Have you read the geekhack TOS lately?
Quote from: Synjin on Sat, 04 October 2014, 18:13:19http://duck0113.tistory.com/101 this site contains images of where he rgb led are installed and I'm assuming that the firmware let's you control the colorsI see, so you can't use a plate if you want to see the RGB effects.
Quote from: feizor on Sun, 05 October 2014, 02:33:44Quote from: Synjin on Sat, 04 October 2014, 18:13:19http://duck0113.tistory.com/101 this site contains images of where he rgb led are installed and I'm assuming that the firmware let's you control the colorsI see, so you can't use a plate if you want to see the RGB effects.the RGBLEDs are on the other side of the SCB from where a plate would go. The 2 on the sides shine down on your desk through the holes in the case, just like all the other duck keyboards (my idea!). The rest are positioned around the edge and wolud shine out through the side of the case through that plastic spacer. I really like how duck has gone to RGBLED: I think it's a great step in the right direction. I will probably have to pick up one of the next generation.
Final pictures and videos of the Octagon before a GB...http://duck0113.tistory.com/108The Koreans are starting next week..
If today had been a hippo, then you'd really have to worry about tomorrow.
When will geekhack group buy start elton?
I'll ask here too:Does anyone know where Duck got the HHKB stickers he put on his Viper?
So this is a 'tray style' case so it's made up of one piece of metal and a plate, so it won't be as 'solid' as a KMAC, correct? How about compared to a GON, this will be more solid right? Sorry for the silly question.
Quote from: cannonking on Mon, 20 October 2014, 19:18:56So this is a 'tray style' case so it's made up of one piece of metal and a plate, so it won't be as 'solid' as a KMAC, correct? How about compared to a GON, this will be more solid right? Sorry for the silly question.Yes it's tray style case. It might not be as solid as KMAC, but it has a lot more metal than Gon.
I might be interested but can some one explain the appeal of that steep incline on the case?
Quote from: radio_killah on Tue, 21 October 2014, 15:06:48I might be interested but can some one explain the appeal of that steep incline on the case?This is my personal opinion but the incline on my lightsaver isn't bad at all and it appears to be very comparable if not the same on the 75%. I use a Filco wrist rest so my palms sit at a good height and is very comfortable to type on. I wouldn't recommend a DSA set for such a board but to each their own. =)
Quote from: digi on Tue, 21 October 2014, 15:17:12Quote from: radio_killah on Tue, 21 October 2014, 15:06:48I might be interested but can some one explain the appeal of that steep incline on the case?This is my personal opinion but the incline on my lightsaver isn't bad at all and it appears to be very comparable if not the same on the 75%. I use a Filco wrist rest so my palms sit at a good height and is very comfortable to type on. I wouldn't recommend a DSA set for such a board but to each their own. =)Yeah I wouldn't use anything but a sculptured set on something with that steep of an incline. I actually really like DSA and I tend to lay my keyboards down flat so I might have to pass although the layout on this looks awesome.
Group buy is up on KBDLAB. http://kbdlab.co.kr/index.php?document_srl=759188&mid=board_gb_outsideI'll have one up next week.
GB will start about the same time, but the lead time for shipping is 3 months.
Quickly mods, approve it so I can join in.
