offline GSimon
« Reply #86 on: Sun, 27 July 2014, 10:49:45 »
The Poker is not the best representative for PBT in terms of texture because the legends are top printed, so you're feeling that in addition to the PBT cap.
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #87 on: Sun, 27 July 2014, 10:52:57 »
The problem for me is finding ISO sets of the DS/PBT sets I like. I bought a vortex blue/white DS set from MK.com but no ISO :( I can't seem to find decent sets on a regular basis.
Admittedly I only have one ISO board, but it's also the only one with WASD caps. Thats why I have them, because it was the easiest place to find an ISO set.
Offline Oobly
« Reply #88 on: Sun, 27 July 2014, 14:10:57 »
If you can settle for dyesub thick PBT you could get a Ducky ISO set for it... They're also OEM profile, but at least they're MUCH nicer than WASD caps.
« Reply #89 on: Sun, 27 July 2014, 14:13:48 »
I did read up on the Clears. However, I have no intentions of either soldering Clears onto a 60% KB. Besides, getting an off the rack keyboard with the 60% form-factor is kinda remote atm. So, I settled for the Browns---which I did use for like 2 weeks. It isn't bad. I could type faster with it than the Greens, but with more typos. :p
@GSimon: I thought about the legends contributing to the roughness of the keycaps. I'm not dissing PBTs. In fact, the thickness of the caps on the Poker seem to muffle the bottoming out 'thunk' sound compared to thin ABS on the QFS. I'm easily satisfied. PBT or abs, as long as the switches are nice, the form factor puts the mouse nearer to my hands, I'm good. It's better than using a rubber dome for the matter.
tl;dr version: I like smooth ABS just a little more than PBT. I could live with either.
Offline tbc
« Reply #90 on: Mon, 28 July 2014, 01:47:31 »
they have poker II with clears on massdrop.  they just finished, but this is their second in a month i believe.  it'll most likely be back many times over.
the era of no 60% clear boards is gone :D
« Reply #91 on: Mon, 28 July 2014, 04:21:05 »
NOOOOooo! I don't need another keyboard! I would love to try the clears though.... must fight the temptation.
Offline Hitcha
« Reply #92 on: Fri, 01 August 2014, 13:59:02 »
After your try PBT caps, you're spoiled for life. Really hard to go back to zero texture ABS.
Full Metal Poker II - http://imgur.com/a/xK2Uv
Offline Skull_Angel
« Reply #93 on: Sun, 03 August 2014, 09:55:31 »
After your try Cherry POM caps, you're spoiled for life. Really hard to go back to anything else.
Ftfy  ;D
Offline Oobly
« Reply #94 on: Sun, 03 August 2014, 15:06:41 »
Ftfy  ;D
Oobly likes this. Still have yet to find a switch / keycap combo that feels better to me than trampoline modded 62g ErgoClears with POM caps.
Offline AuRinBei
« Reply #95 on: Sun, 03 August 2014, 15:19:39 »
Ftfy  ;D
What POM have you used that is that super incredible? I don't think I've ever seen thick POM. I use rainbow jellies, and while they are better than ABS, they feel very similar to my thick vortex PBT in terms of texture. I prefer the Vortex though because they much thicker and make a better sound.
87u || Poker 2
Offline Skull_Angel
« Reply #96 on: Sun, 03 August 2014, 16:36:34 »
Ftfy  ;D
I bought an alpha set off a Cherry G81 from Signature Plastics (I forget the story behind why they have them) and they feel amazing. They may be laser etched, but that's pretty easily overlooked by the fact that they're thick and Cherry profile (not to mention POM  ;D ), I'd be using them now if I couldn't get over the double-shot Skull Squadron DSA set I picked up.
I also have a set of OEM profile POM from a PLU MLG-3000-NKRO. They're thin caps, but still feel heftier then most standard stock ABS, the texture on them isn't as great as that of the Cherry POM caps either, imo (the Cherry POM also have less shine than the PLU caps when new).
edit; I haven't checked out Vortex's caps so I can't make any comparisons there, sorry.
Offline Oobly
« Reply #97 on: Mon, 04 August 2014, 02:41:17 »
Ftfy  ;D
Genuine Cherry POM lasered caps (from a G81-3000). Unfortunately, it's alphas only (spacebar, caps lock, etc are not compatible with most ANSI boards). I also have some Keycool POM blanks which feel very good to me (probably very similar to your rainbow set), even though they're OEM profile and only medium thickness.
Really hoping for Ivan to run a thick POM group buy soon, maybe through PLUM. He's using them for the Pitch Black thick PBT Cherry profile sets. Maybe once the GMK Dolch GB is over.
Offline limitz
  • "the old gods stir and will not let me sleep..."
« Reply #98 on: Mon, 04 August 2014, 12:58:24 »
Lol, this thread is the definition of a first world problem.
I have SP ABS, I have GMK ABS, and I have Vortex PBT. They all have their different feels, but in no universe would I rant about hating "ABS so much."
Mmm... machined aluminum
Offline GSimon
« Reply #99 on: Mon, 04 August 2014, 13:45:14 »
This lol. It's like those who say "omg I've tried every switch, blues, clears, browns...none of them feel right to me!". I think there's a line between having a certain preference and being overly critical, many seem to cross that line.
