Author Topic: [IC] No SMD PCB Project -- 60%, 75%, 87%, 100%  (Read 2396 times)
Offline Pacifist
  • on hiatus
« on: Sat, 21 June 2014, 22:06:48 »
IC
No SMD required PCBs
I want to design and make PCBs. What makes these different from most others? It'll be teensy and/or pro micro based and require no SMD work: just simple through hole.
Plans:
Must haves:
PCB mounted stabs, compatible with "universal" plates and cases
PCB mount holes
Medium Priority:
ANSI+ISO support, multiple layouts
MX and Alps support
Backburner:
Backlighting support
Idea list:
Put teensy in spacebar location
104 can be broken off into TKL or 60% and a numpad. Either seperate controllers for each or some sort of connection to use one controller
« Last Edit: Sun, 22 June 2014, 16:54:37 by Pacifist »
Offline Pacifist
  • on hiatus
Re: [IC] No SMD PCB Project -- 60%, 75%, 87%, 100%
« Reply #1 on: Sat, 21 June 2014, 22:07:18 »
reserved
Offline Hak Foo
  • Make America Clicky Again!
« Reply #2 on: Sat, 21 June 2014, 22:17:00 »
Alps?
Overton130, Box Pale Blues.
Offline Pacifist
  • on hiatus
« Reply #3 on: Sat, 21 June 2014, 22:18:23 »
Alps?
Thank you for reminding me about that. Only issue is getting plates and cases made, but hopefully they can fit with preexisting cases
Offline Magna224
« Reply #4 on: Mon, 28 July 2014, 09:11:01 »
Id probably get one if it was ALPS compatible.
If you live in AZ you can try my keyboards. I usually keep plenty of different ALPS and MX and buckling springs.
« Reply #5 on: Mon, 28 July 2014, 14:37:04 »
One 100% PCB with break-away parts, to get TKL and 60%... Yeah, that idea was up for a project called "The Light" that didn't take off. There might be some useful info in its old thread though.
I would like to have a TKL PCB with the function key row on a separate PCB so that I could raise it up a little.
« Last Edit: Sun, 03 August 2014, 13:45:59 by Findecanor »
