How do these compare to super blacks? If heavier, I'm in for trying a couple.
150 isn't, 300 is.
Yea I'll try out a 300. I'll shoot you a pm
55555
I can never understand why someone would want to try a 300g spring if 55g is already considered pretty heavy.
I'm pretty sure the uber heavy Model F spacebar is under 150g.
The only possible use of that is if you decide to program one key as ctrl-alt-delete and don't want to hit it by mistake.
