Author Topic: Stabilizers: Costar vs Cherry  (Read 10007 times)
Offline Defect
« on: Sat, 07 June 2014, 07:29:39 »
Hello all, wanted to share my recent (very recent) change of heart with regards to stabilizers.
So, we have Costar Stabs and Cherry Stabs (Not My Pictures):
Cherry:
Costar:
Generally speaking, Cherry stabs are mushy in feeling and Costar stabs are rattly and noisy.  For the longest time I prefered Cherry stabs simply because of the noise.  Hitting a rattly spacebar is just an absolute disgust.  But then I bought some Silicone Grease and lubed my Costar stabs.  Especially on a black stem switch, it's now buttery smooth and silent.
Costar is better.  Thank you for joining me in my review.  All 3 words.
Re: Stabilizers: Costar vs Cherry
« Reply #1 on: Sat, 07 June 2014, 07:36:51 »
Have you lubed and clipped your Cherry stabilisers?
« Reply #2 on: Sat, 07 June 2014, 07:51:43 »
I agree with photekq, clipped Cherry stabilizers are my favorite. The convenience of Cherry with the nice crisp feeling of costar. And no rattling.
Offline Defect
« Reply #3 on: Sat, 07 June 2014, 13:50:23 »
No, I haven't.  Maybe I'll have to do that and then come back :)
Offline dante
« Reply #4 on: Sat, 07 June 2014, 23:47:06 »
I always thought it would be cool to do a layout that didn't require any stabilizers.
Offline archer
« Reply #5 on: Tue, 10 June 2014, 14:51:04 »
Is there a tutorial thread out there somewhere that explains what/how this is? I've never heard of lubing and clipping Cherry stabs, but this is very relevant to my interests.
Thanks in advance!
« Reply #6 on: Tue, 10 June 2014, 15:05:06 »
Thanks in advance!
You basically take apart the stabilisers, then clip off the two bendy legs on the stems of the stabilisers. Then put it back together. For lubing.. Lube the sides of the stem with thick grease such as GPL205, and lube where the wire touches the housing.
Offline Battou62
« Reply #7 on: Tue, 10 June 2014, 15:08:06 »
You can't get to the Cherry stabs on plate mounted boards can you? Not easily anyways? It would require desoldering?
« Reply #8 on: Tue, 10 June 2014, 15:15:06 »
Yeah, desoldering required unfortunately. It's worth it for that mod though. It makes them feel so much more crisp.
Offline aref
« Reply #9 on: Thu, 12 June 2014, 00:13:15 »
I prefer Cherry stabilizers. But, I have been using red o-rings and a bit of waffle foam tucked under the space-bar to diminish the excessive clacking.
Offline GenKaan
  • Mer caps, mindre käbbel
« Reply #10 on: Wed, 18 June 2014, 04:33:47 »
I prefer the Cherry one because of how easy it is to remove and clean caps. Never even took the rattle into consideration but now Im convinced what I prefer
|| @Home:: Shine 3 TKL (Mx Red / Deep Space)  || @Work:: G2Pro (Mx Clear / Dye Sub PBT) ||
@Reserve:: HHKB (Topre 45g / Mixed PBT) // Das v3 (Mx Brown / Blank PBT)
Offline Battou62
« Reply #11 on: Wed, 18 June 2014, 07:08:11 »
I prefer costar, but I have never tried any clipped cherry stabs.
Offline osi
« Reply #12 on: Wed, 18 June 2014, 07:16:33 »
In my experience, Costar has felt more crisp than cherry but in practice, the differences are not dramatic enough for me to have a preference.
Offline strict
  • TKL Zealot
« Reply #13 on: Wed, 18 June 2014, 12:46:45 »
Cherry is fine on linear switches, theres no tacticality for them to numb out. I wouldn't use anything but costar on switches with any sort of tactical switches though.
Offline FrostyToast
  • Litshoard
« Reply #14 on: Wed, 18 June 2014, 12:52:21 »
tactical switches
Tactical switches? I have never heard of these "tactical switches".
Can they carry out assassination contracts for me?
Quote from: elton5354
Offline epzy
  • HHKB Fiend
  • ded
« Reply #15 on: Wed, 18 June 2014, 12:54:54 »
Cherry4lyfe.
Offline strict
  • TKL Zealot
« Reply #16 on: Wed, 18 June 2014, 13:37:49 »
tactical switches
I typed out the second sentence and reworded the last half after I read it but apparently overlooked that part  :))
